Question about Frymaster Dean Kitchen Appliances - Others
I have a Frymaster FMH 250SC bunners are not lighting
How to change the pilot light thermocouple on my frymaster
the bottom cover may reveal it. It may need the shell removed. Look for tine screw to remove to release it.
Jan 19, 2017 | Frymaster Kitchen Appliances - Others
Frymaster
Turn gas valve to off for 5 minutes, then turn to pilot and push in and hold then light pilot light, release slowly and turn to on.
Apr 23, 2013 | Frymaster Kitchen Appliances - Others
Knob is turned off but burner light is still on and burner area warm
If this is a glass top cooktop then yes the bunner light will still be on when you turn it off. Also the bunner area will be still be hot. The reason why the light is still on it is telling you that the bunner surfas is still over 95 degrees. Once the bunner area is under the 95 degrees the light will go off. It is a safty warning for people saying that the surface is still hot.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 07, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Frymaster will not re-light after reaching temp on initial start
You have a lazy thermostat that needs replacing. Not uncommon.
Tom
May 21, 2010 | Frymaster Dean FM345EETC Deep Fryer
I need to know how to lite the pilot on my frymaster fryer
fry099_16_4.gifMake sure the thermostat is turned off. Units burners will light as soon a pilot in it is on. fry099_16_5.gif 3-2 Lighting the Pilot and Burner Figure 1 Figure 2 3. Push the knob in and light the pilot. Continue to hold the knob in for about 60 seconds after the flame appears on the pilot. Release the knob. The pilot should remain lit.
I suggest that you boil it out before using. This cleans the pot of any contaminants here is how to do this.
Boiling Out the frypot To ensure that the frypot is free of any contamination resulting from its manufacture, shipping, and handling during installation, the frypot must be boiled out before first use. Frymaster recommends boiling out the frypot each time the oil or shortening is changed. 1. Before lighting the burner, close the frypot drain valve and fill the frypot with a mixture of cold water and boil-out solution or detergent. Fill to the lower oil-level line. 2. Light the fryer in accordance with the lighting instructions in Section 3.1. 3. Simmer the solution for one hour.
I would attempt to paste the complete owners manual but it's just way to large. I do warranty for Frymaster is how I have access to it. Good luck
Oct 17, 2009 | Frymaster Dean GF14 Deep Fryer
I have a frymaster model mj35ssp cannot find where to light the pilot light at! Can someone please tell me
If you forward your e-mail address I will send you the Frymaster instructions w/ picture of where to light the pilot.
Rick
capt_rick1912@yahoo.com
Jul 21, 2009 | Frymaster Dean MJ35-SC-1 ''Standard'' Deep...
Stove bunners flame are to low?
take the knob off, insert a small flat head screwdriver into the shaft and turn slowly
Jul 20, 2009 | Whirlpool GS460 Gas Kitchen Range
Open Questions:
Kitchen Appliances - Others Logo
198 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Thomas Perkins
Thomas Perkins
Paul Carew
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
