Question about Sharp R-1850A Convection/Microwave Oven
My microwave is in my motor home which was connected wrong to 220. the micro doesnt come on at all. is it done or is there a fuse or something that i can replace sharp r-1850a
  • 553 Answers
I'm afraid that the high voltage would have burned out most if not all of the electronics in your microwave. It'll probably be the most cost effective to replace the microwave.
Posted on Jul 27, 2010
Microwave quit working, timer, number buttons timer, all functions on micro side of control panel quit working , timer numbers start etc.
Check to see if the fuse went. If negative then something is wrong with the electronic pad for the unit.
Nov 25, 2015 | Microwave Ovens
WHAT WILL MAKE MY GE MICROWAVE WES1384SM2SS FUSE KEEP BLOWING I REPLACED IT ONCE AND AS SOON AS I OPEN THE DOOR IT BLEW AGAIN
The fuse is there to protect your home in case something has gone wrong inside your microwave. Since the fuse has blown twice, you can safely assume that there is something wrong inside. It may be fixable, it may not be economic to fix it. Impossible to troubleshoot electronics without the unit and test equipment.
Jun 04, 2015 | GE Microwave Ovens
My microwave oven sharp r-220, it doesnt give heat or produce heat? what should i do to fix it?.. the light bulb, motor fan and the timer are all ok..
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 14, 2010 | Sharp R-220BW Microwave Oven
Micro doesnt heat
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse), then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Aug 19, 2010 | GE Profile Spacemaker Over-the-Range...
We bought model NNst4477s. It was delivered on Friday and used to defrost and also heat other food. It then simply lost all power. There is not even any visual display on the clock etc. The fuse is ok. ...
All microwaves have a fuse inside, usually behind the control panel. You need to know how to open the micro to access this fuse either by removing the control panel, or by removing the outer shell case. Must caution that there is a hi energy capacitor that holds a hi voltage charge and if you touch the wrong connections, you will get zapped. This charge does not go away just because you unplugged the micro. If you find the fuse to be bad (you must have a tester because you cannot see if it is bad), then you also need to assume that something else caused the fuse to go bad. Goodluck, MACGIVOR
Jan 31, 2010 | Microwave Ovens
All of a sudden, no power, no lights, NOTHING!
if the microwave is on the same circuit as the refrigerator, it's possible that the micro was turned on just as the refer compressor kicked on. i've seen that situation pop a fuse in microwaves many times - make sure you get a ceramic slo-blo fuse
Aug 22, 2009 | Emerson Black Microwave Oven
GE Spacemaker Micro
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
srtat
Jun 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave doesnt work at all
If the micro is completly dead and the outlet is OK... check the main fuse inside the cover. Unplug unit, remove cover (screws in back) and check the fuse where the power cord comes in through the back.
I am not sure what region you are in but in the States it is usually a 15A fuse. REPLACE ONLY WITH EXACT FUSE. Most hardware stores have these for microwaves.
MM85
Jul 22, 2008 | Frigidaire FMT116E1W Microwave Oven
good day, try to check your cooking settings. tnx
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-1850A Convection/Microwave Oven Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
