Question about Casio PAW1500T-7V Atomic Solar Pathfinder Watch
How to adjust Casio 1500t-7v titanium watch band
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
The schlatter.org solution is for the other type of casio band I've run into.
The wristband with the arrows has a fine pictorial solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band
Basically you use a very very fine poker to poke the pins out in the direction of the arrows.
NOTE: you can't poke them out if you will drive them into your work surface, so think about that before you start.
Posted on Feb 02, 2008
SOURCE: Casio watch band adjustment
Check the Citizen web site: http://www.citizenwatch.com/Technical/English/Service/pin1tube.pdf
You can skip the part about removing the split tube. Instead of their pin pushing tool, I used a short piece of straight pin held with long-nose pliers while I squeezed using medium sized channel-lock pliers. A helper to hold the watch would've been good.
Posted on Dec 26, 2008
escapement
  • 2334 Answers
SOURCE: How do I get the pins out of the titanium band for Casio PAW1500T
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 09, 2009
  • 12 Answers
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Posted on Oct 04, 2009
Why is there a discolored spot on crystal?
This could be caused by damage to one of the filtering films for the display. Did the crystal experience severe pressure or heat at some stage? I'd take it to a service center to have the crystal film checked or just live with it. Maybe the film will recover over time if not abused.
Sep 20, 2015 | Casio PAG80T 7V Triple Sensor Sea...
I just purchased a casio pathfinder watch without a instruction manual model PAW1500T-7V how do I find one
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Jun 15, 2010 | Casio PAW1500T-7V Atomic Solar Pathfinder...
How do I adjust a Casio PAW 1200 Titanium watch band.
You can get instructions from the Casio web site.
Select "support" and the "manuals", watches;
Accept terms
Click on "search" and the download your instructions.
Feb 26, 2010 | Watches
Adjust Watch Band
Click on my profile, then click on TIPS AND TRICKS. There you will find explanation how to add or remove links. Rate me, plz.
Feb 24, 2010 | Timex Ironman Triathlon Hi Ti Watch,...
Job done!
Jul 09, 2009 | Casio PAW1500T-7V Atomic Solar Pathfinder...
Adjusting the world time??
If your watch is Casio:
http://world.casio.com/wat/download/en/manual/
If not, give ALL the details.
Rate, please.
Mar 30, 2009 | Casio G-Shock 800D 7V watch
Wrist band adjustment
In addition to the Pin there is also a small inner "locking" collar about 2mm long that fits into the center section of each link.
I did not notice this collar at first and it fell to the ground when I removed the first link. Without this piece the Pin's will just slide through the links with no locking mechanism.
It fits neatly into the inner portion of the link directly opposite the arrow that shows the direction of removal on the band.
Jul 01, 2008 | Casio G-Shock G7000D-8V Wrist Watch
Casio pathfinder SPF 70-s titanium band adjustment
I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
Dec 17, 2006 | Casio G-Shock G7000D-8V Wrist Watch
Casio PAW1500T-7V Atomic Solar Pathfinder Watch Logo
392 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
