Question about Sony Cyber-shot DSC-S730 Digital Camera
I replaced new batteries and when I turned it on, the red light display below a timer symbol. How can fix it?
  • 6,826 Answers
Http://esupport.sony.com/US/perl/model-home.pl?mdl=DSCS730&LOC=3
The above is a link to the product page of the DSC-s730 camera.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C265373&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=144724361&stateId=1 0 144722813
The above is a link to how to 'reset' the cyber shot type camera to factory defaults.
Hope this helps.
Posted on Jul 27, 2010
How do I install the batteries correctly in a Stanley TimerMax Daily digital timer (Model #28441)
Battery holder should have + sign.
Then Reset timer.
If new batteries and reset do not restore functionality, then replace timer?
manuals on link below
http://waterheatertimer.org/Woods-timers-and-manuals.html#31217
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 26, 2014 | Hardware & Accessories
Just bought my house and the porch light is controlled by Intermatic timer. Just noticed today that my porch is light is on constant. Replaced the battery in the timer. I was able to set the time and...
Don't forget to reset timer after replacing battery:
Copy following link to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If timer does not function after reset, then buy new timer
EJ500 is rated incandescent bulbs only
Gene
h
Oct 05, 2013 | Intermatic Inc. EJ500C Digital Wall Switch...
WOODS 59018 TIMER WIREING CORRECT INSTALLED WITH POWER OFF NETURAL GROUND UP TO CODE LOAD /LINE PROPER.NEW OUT OF BOX WON'T RESET. STEP 1 LAMPS LOAD SIDE GOOD. RETIRED CONSTRUCTION ELECTRICIAN
I don't have answer for defective timer. Buy another timer if everything below checks out:
59018 7-day timer has limited 1 year warranty, and appears to be made by Tork
Timer is for 120Volt single-pole only.
Rated for 1000 watt tungsten, 8A ballast, 1/4 HP
Push reset button with toothpick > not necessary to press-and-hold other button to accomplish reset.
After reset, 12:00 am Monday should display.
Programs are deleted. Reprogram timer.
To check, change and delete specific programming, press PROG key until selected program displays, and then set new programming >>> or press-and-hold MODE button and press PROG button again to delete selected program.
Timer has non-replaceable 30-day carryover battery and does not lose programming after power outage, and will retain programs until battery is depleted.
Review wiring:
Hot to timer black.
Neutral to timer white.
Load to timer red.
Ground to timer green.
Lights will blink if timer red and timer white are connected to load together.
Timer will not function if timer black and red wires are reversed. Display will not show.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Aug 07, 2011 | Woods InWall 7 Day Digital Programmable...
I have an intermatic switch. Just put a new lightbulb in and when I try to turn the light on, I hear a repeated clicking as (presumably) the power is switched on and off. Have tried replacing battery and...
1) If timer worked before and suddenly stopped working, then reset timer.
2) If this is new installation, timer might be wired incorrectly or timer is defective.
You posted under ST01C timer.
If you have different timer, instructions below will not apply.
To reset ST01C timer, hold down on-off button and press reset with paper clip.
Release reset button.
Keep holding on-off button until INIT displays.
Release on-off button and 12:00 will display.
Reprogram timer
Open following links to see wiring diagrams and download manual for ST01C and EJ500 timers:
http://waterheatertimer.org/ST01C-program.html
http://waterheatertimer.org/Flipdown.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 13, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Flickering bulbs
You posted under EJ500 Intermatic battery-operated timer.
If you have different timer, add a comment.
I have tested EJ500 timer.
A) If this is new single-pole installation and lights click on-off when timer turned on, then you connected red wire where blue wire should be connected.
Manual says for single pole switch:
Timer-black-wire to Hot; Timer-blue-wire to Load (lights)
Here's how to wire timer correctly:
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-blue-wire. Choose either one for now.
3) Put wire nut on red wire.
4) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-blue and timer-black wires.
B) If you are replacing 3-way switch, view wiring diagrams shown on link below, and then add a comment saying exact color of wires. To wire this timer for 3-way can require additional wire between switches. This is because EJ500 blue wire must always go to Load (light, fan, motor)
http://waterheatertimer.org/ST01C-program.html#EJ500-wire
C) If this is older timer that stopped working, check your bulbs. Then check timer battery. Manual says if timer stops working and bulbs are good, and battery good, then reset timer and reprogram. How to reset timer. Press reset button while holding down Next/ON-OFF button.
EJ500 manual has long list of programming instructions: Add a comment if you forgot parts of programming.
EJ500 manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej500c%20-%20english.ashx
Nov 28, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
After using the shave a digital red symbol of the head shows up at the bottom of the shaver. What does this mean? Thanks.
Digital red symbol of the head shows up. It's menas that you should change new replacement heads, that Norelco Arcitec electric shaver replacement heads is Norelco RQ10 shaving heads.
May 21, 2010 | Norelco Arcitec Electric Shaver -...
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
Not turning on
The batteries probably need to be replaced. Be sure that any batteries seat properly and tightly. You may have to tape the battery door shut with strong tape to keep the contact tight. This type of damage is expensive to repair compared to the cost of the cameras. You can take it in and have it looked at, but be sure to get an estimate and then you can make an educated decision on whether to repair or replace it.
Best wishes to you and Thank you for using Fix Ya!
Aug 23, 2008 | HP Photosmart 435 Digital Camera
Sony Cyber-shot DSC-S730 Digital Camera Logo
177 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
