We are on wireless for our printer. The HP L7780 is connected to power, phone cord (using our extra long phone connector as theirs was WAY too short), and a router to print wirelessly. We are a small business office and I can't seem to find any help, manual, directions. I need help!!! Help us receive those faxes. You are the Master
I have a problem that it fails the 'correct type of phone cord' test. It tells me that I need to use the 2 wire phone cord adaptor with my existing phone cord.
I too have a problem with HP7280. I can send faxes but not receive. I am using Cox digital cable phone service and have one phone line for phone and fax with distinctive ring for faxes. HP technical support tried test fax and he himself heard the distinctive rings. He basically ended call saying sorry but HP has problem with incoming digital phone fax signals and he had no solution.
Any ideas for solution with this model? Or do you know of any all in one combos, perhaps another brand that will work with digital signal?
First things first, i really want to know how things being setup in your end. Let say for example, from the walljack what is the device connected to it. Or if your using one line for both incoming calls and faxes. Or if your using a DSL also for that same phone number for faxing/incoming calls.
Those are just severa factors that affect your problems. Meanwhile, i cant give you a solution on your issue since i still dont have a clear picture on are the devices connected with each other. ALso, its really advisable that you need to use the telephone cord that came out with the box.
Thank you so much. I remain.
adonscott
Our fax line is the second line in the hunt so there is a line share device on the line (The Stick). Our phone vendor tried a different line share device but still had the same problems. (1) The fax takes forever (4-6 rings) to pick up even though it's set to 2 rings, (2) when it does work, which is rarely, we might get 1 or 2 faxes then can't receive anything. The sender hears ringing but is eventually disconnected. Both our service provider and phone vendor have been here trying to resolve the issue. If the vendor technician plugs in his test set it does ring when his office sends a test fax. However, if he then plugs the fax in, nothing happens. Any ideas???
