Question about Dell OptiPlex GX620 PC Desktop
GX620 does not turn on
I get a yellow led on the power switch and on the monitor.
The 3rd and 4th led on on.
I've replaced the memory, but still does not turn on.
    Novelist:
  • 145 Answers
Look in the back, there should be 4 lights that will either be green or yellow marked A B C D , see what the code is and look it up, this might tell you whats wrong.
Posted on Aug 01, 2010
I trying to connect my SFC-4160 (security first color ccd camera) the wiring has been cut n there is 5 wires black,red,yellow,white and a bare wire ???? help
Inside the camera is a 4 pin connector connected to the LED Board, with the connector in hand, turn it till you see the pins inside the connector, from left to right wires 1st-white, 2nd-black, 3rd- bare wire or shield, 4th-red, yellow is not connected, the RJ45 end, face the latch away from you, wires are 1st-red, 2nd-white, 3rd-yellow, 4th-shield(bare wire), 5th-black, the LED Board has the wire positioning marked,,,,,
Nov 27, 2012 | Car Audio & Video
HP 17'' L1706 LCD Monitor image shacking
shacking?
well you proved its bad.
a refurb at walfart is $50, about 1 /4th a repair bill.
most the monitors all before magic year 2010 LED year.
all of the now are dead for CCFL back lamps.
1: dim
2: FLASHING JUST LIKE HOME FLORESIENT LAMPS TO.
3: TURNS yellow
4: goes dead, but flash light played on front show data.
5: works not, not next day, repeat,(random)
all do that, ever one, unless your was parked on self for 5 to 10 years.
they all die 20,000 hours (not days , hours)
Feb 28, 2018 | HP Computers & Internet
My pc doesnt load every time I want to turn after i boot the power and press 1st, 2nd, 3rd and 4th boot... in the screen I can see Dell is loading but doesnt move, i try to press F12 for boot and the...
Are you Sure that the computer model is Dell Optiplex GX260? Because looking at the manual diagnostic lights are found at the back. and the fault can be determine If the ABCD lights are yellow or green. But None the less 2/3 Depicts a hard drive problem while 3/4 depicts a memory issue.
Hard drive Issue:
1. Disconnect all non essential cables at the back of the computer. Leave only the mouse, monitor and keyboard. See if it boots up normally
2. If it boot up fine. try plugging one peripheral at a time until you find which peripheral causes the computer not to POST (Power on Self Test)
3. If you still getting problems, Follow these steps
4. To access the BIOS you must tap F2 or delete key upon turning the computer on
5. Try to look for the Hard drive if it is detected by BIOS if not got to step 9
6. Look for Boot Sequence or anything that is associated Boot
7. The Order boot of must be 1st: DVD Drive, 2nd: Hard drive, 3rd: Network etc.
8. Save the changes and Restart
9. If you still get the same message I suggest that you take out the hard drive and put it back in until it is detected in BIOS
10. If Step 9 did not work I think you need to replace the Hard drive
Memory Issue:
1. Open the chassis of the computer
2. Try taking out all memory modules
3. Rub the metal contacts of all memory with a pencil eraser
4. If more than one memory. Put one memory first and turn the computer on. If it turned on add another memory and turn the computer on. Repeat these steps until you determine which memory is faulty or all memory module contacts needs cleaning
Jun 16, 2011 | Dell OptiPlex GX260 PC Desktop
I have a intel 478 board an don`t know how to connect power poer led
The power led wires ( there are two) go onto the two pins on the top row of the front panel coonetcor block on the board, on the 1st and 2nd pins working from left to right.
The full connector block is wired as follows:
top row: left to right >>
1st& 2nd are Power LED, the 3rd & 4th are the power switch, the 5th is empty.
The bottom row: left to right >>
1st & 2nd are hdd light, the 3rd & 4th are the reset switch, the 5th pin has no connector to the pin
Note: the power led and hdd terminals are to produce a light when the pc is on and busy.If the lights do not show, turn off the pc, turn the connectors round 180deg, reconnect and turn back on again. Job done
compdoctor2005@btinternet.com
Dec 10, 2008 | Computers & Internet
Black Screen
Edwards,
What you mean by replaced the fuse? Are you replaced the capacitors on the AC Adapter. If so, Then it's not the only problems. The main problems is the backlight inverter needed to be replaced. Go check out my website @ www.3rd-rocks.com
and click on LCD Parts. If you have any questions just email to to me @ cjt@3rd-rocks.com Have a nice...Happy July 4th!
CJ
Jul 04, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Screen doesn't work properly. Can just see windows loading if hold screen to light. Computer Compaq Presario V2157Ap or V2000 both nos on back of comp
1st test,- connect an outside [test] monitor to the back .There is a VGA plug somewhere back there. If the screen come in good, the problem could be your Laptop monitor screen.
If the connected test monitor acts the same, visually, the problem is in your Laptop.
2nd.test- goto BIOS setup and press F=function that set your laptop to DEFAULT, reboot and see.....
3RD. test- [POWER OFF!!] switch ram chips around from one socket to the other ,, reboot or power on
4th:replace memory chips with KNOWN good ones
If u still have problems, goto technician for help
May 06, 2008 | Computers & Internet
Powerbutton flashing yellow
If the main power button LED is flashing or solid yellow, this could indicate a hardware problem.
Was it running good before?
Are the diagnostic LED lights all green?
Here is what dell says:
If the power light is blinking amber  —
 The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Do you remember what the BSOD said?
Oct 22, 2007 | Dell OptiPlex GX620 PC Desktop
System not booting
if you are only getting a flashing line in the left corner of your monitor you may have a damaged cmos chip, because you should be able to atleast get into the bios, unless you have faulty memory, so if you have two sticks fitted remove one and try again, ensuring you use the correct memory slot.
Aug 31, 2007 | Gigabyte GA-M61P-S3 Motherboard
Dell OptiPlex GX620 PC Desktop Logo
411 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
