Question about Digi-Code Digi Code 5202 Garage Door Opener Keypad 310 MHz Stanley 2986 STAKP Code S
My stanley garage door opener motor runs but it won't open or close my door
    Scholar:
  • 143 Answers
If the motor runs and the chain does not then you have stripped the gears and will need to replace them. If the motor runs, the chain moves but the door does not move then the trolley is not attached or needs to be replaced. Thanks BB
Posted on Sep 05, 2010
  • jamesfehr Jul 30, 2011
    Stripped gears is one of the possible problems. The second is that your gearbox may have broken, which is exactly what happened to me. You may be able to get another if you're inclined to try and fix it.
I NEED THE MANUAL FOR MY STANLEY 8500.51 GARAGE DOOR IT WON'T CLOSE
Try searching around here to find similar or hopefully exact opener. Stanley no longer is in the garage door business, and the company that bought them out went bankrupt.
Good Luck
http://www.teknuw.com/garage-door-opener-installation-manual/stanley/
Feb 23, 2015 | Building Materials
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened fine but now when I try to close it, all I hear is a buzzing sound for 3 sec., light comes on but door won't go down.
Your trolley may be jammed against the bolt just in front of the motor unit. If so, loosen the chain enough to relieve the strain on the chain and then run the opener until the door is closed. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jul 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener (chain) motor runs in reverse. Trolley slides forward trying to close door, even though it is closed, instead of sliding toward motor to open door. Happened out of the blue - was
Loosen the chain enough that you can remove it from the sprocket. Run the opener until the sprocket turns counterclockwise and stops. With the door in the open position replace the chain. You will probably need to adjust your open and close limits per your owners manual.
May 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a stanley garage door opener that won't close the door
the door beams are not working properly. Let me know what you find
Apr 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Digi-Code Digi Code 5202 Garage Door Opener Keypad 310 MHz Stanley 2986 STAKP Code S Logo
538 people viewed this question
Top Digi-Code Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Digi-Code Electrical Supply Expert? Answer questions, earn points and help others
