Question about Lexmark T644 Laser Printer
Que significa 933.00 Service Printhead Error y que solucion tiene
SOURCE: Oxd0620230 reset power
my printer is a hp officejet j5750 all in one, the probem is that I can't scan in it, but I can print, send fax, an make copy in it, so the only problem is the scaner, plese help me
thanks.
Posted on Mar 04, 2009
  • 85 Answers
SOURCE: optra t610 error 935/933/934
replace printhead - scanner assembly. The scanner motor is not working correctly. Need to remove side covers, back of printer assembly, the top cover. Printhead is below the top cover
Posted on Mar 13, 2009
don_farr
  • 1018 Answers
SOURCE: Lexmark T630 has a 933 error. I have replaced the
933 - Mirror Motor - Locks/Lost Hsync* (*Horizontal Sync) Have you gone through this exercise yet: These errors usually indicate a failure in the HYSNC signal to the printhead. Check the continuity of the cables connected to J5 and J4 on the system board. If incorrect, replace the defective cable. The voltage at J4-1 measures approximately +5 V dc. If incorrect, replace the system board. The voltage at J5-7 measures approximately +24 V dc. If incorrect, replace the system board. If correct, replace the printhead assembly. Don
Posted on Jun 07, 2009
  • 628 Answers
SOURCE: Que debo hacer con esto 933.00 Service Printhead
Sorry to inform you that the laser printhead is defective and must be replaced. You will have to take it to a service center for repair.
Posted on Nov 27, 2009
Mike Trivedi
  • 67 Answers
SOURCE: error message 933 service printhead error
f the printer continues to post a 930 Printhead Error, it thinks the wrong printhead unit is installed.
  • If the printer was recently serviced, make sure the correct parts were used. This is especially true if the parts replaced were either the printhead unit or the printer's engine/system board. It is in one of these two parts that the printer is detecting the problem. Note: If you are the person repairing such a printer, please be aware that parts from different, though similar, printer models may not be compatible with this printer. Also make sure to check the laser cable going from the printer's engine board to the printhead unit, as it reads that signal.
  • If the printer was not recently serviced before this error occurred and powering the printer off and on does not help, the printhead unit and possibly the laser cable or the engine/system board to this printer may need to be replaced.
Posted on Mar 03, 2010
Mi impresora HP 5610 tiene encendidas todas las luces marca un errror 0xd05d010d RESET POWER, que puedo hacer.. gracias
SOLUCION: Hola la solucion para la HP Officejet 5610 con ERROR 0xd05d010d es muy sencilla hay que resetear el Equipo lo cual se hace asi:
1. Desconectas el cable que va de la impresora al equipo
2. Luego desconectas el cable de poder de la impresora
3. Mantienes presionadas las teclas (ASTERISCO) * y (NUMERO) # y conectas el cable de poder a la vez.
4. Te sale unas preguntas de Idioma y pais las respondes y LISTO
BUENA SUERTE
Aug 23, 2011 | HP Officejet 5610 All-In-One InkJet...
No puedo entrar a mi pagina de facebook me dise error
Este será un mal español porque estoy utilizando un traductor, pero yo haré lo mejor:) No puede ser muchas cosas mal. Por lo general, reiniciar el equipo va a funcionar,pero si eso no funciona eso significa que hay un problema con facebook, por lo que sólo tiene que esperar a que lo repararan.
Jul 06, 2011 | Facebook Social Network
Tengo un stratus 96 motor 2.4 y lo que le pasa es que me esta gastando mucha gasolina lo lleve a escanear y lo unico que me arrojo fue el codigo p0171 quiero saber si tiene algo que ver y como puedo...
DTC P0171 System Too Lean (Bank 1)
Básicamente esto significa que un sensor de oxígeno en el banco 1 detectó una condición de escasez (cantidad de oxígeno demasiado en el escape). En los motores V6/V8/V10, el Banco 1 es el lado del motor que ha cilindro N º 1. Nota: Este DTC es muy similar al P0174, y de hecho su vehículo puede mostrar tanto los códigos a la vez.
Síntomas: Usted más que probable que no nota ningún problema de conducción, aunque puede haber síntomas como la falta de poder, la detonación (detonaciones), y / o una vacilación / aumento en la aceleración.
Causas: Un código P0171 puede significar que uno o más de los siguientes paso:
  • El MAF (flujo de aire masivo) del sensor está sucio o defectuoso. Nota: El uso de "aceitado" filtros de aire puede causar que el MAF se ensucie si el filtro está más aceitada. También hay un problema con algunos vehículos, si los sensores MAF fuga de la silicona para macetas material utilizado para proteger los circuitos.
  • No puede haber un vacío de fugas de aguas abajo del sensor MAF.
P
osibles soluciones:
Las posibles soluciones incluyen:
  • En la gran mayoría de los casos, sólo tiene que limpiar el sensor MAF hace el truco. Consulte su manual de servicio para su ubicación si necesita ayuda. Me parece que lo mejor es quitarlo y pulverizarla con limpiador de electrónica o limpiador de frenos. Asegúrese de que está cuidado de no dañar el sensor de MAF, y asegúrese de que esté seco antes de volver a instalar
  • Inspeccione todas las mangueras de vacío y PCV, sustituir si es necesario
  • Compruebe si hay un filtro de combustible sucio y la presión del combustible adecuado
Hope helps (espero que esto sea de ayuda, recuerde calificar esto).
Jul 31, 2010 | Dodge Stratus Cars & Trucks
Me presenta mecha error 12 que sera por favor ayuda gracias
mecha error 11 o 12 significa k algo pasa con la cuchilla, debes de desarmar la impresora y ver si hay algo que la este trabando
Jul 09, 2010 | Kodak 6800 Thermal Photo Printer
Check engine que significa ese icono
El icono del motor del cheque significa simplemente que el ordenador del coche ha identificado un problema en alguna parte dentro de uno de los muchos sistemas del coche. Para saber exactamente por qué de que la luz del motor del cheque llegó el tienes que tener el ordenador del coche escaneada. Conduce a la mayoría de cualquier tienda de piezas de automóviles o AAMCO y que van a hacer el análisis de forma gratuita. A continuación, le dirá lo que su equipo es informar a usted como un problema. Regards, Joe
PS favor y amablemente tasa de mi respuesta. Gracias.
Jan 21, 2010 | 1995 Jeep Grand Cherokee
Que debo hacer con esto 933.00 Service Printhead Error. Actualmente tiene los drivers segun S.O ¡help me!
Nov 27, 2009 | Lexmark T644 Laser Printer
No prende ya mi monitor
Hola, Su monitor tine un problema de unidad de fuent la luz O la connector de VGA tiene unas pins dentro la connector danados.
1. puede chkar los pins
2. comprar una unidad fuente da luz
Si su monitor tiene una garentia por fabrica yo recomendar usted llamar esta fabrica para un reperacion.
Disculpe yo no puede escribe moy buen in espano espero que usted si entiendan.
Por favor vota moy bien para esta solucion si usted encauntra the solucion si ayunden.
Gracis
Atte Rulds2008 - GURU
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 24, 2009 | Princeton Digital VL2018W Monitor
Que significa el error 0X4001100200001005 en una restauracion de
Acabo de recibir el mismo mensaje de error en mitad de una restauracion de pc. La solucion en mi caso:
1) Desonectar el cable de alimentacion y encender el pc para que se descargue de toda corriente, volver a conectar la alimentacion.
2) Limpiar el CD de restauracion (con el CD sucio no lee y da error) e introducirlo en la bandeja CD/DVD
3) Encender el pc y enseguida oprimir F12 para que arranque con CD/DVD
4) Esperar que eso lo solucione
Jul 06, 2009 | E-Machines (T2958) PC Desktop
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
Lexmark T644 Laser Printer Logo
914 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
