Question about Garden
Have a Phoenix LP Grill Model PG2001P and am looking to convert to NG. The old part # was GRL00066 for the ng conversion kit. Any idea where I may find it? Or any idea what size the NG orifice is?
SOURCE: how to convert from lp to ng
Yes,
I converted a Sam's Club Members Mark grille last year and just did some research on the internet and found a numbered drill size chart that gave me the correct drill size to use on each burner(side,main and rear)for the proper BTU supply for the size or BTU rating for your burner. I drilled them, All has worked well! I know Ducane will tell you not to do that, but I think it is a legal issue. If you have a problem, they don't to get a letter from your lawyer.
Posted on May 13, 2008
AlmostBob
  • 550 Answers
SOURCE: Converting LP to NG
The install manual on the dacor web site insists that Natural Gas requires the nozzles be removed, that low pressure NG works with the large 'default size nozzles'. Have done the conversion, in Australia, for my own barbecue, worked ok
Gas is too dangerous to make mistakes with. All I can suggest if Dacor is difficult is take the pdf of the installation instructions, link in the first replies, and the barbecue to a local gasfitter/plumber and ask them to work on it. they will be able to do the calculations from the existing nozzle size, lpg pressure, ng pressure, and required BTU output, to put in correctr nozzles
Dacor Australia are much easier to deal with.
(Now res in Canada,)
Bob
Posted on Aug 08, 2008
redbeard00
  • 957 Answers
SOURCE: Can I convert my MDBQ-30 NG grill to LP Gas
yesL contact your local propain provider and/or plumbing supply Co. They need to see the valve and they will let you if they can convert it or not. If not they will sell you an L.P. style valve.
Posted on Apr 25, 2009
SOURCE: Conversion kit or fix for LP to NG for the Char-Griller
I removed the jets and drilled them out, #54 is what I started with and then moved up from there to get a good flame( gas pressure may be diffrent in your area). I went to lowes and purchased the universal gas line for grills. Item #: 206469 from lowes, I removed the hoses from the valves, and proceeded to remove the regulator from the hose. After that, i used a 1/4" npt coupling, and a 1/4/" NPT to 3/8" Flare fitting( fits to hose). I drilled a hole in the brace that is under the clamshell(it says UP) that way I had a place to relive stress from the hoses. I threaded the Coupler to the Y then threaded the Flare fitting thru the sheet metal and then the coupling. This was an easy mod minus the garage in disarray, my precision calipers on loan, and 3 trips to the hardware store. The connection that goes to the house is a 3/8" NPT Female, my house has 1/2" pipe, The one wasted trip to the store is because i didnt bring the fitting with me to the store and assumed the size was 1/2 to 3/4(Rookie Mistake). 46e03a6.jpg846ce6e.jpgb1bb7d1.jpg
It was 35 degrees when I finished this mod, and on high for all 3 burners, I got it to 675F in a hurry. the needle was still creepin up, but that is when I said that was good enough for me.
I used my lathe to drill out the jets, ksware is correct with how easy the jets break. I broke the one in the side burner. I will make another one when I get an hour or two. Good luck to you and happy grilling.
Little Elm, Tx.
Posted on Jan 03, 2010
SOURCE: I'm trying to convert to
Tne 720-0677 that I purchased came with a NG conversion kit and has all the pieces needed. Try here and maybe this will help
http://www.shopnexgrill.com/category/nexgrill
Posted on Aug 22, 2010
Need to convert jenn air grill from NG to LP. model 720-0138
Most gas supply companies have the jets and the knowledge to change the regulator etc.
Nov 19, 2014 | Grilling
Admiral dryer
Who did the conversion to lp? Do you have the old part from the conversion still? If not you can order a kit to put it back to stock which is ng. Not hard for a guy that's handy but time consuming. 2-2.5hrs.
Feb 08, 2014 | LG DLG7188 Gas Dryer
Convert gas grill natural
ducane will not make these available anymore because the ducane family no longer owns the company and the models since 2007 are all made in china with poor quality controls. conversions are simple but the parts will not come through ducane or weber. replace the orifice in the tip of every control valve and replace the regulator. that is the only difference in fuel types.
Oct 15, 2013 | Ducane 30400042 (LP)
WE HAVE A BRINKMAN GRILL AND BOUGHT THE LP TO NG CONVERSION KIT THAT IS RECOMMENDED FOR THIS GRILL ...KIT HAS TOTAL OF 6 ORFICES AND THE GRILL IS A 5 BURNER, WITH SEAR AND SIDE GRILL SO THAT MAKES 7..NOT...
Some Brinkman grills have the LP orifice installed on the NG orifice directly from the factory.
If that is true, you remove the LP orifice and the NG orifice is already there. Check instructions in the conversion kit and look for this detail carefully. I just did a Brinkman conversion and instructions were very confusing. The orifices in the kit are not used (on my unit).
Gary
Aug 21, 2011 | Garden
I have a Weber Silver B grill that I purchased 12 years ago.I would like to convert it from propane to Natural Gas. I have been told I cant! Is this true? If not, where can I get a conversion kit? Thanks!
Weber stopped selling conversion kits due to some legal action in 2008. There are no longer kits available. What you would have to do to covert it is order a replacement gas valve for the NG version of your grill just to get the orifices. Then you have to replace the LP regulator with a NG regulator. Typically most NG grills do NOT have a regulator but local building codes will require a NG regulator and a different gas line hose.
Conversion of a BBQ gas valve to NG is a matter of drilling out the orifice to a larger hole in an LP orifice.
You will not find anyone that will perform this conversion for you due to legal liabilites.
If you want to convert it... you will either have to order the whole gas control valve for NG or drill out the orifices yourself in your current gas valve hoping your got the orifice hole size correct when you drilled it. Mind you all liability for doing this lies solely with you.
This site has all weber parts:
http://www.clagrills.com/allgrillparts/weber/weber-models.htm
http://www.clagrills.com/gasgrillparts/weber/weber-gas-grill-parts-home.htm
Thanks for choosing FixYa,
Kelly
Apr 29, 2011 | Weber Genesis Silver B Grill
HOW DO I CONVERT FROM LP TO NATURAL?
Weber does not sell a conversion kit. They wont sell due to liability reasons. But to answer your question you need to change all the burners, controls, and you will need to remove regulator and replace with hose to ng outlet. NG has a regulator where NG is attached to house..
Jun 02, 2010 | Weber Genesis Silver C Grill
Where can i find conversion kit for weber platinum series going from LP to NG
Weber does not sell conversion kits. They sell either lp or ng grills. They say the liability is to high to have someone convert grill. No parts available have to buy new grill.
Mar 21, 2010 | Brinkmann ProSeries 810-6330-W Grill
Conversion kit for Weber Summit LP to Natural Gas
Hi, you can purchase your kit at amazon, click here and take a look: Amazon com weber grill conversion kit to natural gas. I hope this was helpful. Cheers
May 31, 2009 | Weber S-420 (NG)
How to convert from lp to ng
Yes,
May 01, 2008 | Ducane 30400042 (LP)
Converting a Cabana Kitchens CNA 480 from NG to LP
go back to place of purchase they will have a kit
Dec 30, 2007 | Cabana Kitchens CNA480 (NG) Grill
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
