When i turn on my pc i hear a noise but in my screen i don't see nothing
  • 396 Answers
Do you see any activity from the hard drive lights or do you hear a single beep from the computer speaker? If yes do you have an flat screen or a CRT monitor and do you have a power on LED illuminated on the monitor? Can you see any output accessing the menu mode of the monitor? If yes check your cable from the monitor to video card to make sure it is plugged in. If no it could be your monitor or video card and you will need to test the monitor on another system. If you press the power key once for a second will the computer immediately shut off? if yes the problem could be the mother board or power supply. You need to test the power supply if it is good suspect mother board or CPU. If the system shuts down within a minute then test the video card.
Posted on Jul 27, 2010
  • 75 Answers
If you do not see anything,that means there is issue with your motherboard and you need to get it replaced.
once it is replaced.everything will be great as before
thanks
Stacking and also i hear a shhh..hhhhhh sound from the hard disk
It depends on the type of noise, the source of the noise, your brain's reaction to the noise, and your ability, or lack thereof, to tune out a noise that can break your focus.
I work in a cube farm next to three other programmers. The cube walls are low, and offer no barrier at all to noise. One worker occasionally has outbursts where he either becomes excited or agitated and semi-yells at his screen. It's not that frequent, and though I'm over-sensitive, I can deal with it.
Another co-worker, while she has a softer voice than the agitated one, likes to softly talk to herself as she works on a problem. When she pronounces "s" or soft "c" words, the sound is similar to a squeaking chipmunk. I have good hearing, am only 5 feet away from her head, and the other guys don't even notice (at least one has poor hearing).
To me, the "s" sounds this coworker makes are like nails on a chalkboard. What's more, the noise is un-predictable, because she goes through stretches where she doesn't talk to herself at all. When she does start talking, it's pretty much impossible to have consistent focus.
What's funny/sad, too, is if I try to be subtle and say "Shhhhhhhhh...", she doesn't hear me, because her hearing isn't great.
The situation is very awkward: I don't want to tell her directly to be quiet, because her whole modus operandi seems to be based on talking to herself, and she might take serious offense. And this, in turn, makes the noise even more frustrating - kink of like your fingers getting stuck in a Chinese finger trap. So I guess that means I better find a quiet cube in a different location, or find a work environment where noise is not an issue (if there even is such a thing).
If you read this and you are one who talks to yourself, take a moment to consider your coworkers!
Aftermarket Car Headlights
Jun 11, 2012 | Acer Aspire 5742 Notebook
Hi I have Lenovo 3000 n200. When I try to turn it on I hear fan noise, DvD burner works, dark screen, nothing shows on screen and after that everything is silent. I did hard reset etc but no use. I...
On the back of the laptop there should be a compartment.Open it a find the RAM sticks.If you have 2 sticks,remove one and try to run it with only one and repeat the same process with the other stick.If you have an extra RAM please insert a it and run the laptop.
May 03, 2012 | Lenovo 3000 N200 PC Notebook
It does not start n displays nothing on the screen
if you cannot hear any fan noise when you start your desktop,that means you need to change your power supply ,if you can fear your fan noise but cannot see anything on screen then there can be issue with your motherboard,you will have to get it replaced
Sep 13, 2010 | Dell OptiPlex GX520n PC Desktop
When I turn the key in the ignition I don't hear anything and my car won't start. I tested the started and it is fine. I replaced the ignition switch. Could it be my alternator or my neutral safety switch...
no. the noise you're not hearing is the fuel pump. When u turn ur key on you should hear a buzzing like sound from the rear of the vehicle. If not, and ur car don' start, probably fuel pump. Just to verify the faulty fuel pump, have an assistant open the fuel tank cover and remove the gas cap itself. With you inside turn just the key on, and have your assistant listen for the "buzzing" or "hummin" sound. if nothing there, then faulty fuel pump. If noise is present, then perhaps you have a different problem like nothing is reaching the engine, fuel wise. Like a plugged fuel filter. when replacing the fuel pump, ALWAYS do the new strainer as installing the old one could cause a whole new set of problems and eventually wipe out the new one as well *RULE OF THUMB, WITH NEW FUEL PUMP, REPLACE FUEL FITLER.* this will be easier on the pump output to the engine. good luck.!
Aug 24, 2010 | 1994 Jeep Grand Cherokee
Newer HP Pavilion dv6000 turned off while in use and wont turn on
1.Start your computer and see if your hear your fan noise,and cannot see anything on screen then there is problem with your power supply.
2.If you cannot hear your fan noise,and do not see anything on screen,then there is problem with your motherboard
3.if you hear fan noise and can see something on screen,then it is the issue with your hard disk (very less cases)
Mostly it would be the 2nd case that you will have to get your motherboard replaced
Jul 27, 2010 | HP Pavilion dv6000z Notebook
No power light when on but can hear running, no screen image
First make sure the monitor is on and connected to the PC.
If the power light is not on you could have a bad power supply, it could also be that the onboard video went bad.
If your PC has four trouble lights in the back, let us know which ones are lit, this can pinpoint the problem.
The noise you hear is the drive spinning up and the CPU fan.
Good Luck.
Feb 22, 2009 | Dell Dimension 3000 PC Desktop
I can hear other people, but they can not hear me. Worked before?
go to the sound icon on the lower right of your screen and make sure the mic is not muted... you may have to look in the menu for additional controls.
Robert
Please take a moment to rate this solution thanks
Jan 26, 2009 | Logitech QuickCam Pro 5000 Webcam
Computers & Internet Logo
56 people viewed this question
Alun Cox
David Payne
David Payne
