Question about Dryers
How to hook the drive belt to the pulley and the motor
    President:
  • 3,773 Answers
Double the belt above the idler and push the doubled part through
the idler and over the motor pulley.
Leo Ponder
imufo2@sbcglobal.net
Posted on Jul 29, 2010
Repair a belt on a washing machine for a speedqueen
Remove the front panel by removing the three screws at the bottom of the panel and then tilting it up to unhook it at the top. Make sure the machine is disconnected from the electrical power - not just switched off but unplugged at the socket. Look for the belt between the electric motor and the main drive pulley of the agitator and also locate the belt tensioner which is a small pulley pressing against the belt under tension of a spring hook onto it. Pull and keep the tensioner away by hand to allow the removal of the belt starting at the motor pulley. Replace with the new belt by starting at the agitator pulley. Keep the tensioner pulley out of the way until the belt is fitted on both pulleys and then allow it to settle against the belt again. Do not adjust the spring tension and buy the correct belt from speed queen as it requires a graphite type belt. An ordinary vehicle v-belt will not work - repeat will not work. Replace the cover by hooking it in first at the top and then replacing the screws at the bottom.
Oct 19, 2014 | Speed Queen Clothes Washer Agitate & Spin...
Teac schematic
To replace a drive belt.
Before starting unplug from mains power source.
1, Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
Job done.
Stylus city
Jul 03, 2014 | Teac Audio Players & Recorders
TROMM WM2277HW Front loader washer has an increasing louder spin cycle.
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 12, 2014 | LG WM-1832C Front Load Washer
Need Instructions to replace belt on panasonic SL-5N Turntable
To replace a turntable drive belt.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the center spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
7. Align the center hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
Job done.
Apr 11, 2013 | Audio Players & Recorders
Knocking noise when printing
Check the following:
1. DC motor assembly.
Make sure all the motor plate mounting screws are tight.
2. Idler pulley - DC motor assembly.
Make sure the idler pulley is not binding on the pulley shaft. Check the pulley for wear. Check the idler pulley shaft on the motor mounting plate for damage or contamination.
3. Drive pulley.
Check the drive pulley for wear, binds or damage to the pulley or pulley shaft. Make sure the pulley turns freely on the pulley shaft.
4. Motor drive belt - tray drive belt.
Check the DC motor drive belt for damage. Make sure the belt is tracking correctly on the drive pulley, idler pulley, and motor pulley. Check the tray drive belt for damage. Make sure the belt is tracking correctly on
Dec 11, 2012 | Lexmark X646e Laser Printer
No spin agitate or drain just motor noise
The noise coming from the motor means it is running but cannot drive the drive pulley and the pump pulley because the drive belt is either broken or has slipped off. The drive pulley and the pump are driven by a single belt. Replace the drive belt if broken or loose and has slipped off. Disconnect power then drain the water manually by placing the end of the drain hose into a bucket or a shallow basin. Position the bucket/basin as low as possible to extract as much water from the tub. Once drained, lay the machine on its back to access the belt under the machine. When replacing the belt, wrap it on the motor and the pump pulleys then on the drive pulley. Turn the drive pulley in such a way that the belt wraps around the motor pulley, pump pulley, and the drive pulley.
Nov 11, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I am assembling a sony turntable and don't understand step 3. Using the ribbon, loop the drive belt around the motor pulley. PS-LX300USB model Thanks
Manuals and belt instructions here:
http://esupport.sony.com/US/perl/model-home.pl?mdl=PSLX300USB&LOC=3
You would handle the belt by the ribbon instead of bare fingers so your finger oils wouldn't contaminate the belt. You stretch the loop of the belt over the drive pulley between the flanges to hook it.
Nov 07, 2010 | Sony PS-LX300USB Turntable
I have a engine on my sawbench which is rated at 3000 r.p,m thepulley on the output is 6 ins .what size pulley do i need on the saw to make it turn at 800 r.p.m.
The RPM's of the motor x the size of the pulley (3000rpm x 6inchs = 18000) = the output RPM's of the drive x the size of the pulley (in this case 800rpm x D ) Diameter would = 22.5 inchs.
Basically:
3000 X 6 / 800 = 22.5
You will have to change the pulley size on the motor to a smaller pulley. A 2" pulley on your motor would require a 7.5" pulley on your drive. Or you could use two belts to reduce the size of the pulleys even more. If you halve the RPMs to 1600 first from the 2" pulley you would need a 3.75" pulley followed by another belt hooked up to a 4" pulley to get your 800rpm. Hope this helps.
Oct 01, 2009 | Saws
Belt is off my audio-technica turntable at-pl50
WASH YOUR HANDS FIRST! Any oils on the drive belt may cause slippage.
This is from the manual:
A) Remove the record mat from the turntable platter
(Fig. 10a). Through an opening in the
turntable platter, visually inspect to see if the drive belt
is around the motor pulley (Fig. 10b).
B) If the drive belt is not around the motor pulley: Lift
and remove the turntable. Place a thumb into each of
the left and right openings on the turntable platter; and,
using the fingers to press down on the turntable housing’s
surface, pull the platter straight up (Fig. 10c).
Avoid pressing on the tone arm.
C) With the turntable platter bottom side up, place the
belt along the outside wall of the turntable platter's
drive rim, making certain that the belt is smooth and
flat all the way around (Fig. 10d).
D) Put the turntable back on the center spindle, make
certain it is fully seated, and align one of its openings
over the motor pulley position.
E) Through the opening, carefully hook the turntable
belt with a finger or with the original red ribbon (never
use a sharp object) and pull the belt over the motor
pulley (Fig. 10e). Make certain the belt is not twisted
between the pulley and the platter’s drive rim.
F) Put the record mat back on the platter.
G) While holding the tone arm in its rest position,
slowly turn the platter by hand clockwise at least 10
rotations to clear the mechanism’s automatic cycle.
Apr 24, 2009 | Audio Technica AT-PL50 Turntable
Replacing belt on washing machine
Hi!
Welcome to Fixya,
in replacing a belt please follow this step:
  • turn off and unplug your washer.
  • hook the belt first in drive motor pulley. ( a slot where your belt take place on top of the motor and sure that the belt is in place firmly to the slot of the pulley.)
  • start to hook the other end/loop of the belt to the tub pulley in one side of the pulley (it is more efficient in starting to hook the belt from inside to outside rotation.)
  • and hold the belt and rotate inside the pulley of the tub slowly
  • dont let the belt slip outside the slot of the pulley hold it firmly with your hands
  • hold the belt, clip to the slot of the pulley
  • but don't hold the belt alone or don't hold the belt in between of the pulley.
  • hold the belt inside the slot of the pulley in the tub pulley and rotate slowly. until it fix to the slot of the tub pulley.
If you need further assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
aclamonte
Dec 09, 2008 | Washing Machines
Dryers Logo
Top Dryers Experts
Marvin
Marvin
