I had to unplug my d link wireless router from my modem and now that I have reconnected it I cannot access the internet. Please help!!
  • glenon Jul 27, 2010
    Its a wireless router so nothing is connected to my computer. The modem is working fine, the d link has a powercord and the blue ethernet cable is in the wan port and the modem. What did I do wrong?
  • 1,555 Answers
The settings on your dlink wireless router has washed out. You must have disconnected it for more than 5 minutes. Now there is no IP on that router No subnet mask. On DHCP you cannot connect wireless. To get an accurate response kindly do let me know your internet provider alongwith you location and whether the connection is broadband or something else you modem make and model your routers make and model.
Posted on Jul 27, 2010
  • 472 Answers
  • make sure you have the cables connected into correct ports. The correct connection should be as follows : modem should connect into the internet port on the router and then cable from LAN port of the router to the computer.
  • After you have them connected properly, disconnect power cable from your modem and the router and then turn off your computer.
  • connect power cord to the modem first, wait for 15 seconds, then connect your router and turn your computer back on.
  • if everything works fine then you should be able to go online but make sure that you have a DSL light blinking on your modem.
Good Luck!
My router won't give me internet access?
IF you have a Modem and a Router & you have the cables on both hooked up right just unplug the Modem for 1 min and replug it back in and after that unplug the Router for 1 min and replug it back in and they should auto detect or set up and they should work.
Jul 30, 2014 | Zonet ZSR4154WE 80211N Wireless Broadband...
Wlan light keeps coming on and off internet connection is unstable
wlan light going on and off is normal that means that there is activity between router and wireless device (computer, smartphone, etc) If you have intermitternt connectivity try this. Unplug router from power, then internet modem from power as well, wait about 30 seconds, reconnect modem, wait about a minute and lastly reconnect router. If this does not solve the issue you may want to call your internet service provider.
Rob.
Please rate. Thanks.
Mar 04, 2011 | Linksys Wireless-G WRT54G Router
My acer aspire one wont connect to internet. it says it is connected to wireless, and i have wired it to modem but the problem still persists. please help.
Based on your description, the following is assumed.
1. The service to your Internet Service Provider is through a cable or DSL modem.
2. Internet service was initially set-up with your netbook directly connected to the modem.
3. A wireless router was since added and is using the direct wired connection to the modem.
4. The netbook is connected to the wireless access point being provided by the router.
5. The netbook says it is connected to the wireless access point but still no internet access.
The problem is likely due to the modem capturing the MAC address of the netbook when access to the internet servce was initially set up using the netbook directly connected to the modem and now the modem will only allow access with the netbook directly connected to it. You can check this out by reconnecting the netbook directly to the modem. It may be possible to "flush" the captured MAC by unplugging the AC power to the modem, waiting a few minutes and then powering back up with the router connected in place of the netbook. To make it easier, you may want connect your netbook directly to the router's LAN side to check if you now have internet access through the router. If you still don't have internet access, you will need to use your netbook to log onto the router to clone your netbook's MAC address for the router's WAN connection. The router's user guide/manual has directions on logging in and doing the MAC address clone. It will also have an explanation as to what is a MAC address.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have a d-link extreme g attached to a cable modem; the d-link is set for wirless. I can pick up the d-link on my ipod and laptop, however it only provides local access; no internet. I've tried everything...
I'm sure you have tried most of these steps but I'm going to list them any way so we have a complete picture of the trouble shooting process.
If your only getting local access that indicates that the router is broadcasting the wireless signal but unfortunately there is a connection issue between either the modem and router or the modem and the internet service provider. The first step is to verify that your modem is online with a good connection. If you have a working internet based phone than your in good shape. If not than you will need to research the light patterns of your modem or bypass the router to determine weather or not you have a connection to the ISP. The first step in trouble shooting a connection issue between the modem and router is to disconnect the Ethernet cable from the modem and the router than reconnect it. Make sure that the cable is connected to the correct ports. Next you will want to power cycle the computer, modem, and router. To do this you will need to shout down the computer and disconnect the power cables from both the modem and router. Allow all devices to remain off for 2 minutes. Plug the modem in first. Wait for the modem to establish a connection with the internet service provider(ISP). Depending on the type of modem this can take up to 5 minutes. After a connection to the ISP has been made reconnect the power to the router. Wait about another 2 minutes for the router to establish a connection with the modem then turn on the computers in the home. From this point you will need to retest.
If you still only have local access than there is a good chance there is an issue this either the Ethernet port on the modem or router. To trouble shoot the Ethernet port on the modem you can bypass the router and power cycle the modem and PC again. If the PC has no access wile directly connect to the modem than there is an issue with the modem and will need to be replaced. The good news is that most internet service providers will replace the modem for free. If all the trouble shooting steps above have failed than you will need to contact the router manufacture directly.
I hope that information above has helped is some way.
If possible please rate this solution.
Sep 01, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
My email is glenon@romprop.com I had to unplug my d link wireless router from my modem to move my desk and now that I have reconnected it I cannot access the internet. Signal is strong but no internet...
Hi, you shold recheck the network cable from the MODEM is correctly connected to the WAN or INTERNET port on the router, also try turning off and of the modem and then the router. I hope it helps.
Jul 27, 2010 | D-Link Air DWL 520 802.11b (DWL-520)...
Its just not working. there's a red dot on the router. please help
Reset your router to factory defaults.
For that press RESET button for 10 seconds it is in back panel of router.
hen connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Also change channel type in wireless option 4,6 and 11 channel are best.
Try 1 by 1 then save settings and restart router.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | D-Link AirPlus DI-524 Wireless Router
D-Link DIR 655 - DHCP server but no internet
This usually happens when the router has timed out trying to grab an IP address from your modem.
I suggest unplugging your router and modem, waiting 1 minute, plugging in your modem, wait 1 minute, plug in your router, wait 1 minute, then try to connect again.
If this solution has helped you, please take the time to rate me.
Oct 04, 2009 | D-Link DIR-655 Wireless Router
How do i reconnect linksys
Oh man your going to have to help me out a little on this one. Do you mean you had to unhook it and connect directly to the modem and now you want to hook the router back up? If thats the case Unplug all the devices (Pc's modem and router) connect an Ethernet cable from the ethernet port on the back of the modem (not the linksys) to the internet ethernet port on the linksys (usually set a little apart from the rest) then connect all the computers to the routers ethernet ports (usually labeled 1-4) then turn on power to the devices starting with the modem, wait for it to completely boot up all the lights like they're supossed to look. Then turn on the router and wait for that to finish booting up then all of the computers. If you have wireless devices that will take a little more help.
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
L2TP connection problem
Hello, I've had the electric cut off and immediately back on and I lost my connection from Wireless router to modem. I could not connect in the same way. I could access the router settings with wireless laptop and PC but not to internet on either. I bypassed the router and connected the PC computer to modem then to internet verifying with a browser. I then reconnected the computer cable back to router and router to modem. It stayed connected. But I'm not sure if you have a PC connected to the router also. Sometimes just unplugging some cables and replugging will solve problems. Hope this helps.
Feb 18, 2008 | D-Link AirPlus DI-524 Wireless Router
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
