Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
Ceiling fan won't spin - Light works fine!
Have 2 identical ceiling fans in bedroom. both run from one double switch. One fan will not spin but the light will come on fine. Just put brand new motor in with no change. Thanks for any inputs, -M
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
Pranavendra
  • 16 Answers
SOURCE: 42" ceiling fan
1. Try to rotate it by free hand and see it is free machanically. If not, it ball-bearing/bush should require lubrication or replacement.(Note at this satage there should be no electric supply to fan.)
2.If it is free, rotate it fast by hand, then immediately switch it on.
a)If it continue to rotate, then there is fault in capacitor.Replace it.
b)If not, ask me.
Posted on Nov 29, 2007
shaggyrat
  • 1224 Answers
SOURCE: ceiling fan motor locked up
replace ceiling fan motors will lock up its called normal wear
recommendation for a good strong long lasting ceiling fan
hampton bay
or hunter
my father put up fans some 16 years ago and still running strong
Posted on Jun 08, 2008
  • 70 Answers
SOURCE: Ceiling Fan only spins 1 speed
assuming you havent messed about with the wireing it can only be the pull cord switch fault or the motor is on its way out
Posted on Jul 25, 2008
  • 10 Answers
SOURCE: Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Posted on Oct 24, 2008
Why Ceiling Fan Fixture does not work
You get what you pay for! Shouldn't buy a store brand.
Jul 14, 2014 | Hunter 52" Ceiling Fan With Light And...
Why my Hunter Ceiling Fan does not work?
Its unlikely that the fan is on a separate feed from the breaker box than the rest of the outlets in your room but you never know. It would not hurt to check all of your breakers. If the fan and its light are controlled by the same wall switch then the wall switch may have went bad. Within the fan there are separate wires for the fan and the light so both of them would not go out at the same time. It makes more sense that the problem is at your wall switch.
Jul 14, 2014 | Hunter 25872 Sojourn II Brushed Chrome...
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
I understand that the black and blue wire can be connected to the black wire in my ceiling. ok fair enough. However, in my new bedroom, there is 2 switches on the wall that apparently control two black...
A ceiling fan requires a neutral wire (white), a ground wire (green), a hot wire for the fan (black), and on fans with light kits a hot wire for the lights (blue). These examples will assume that a lighting kit is going to be used, but if it is not terminations to the blue wire are not required and the circuit is greatly simplified The ceiling fan and light can also be wired through switches. When a single switch is used to connect to the ceiling fan and light the ceiling fan (black) and light (blue) would both be connected to the switched black wire. In this configuration turning the switch on would power both the light and ceiling fan. In order to turn just one off, the pull strings would have to be used. The problem with this approach, is that when the pull strings have been used to turn the light or ceiling fan off, turning the switch back on will not work until the pull string is pulled again .
The ceiling fan and light can also be wired through two switches. This would generally be two separate switches, one for the fan and one for the light. This would generally be a 3 conductor w/ground coming from the switch box. The ceiling fan (black) wire would connect to the switched black wire from the ceiling fan switch, the light wire (blue) would connect to the switched red wire from the light switch and the neutral (white) and ground (bare) would connect to the their associated wires..
Jul 07, 2011 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
I have a single pole switch that currently controls a bedroom outlet. i am installing a fan and light in the bedroom. i have a new triple switch that i want to control the existing outlet, the fan and the...
Wiring is not fully described: Location of hot wire and neutral wire from breaker box are unknown.
If Hot wire arrives in ceiling box first, the switch box will not have white neutral wires that are twisted together and covered with wire nut. Neutrals will be in ceiling box.
What is known: You are replacing single pole switch attached to one 14-2 wire going to light.
You are replacing light with a fan-light and replacing switch with a 3-pole TM8111 switch.
You have replaced 14-2 wire with 12-3 wire.
TM8111 wiring shows following link:
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Fan pull-chain wiring shows following link:
http://waterheatertimer.org/images/Fan-motor-1-344.jpg
Assume neutrals in ceiling box.
Assume Hot wire in ceiling box: Connect 12-3 black wire to black Hot wire. Connect 12-3 white wire to black wire on light. Connect 12-3 red to red wire on fan.
White neutral from fan and white neutral form light connect to other white neutral wires and covered with wire nut.
Wiring at switch:
Black Hot wire from ceiling box connects to A COM terminal.
White wire to ceiling light connects to A SP2
Red wire to fan connects to A SP1
Jun 21, 2011 | Pass & Seymour Legrand TM8111 Three Single...
My ceiling fan is spinning in the WRONG direction. I know because I have an identical fan spinning in the right direction. How do I get my fan to spin in the right direction? It has been doing this ever...
shut it off, an get up there and see if it has a directional switch, to make it go forward or back wards. also be sure the blades are not upside down on fan motor. the reverse switch should be on the fan motor housing so it can be reversed.
Sep 09, 2010 | Hampton Bay 52 In. White Redington...
We have 2 Hunter ceiling fans with remotes. We can get the one in the bedroom to work great but the one in the living room now will not turn on the fan or light. Also when we are trying to get the living...
The remote might have wrong orders. Get the battery out and insert it back and see if the problem solved.
Do you set the dip switchs correctly on the fan and on the remote? Numbers set must be matched. Otherwise, the fan won't work either.
Aug 11, 2009 | Hunter 52" Ceiling Fan With Light And...
Motor Hum
check your grounds and all other connections. remote wiring has to be precise. somes times not for the do it your selfer. all the labor youve encountered somes the cheap can turn out to be very expensive.
Apr 26, 2009 | Hunter 52" Ceiling Fan With Light And...
My home is pre wired for a ceiling fan in the master bedroom. There are two light switches that control the pre installed wires. One for the light on the fan and one for the fan. There are four wires
The usual wiruing for these fan/light circuits is that the black wire on one switch is for the fan and the red on the other switch is for the light. If you are using a remote set up for both fan and light, then hook the remote wires to the black and white wires in the ceiling, You can cap off the red wire in the ceiling as this will not be used.
Apr 24, 2009 | Hampton Bay 24002 Ceiling Fan
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
347 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
