Question about Home
My bathtube jets don't work but there is a hum when I turn it on.
There is not output on the jsets but my motor is humming.
    Problem Solver:
  • 9 Answers
1. Is the tub filled with water?
2. Has it worked in the past?
3. Is the Intake Blocked?
There is often a turn knob for the speed of the recirculated water.
It may be valved down all the way
Posted on Jul 28, 2010
My jets are humming In the lasco luxury bathware how do I fix
The humming suggests that the pump is running but something is clogging it. You will have get access to the pump and probably do some disassembly to isolate the cause and correct it.
Jan 26, 2015 | Home
Whirlpool only hums
Motor is either seized or something is stuck in the pump.
Oct 19, 2014 | Eljer Home
Pump hums but nothing happens
Sounds like the pump impeller is stuck. Shut off the power and check to see if the pump has a small round cover on the end opposite from the pump. Some pump motors have a slotted shaft that you can insert a screw driver and manually turn back and forth to loosen the stuck impeller otherwise drain the tub and remove the pump to access the impeller and attempt to free it.
Hope this helps.
Bob
Jun 01, 2014 | Crane & Co Crane Plumbing 2430W Whirlpool...
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
No access hatch in tub when i press power buton it hums but no water from the jets no way to check moter or any other componet
If the motor is just humming when you press on the button to turn on the tub then you have a bad motor and it will need to be replaced
Feb 08, 2011 | Home
Pushed button to turn on whirlpool - hear motor - jets don't work
if the motor just hummed then it is likely a bad motor. you will need to replace the pump at that point. Bathtub buttons like the one you have either works or they do not. there isn't any in between areas.
May 31, 2010 | American Standard Cadet Corner Bathtub -...
Jetted bath tub has stopped working. Motor hums
look on the back of the motor there should be a shaft that you can try to turn to spin free because something inside the pump is blocking it. rate me if this is helpful.
Feb 15, 2010 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
American standard air tub motor hums
sounds like the motor might be on a dead spot. try turning the shaft of the motor 1/2 turn or so and see if it will kick in. If not you may have a bad motor of some debris in the motor preventing it from starting.
Jan 01, 2009 | Home
Home Logo
218 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
