  • 101 Answers
The drain valve is bad, replace it. hope this information could help you.
Posted on Apr 23, 2008
My ariston av61 washing machine is not draining and there is no obvious opening to drain it.
to drain a washing machine simply place the drain hose lower than the tub and the water will run out
the reason it is not draining is that the pump under the tub is not getting power to start it or the pump is failed ( something jammed in the impeller like bobby pins bra wire , buttons or coins.)
May 22, 2015 | Washing Machines
h2o is the chemical symbol for water. But if the water keeps running and does not stop, even when the machine is full it could be the machine has a defect level indicator, or the water lock does not work. When the lock even don't closes what you remove the power the lock is defect.
Mar 24, 2015 | Ariston Technologies Washing Machines
Ariston 1636 f/l washing machine not draining properly
you need to clean the water passage at the drain hose.
Feb 27, 2012 | Ariston Technologies Washing Machines
Ariston a1600wd wont turn on
Before you change fuses, do you have an internal fuse board or RCD system in your home? Sometimes, an individual RCD can trip out, locking off sockets. Some sockets are individually set up for up and downstairs in a house, or different rooms. If you have a board or RCDs, check them out :)
Nov 18, 2017 | Ariston Technologies Washing Machines
Washing machine will not spin
hello, there could be couple of things wrong is the pump draining properly if ok then it may be the module control board some times the transistor on the board shorts out hope it helps
Jan 08, 2011 | Ariston Technologies Ariston AWD12 Front...
Hi Door to my ariston a1600wd is leaking any ideas? I cn't afford to get a technician out, I am willing to try and fix it myself. Is is a seal or a door problem?
Is it definately the door? ive had the water leaking from the top drawer but looked like the door! Ive just cleaned the filter from the drum to the water pump and it was blocked, which makes me think the pump cant pump the water out quick enought on the spin cousing water to rise. U can get to the filter from the rear of the machine by taking the plastic cover off at the bottom and removing the black gater where the filter is inside
May 23, 2010 | Washing Machines
Water not emptying from the machine,
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine2_bing.gif not draining and or not spinning
May 16, 2010 | Ariston Technologies Ariston AWD12 Front...
Ariston a1600wd not working
There is a filter of sorts in the pump inlet pipe, its a big item catcher coins etc, but thats got nothing to do with the module error wich is a pricey item at £120! I've had one go already and in the last year, a inlet valve plus a control pcb panel in fact its almost a NEW machine! i'll never buy another hotpoint or ariston again. The machine is two yrs old!
Oct 02, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
Jul 10, 2007 | Ariston Technologies AWD 121
Washing Machines Logo
404 people viewed this question
Top Washing Machines Experts
