Question about Nordic Track NordicTrack Treadmill, A2550
The equitment is stuck in the storage position can't get the machine down to the floor for use. The release is not releasing the shaft
Dyson brush head will not snap down to floor
The red step-on release is damaged/defective.
May 28, 2018 | Dyson Vacuums
How do you remove the lower center console on a 2000 Olds Intrique
Item Part Number Description 1 060024 Floor console armrest 2 06010 Floor console storage bin 3 04338D Floor console finish panel (front) 4 044D90 Floor console finish panel (center) 5 - Floor console cup holder screws (2 required) 6 13562 Floor console cup holder 7 - Floor console front screws (2 required) 8 - Floor console rear screws (3 required) 9 - Floor console nut 10 045A36 Floor console Removal and Installation
  1. Position the seats as needed to remove the console.
  1. Disconnect the battery. For additional information, refer to Section 414-01 .
  1. Remove the floor console storage bin.
    1. Remove the 3 screws and the armrest.
    1. Remove the floor console storage bin screw.
    1. Remove the pin-type retainer.
    • Disonnect the electrical connectors.
  1. Remove the floor console front finish panel.
    • Pull upward from the front of the trim panel to release the retainers.
    • Disconnect the electrical connectors.
  1. Remove the floor console center finish panel.
  1. If necessary, remove the 2 screws and the floor console cup holder.
  1. Remove the 2 floor console front screws.
  1. Remove the 3 floor console rear screws.
    • To install, tighten to 4 Nm (35 lb-in).
  1. NOTE: Lift the console from the rear and slide it rearward to release the rear seat heater ducts from the instrument panel. Remove the nut and the floor console.
    • Disconnect the electrical connector.
    • To install, tighten to 8 Nm (71 lb-in ).
  1. To install, reverse the removal procedure.
Jun 10, 2015 | 2000 Oldsmobile Intrigue
2nd Row Headrest Stuck in Upright Position and will not Fold for Stow n Go
You will need to take the seat apart to determine what is not fastened to release it.
Apr 09, 2014 | 2011 Chrysler Town and Country
I have a Bernina Activa 145S; the pressure foot is stuck in the down position; how do I lift it?
Machine will require service from an authorized repair technician.
Presser foot mechanicals are broken.
Jan 30, 2014 | Sewing Machines
My Nakajima AE-710 margin release does not work. How can I reset to factory settings?
When using the margin release DON'T HOLD IT DOWN just press and release. if this dosen/t work turn off the machine and see if the carrier will move both ways relatively freely if not look fot debris and spray a little WD40 on the silver shaft that it slides on.
DickyO
May 08, 2012 | Nakajima AE-710 Typewriter
The gator mount became stuck in the down position with the motor deployed into the water. The release rope would not release the lock to return the motor to the storage position so that I could operate...
mos minn kota motors have a pin that is spring load to lock when the motor is deployed. when you pull on the rope to lift the motor the pin is pulled forward to release and allow you to lift motor. sometimes it is necessary to put some pressure on the motor as if you were trying to push it farther in the water as you are putting this pressure on the motor pull on the rope to release the motor be very careful to avoid getting your hands or fingers in the way. when you get the motor up be sure to put a small amount of grease on the ends of the pin to prevent this from happening again.
Feb 25, 2011 | Garden
1986 Fiero: my e brake on my 85 fiero is stuck and i need it t...
It probably got stuck from lack of use/lubrication. But if your lever is also stuck up it could be a function of the actual lever action. I'm assuming you tried pushing the button in to release the lever?
Step 1) Get a haynes manual if you own a fiero, VERY valuable tool
Step 2) Check the physical action of the lever, is the lever not releasing down because of the lever itself? --> frozen/rusted? something physically blocking it on the floor of the car? Or is it not releasing due to the cable tension?
It's been awhile since I looked at it, but there should be a way to take the cover off of the lever to see the cable come into the shaft from underneath the car. Follow this cable to the rear of the car where it goes to the driver side rear brake caliper, then across the car to the passenger side caliper. You can adjust the tension for the cable using the nuts on the cable.
Also, there is a spring on each caliper that is supposed to put tension on the cable when pulled, so when released the cable returns to driving position and thus releases the brakes. Are these springs missing?
Are the brakes engaged because of the e-brake being stuck?
If you are in a pinch and need to use your car and can't because the brakes are on due to a stuck e-brake, it's not smart and can be illegal in your state, but you could just cut the e-brake cable. Should be pretty easy to do where it meets the lever on the inside of the car.
Let me know if you need more help
May 16, 2010 | 1986 Pontiac Fiero
I have an IBM Selectric III that has been stored for a couple of years. Before storage it worked fine, but now it just idles when powered up and nothing operates. I assume this means it needs lubrication....
Typically a machine that has been out of use, but was previously working may just need some lubrication on the motor centrifugal clutch assembly, but the entire machine probably would need lubrication also. You can first try to hand cycle the machine by grabbing the shaft that the carrier travels on and rotating it towards the (top to rear) rotation. This shaft rotates on revolution per print cycle and at rest the slot is slightly towards the rear of the machine. If you must lubricate the machine, then remove the cover. Lift the lid, place each hand of platen knobs and with thumbs, push down on release latches, after platen is out of machine, reach inside left and right cover and release the top cover latches and pull the cover straight UP to remove. Use 10 weight oil on motor bushings and centrifugal clutch hub (motor shaft).
Nov 08, 2009 | IBM Office Equipment & Supplies
How do you raise the karaoke 5 ft santa to full height?
On the one we have at work, there is a release on the main shaft above the feet so that he can stand tall, it then clicks into position so it doesn't fall. Hope this helps.
Dec 08, 2008 | Toys
Nordic Track NordicTrack Treadmill, A2550 Logo
78 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
