Question about Archos 605 WiFi Digital Media Player
Wifi and clock synchronization problem
I can't connect to my wireless router - this is a netgear 614 router, even with all the encryption and security disabled. I have successfully connected to a public network but when I do the automatic time synchronization fails and I cannot access the online content portal as a result.
Any ideas for fixing my problem appreciated.
  • 1 more comment
  • mebe Apr 24, 2008
    I have tried this and it doesn't help. Good idea though.
  • sarcon-ec May 12, 2008
    Have added MAC address (Archos 705 wifi 80gb) to router but the message
    'Content Portal clock service could not be accessed. Please try at another time or from another network'
    still comes on screen every time I try to access it. Any solutions. Have most up to date firmware.
  • wwht Apr 10, 2009
    content portal clock cannot be accessed and I want to purchase movies
  • 4 Answers
You can try adding the mac address of your archos Menu/system/settings. onto the router. It may be a built in firewall preventing you from connecting. good luck
Posted on Apr 24, 2008
Router wifi and computer dont connect
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. Toconnect to your wireless router from the computer/laptop, configure thewireless card in your computer/laptop with the router's wireless settings ieSSID, plus the WPA or WPA2 encryption key. Then computer/laptops cancommunicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Feb 25, 2012 | NetGear Computers & Internet
I have a MiniDell Inspiron Netbook that will connect to the internet through a neighbor's WiFi, but will not connect through my own Netgear router. The router is working fine for 2 other connections. How...
You may want to do a reset on the router by holding down the reset button on the back of your router. That will reset and MAC address filtering or any other security that you might have turned on.
Mar 08, 2011 | NetGear WGT624 Wireless Router
My Atheros AR5007 will only complete a "Local Connection, No Internet Connection" to a NetGear N600 Dual Band Router when Security Options (WPA2-PSK (AES)...ect) are selected on the Wireless...
Since the connection works without the encryption settings, it is NOT a driver issue. It sounds like a missing wireless network security setup problem. So assuming Windows (Mac OSX is similiar):
  1. Connect a laptop/PC to the NetGear via ethernet. It saves on some aggravations later.
  2. Connect to the NetGear and restore the security settings, and remember your keyword.
  3. On your computer, open the list of Wireless Networks (usually Start->Control Panel->Network(ing)->Wireless Networks). The menu sequence might differ slightly, depending on which Windows you're running.
  4. Find and click on "Manage Wireless Networks" (or words to that effect)
  5. Right click on your wireless network's name to get the drop down menu, and select "Properties"
  6. Find a button or tab related to "Security"
  7. Under Security Type, select WPA2-PSK (or Personal)
  8. Under Encryption Type, select "AES"
  9. Under Password (or Security Key), type in your router's WiFi security key word. You may have to log back into the NetGear and find the keyword (yours) or the alternate (gibberish) form.
  10. Save the settings
  11. If you're connected to that wireless network, then disconnect
  12. Try connecting to the wireless network again. It should work this time.
Feb 23, 2011 | D-Link Computers & Internet
I cant find my wi-fi password can you help please ???
The WiFi password is the encryption key is in the router's wireless settings.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Netgear to the LAN port on your computer.
Open a browser and enter the
Netgear configuration URL
http://192.168.0.1
The default login = admin
The default PW = password
You can protect your router by changing the default PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 13, 2011 | NetGear DG834G Router
Netgear password for wi-fi , for xbox live and ipod
Wifi password can be obtain by accessing the Netgear WPN824 router using a computer connected to it.
How to access the router
Go to http://www.routerlogin.net
username: admin
password: password
-Click wireless settings
- security encryption options would display the WIFI password.
- its the KEY1
Jan 01, 2011 | NetGear RangeMax WPN824 Router
How do i set netgear 614 with a password
To configure the Netgear wireless router, connect a LAN cable from the Netgear LAN port to the LAN port on the computer.
Then open a browser and enter the Netgear's configuration URL
http://192.158.0.1
You can now change the default password and configure the wireless settings eg. SSID, WPA or WPA2 encryption.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Nov 13, 2010 | NetGear WGR614 Router
I don't know how to connect my second laptop to the netgear router to get internet service.
Go to the first pc that is already connected. Right click your connection and note the status/advanced information, find the gateway IP address. Open a web browser and login to your netgear router. NetGear default is admin and password.
Now go to the wireless setup, note the ssid or name of your wifi network, also note the security encryption and phrase you are using. If you don't remember you can set it again there and save but then you will need to reconnect to it, if all else fails use a data cable and plug directly up to the router to manage it.
Once you know your wifi name and security key you setup, go to pc 2 and use the wireless utility scan or refresh you should see the name of your wifi network, click join to connect, it will challange you for the password. It if doesn't then all of your neighbors can use your internet and access your computers. Need to be sure to secure your wifi signal by managing it via the web management using your web browser.
Aug 29, 2010 | NetGear WGR614 Wireless Router
ACER AS5738-6444 Notebook cannot see my wifi router?
The wireless card in the notebook needs to be configured with the Netgear's wireless settings ie. SSID, WPA encryption etc.
Please click on this link for my instructions on securing the wireless network, configure the wireless router and wireless card in the notebook :-
Feb 05, 2010 | Acer Computers & Internet
How to change (or update) wap to wpa encryption on ASUS WIFI-B Network Adapter
With this Asus wireless B adapter even the new driver dont support WPA wireless security , because right now sicne WPA is a much newer and higher type of wireless encryption only some wireless B adapter supports that and sorry to say this wireless adapter that you have don't support it even with the latest driver so it will be better to get a new wireless G adapter that supports WPA 100% , you can get the wireless adapter from Asus or from other wireless device manufacturer like Linksys, Netgear. Dlink and Belkin....
Nov 02, 2008 | ASUS WIFI-B Network Adapter
Connectivity problem.
Hi Bidush,
You might wanna check out your notebook to find out if you have any firewall blocking any attempts to connect to nearby wifi. Also, if your notebook comes with intel proset wireless feature, try to make use of that for connnecting to the wireless lan instead of the default microsoft method of connecting (much easier and user friendly).
On the other hand, please do check on the router if you have enabled any form of security feature (mac authentification, wep encryption method, etc) that prevents your notebook from "seeing" the router.
Although these are just surface steps, it is important to makes sure these areas are clear before we go in to further zero in on the problem. I would like to follow up with you on this, so please kindly update me on the situation by replaying to this post and we take it from there. Thank you.
-Technomancer
Jun 06, 2008 | NetGear WGR614 Wireless Router
Archos 605 WiFi Digital Media Player Logo
512 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
