Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Our DD603 double drawer dishwasher the top drawer is catching on the what appears to be the upper liner of the top compartment. I can lift the linner slightly with my finger when pushing the drawer closed and it will not catch. Would you know how I can correct this problem. thank you john rossi
  • 11,896 Answers
Check that the latch is not out of alignment. If the paneling is coming off, try an adhesive to hold it up. Make sure paneling is out of place. If so, try and push it back in place and use an adhesive to hold it down.
Posted on Jul 27, 2010
  • jjrosftl Jul 27, 2010
    How do I remove the upper drawer to get a better look at the upper liner or to inject an adhiesive and can you rcomend an adhiesive ?
    john
    thank you
  • Nate Stansfield
    Nate Stansfield Jul 27, 2010
    You should pull the drawer completely out, then lift it up then out.
Top drawer can not be open
If this is a double drawer dishwasher and bottom drawing is functional but top drawer won't open means the controller on top drawer is faulty or power circuit is locked. If turning the mains power off and back on makes no difference then controller could be the problem. One way to test is to take the controller from bottom drawer and replace that in the top drawer. This requires a lot of patience and experience with electronic stuff. If you are not brave enough to test then call the technician. The controller is about $200 to buy. Make sure the mains power socket is taken out before working on the dishwasher internals.
FISHER PAYKEL DISHWASHER DD603 Parts
Feb 10, 2014 | Fisher and Paykel Dishwashers
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
Why won't my top drawer start
I am assuming you have a double drawer unit DD603. A drawer will not respond when you press Start button for several reasons. Assuming the panel lights are on, there could be a problem with the lid seal motor or the sensor that detects drawer is closed or blocked outlet hose or dirty panel. Take a damp clean cloth and wipe the inside of the drawer door panel. The dishwasher is very smart and checks for the condition of the dishwasher before starting. If turning off the mains power and turning it back on does not change the situation you will need a technician to attend to it.
Feb 07, 2013 | Fisher and Paykel Dishwashers
I have a dish drawer DD603 purchased in 2005. It
I presume you have a double drawer model.
Does this problem occur with both drawers?
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Dd603 info only acrid smell/smoke from upper
INFO ONLY- POTENTIAL FLUIDS CONTAMINATING CIRCUIT BOARD
EDGE CONNECTORS
Jan 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
F&P double drawer (DD603) won't empty
Ok you need to remove the motor rotor it's under the spray arm and comes out like a light bulb from the top draw and check for anyting stuck under it or any damage done to it. Try swapping it with the one out of the bottome drawer and see if that works. When you first start the washer does it drain all the water?? if still no luck try swapping the motor contoller modules (computer board) from the top drawer to the bottom drawer and retry both drawers ,if the fault moves drawers with the part, then that part is faulty cheers
Mar 18, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer stuck, gaskets rubbing, no power to controls
I see the question is posted in the DD603 section, so I am not sure if I am giving the proper advice. Are you sure this is a 602/601 series? A DD603 model has lid actuator motors, not the inflatable style seal. It sounds like the lid motors are in the DOWN position. Since the machine is "dead" what may have happened is the heater plate opened up (the heater plate is a dropping resistor inline with the machine's controller) when the machine was in use and that stopped everything dead.
Double-check your model number so we know what style of lid your machine has, The difference is huge between models.
Dec 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
