Question about Microsoft Zune120 Digital Media Player
Zune black screen
My zune just died on me yesterday I left it on the table and next time I checked on it the battery was dead so I didnt think much of it perhaps I left it playing for few hours later when it failed to start only showed the bright black screen I realized that it couldnt have been playing since I pulled out headphones which pauses the music... I tried soft restart (Back+up) it loads and goes right back to black screen I can turn it off after I hold play but when I tried to hard reset it didnt work... Well by doesnt work I mean nothing happened when I tried the key combo...
I went into device manager and it can see my ZUNE but the software doesnt seem to detect it.
BTW the I cant get music to play
ThaMp3Doctor
  • 8596 Answers
SOURCE: ZUNE 30GB Zune Music... Problem
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Jul 06, 2008
altec1105
  • 68 Answers
SOURCE: my zune is not detected by my laptop or zune software.
try to wiggle the zune cord but not to hard
Posted on Nov 22, 2008
  • 27 Answers
SOURCE: Zune
To reset the zune you must press and hold the back button and the top part of the zune pad. Other parts of the zune pad will not work.
When plugging the zune into your PC does the PC detect it (device manager -> portable devices). You should hear the ding sound of hardware connecting.
If it is connecting to the PC and is not detected by the software than it is likely a permissions problem. Right click the software icon and choose run as administrator.
If it is not detected by the PC than check your usb cable and make sure your zune is charged and not frozen.
Posted on Jan 13, 2009
  • 11 Answers
SOURCE: Zune won't turn on or charge
probly a lemon battery. Get ms to replace it.
Posted on Feb 14, 2009
  • 4 Answers
SOURCE: Zune
I found the solution. what you do is you plug your zune into your usb port and your zune home page will come up automatically. as soon as your computer reads it look in the top right corner and go to settings. then go to device. finally press erase all content.
when it is done your zune should be empty but it will scroll and work once more...im not sure what is wrong but i had this same problem with my i pod and this same solution fixed that problem also.
ZUNES ARE MUCH BETTER THAN I PODS, stay zune and proud.
Posted on Apr 27, 2009
Zune is completely dead when not plugged into my computer
the battery is not retaining any power. the only reason it works while it is plugged in is because there is power go directly to the battery
Jan 11, 2010 | Audio Players & Recorders
Blac screen after the zune turns on
Hi, It is one of two things. You have a dead battery or your Zune has had a software crash. Make sure your batteries are charged then try it again. If it still does it you will need to contact Microsoft for possible repair.
May 11, 2009 | Microsoft Zune JS8-00001 Digital Media...
30GB Zune Froze
all of the zunes 30gb in the world went dead last night go to zune support.com and request a repair they will be helping you soon .
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune froze on boot up this morning. Reset buttons won't work nor will any others. Tried charging battery to no avail.
There's a fix:
Your Zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the Zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the Zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connector. Your Zune should start up immediately. Press the backing of the Zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
ZUNE NOT WORKING! ONLY BLACK SCREEN! WONT CHARGE!
Listen everyone this is what happened to me and what I did. Let the battery drain completely (unplugged from computer). It usually takes 5 to 6 hours to drain completely.
Then plug back in and hold the back and down button at the same time. Zune should resume functioning afterwards. All that is needed is a recharge.
Dec 29, 2008 | Microsoft Zune JS8-00001 Digital Media...
Unresponsive (and dead battery) zune o' saddness
Power sources that are supported loadTOCNode(2, 'moreinformation'); To charge the battery in your Zune device, you must connect the Zune device to one of the following supported power sources:
  • A computer’s USB port that you can connect to by using a Zune Sync Cable.
  • A Zune AC Adapter that you can connect to by using a Zune Sync Cable. Note The Zune AC Adapter is sold separately.
  • A Zune Car Charger or a Zune FM Transmitter/Charger. Note These items are sold separately.
  • An Xbox 360 console's USB port that you can connect to by using a Zune Sync Cable.
  • A “Designed for Zune” mobile battery pack
http://support.microsoft.com/kb/927348
Nov 09, 2008 | Microsoft Zune JS8-00001 Digital Media...
My zune stopped working and now will not turn on
I figured out the solution by just getting upset.
Hold the Back arrow (<-) and Up on the touch pad and it will restart the Zune. This works for the 8gig and 80gig Zune.
Oct 20, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Battery life
have u dropped it at the top any
Jul 16, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune120 Digital Media Player Logo
59 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
