Question about Pioneer CDX-P1280 12-Disc CD Changer
How to install
I lost my manualand can't remember how to install the cd changer to my reciever
    President:
  • 676 Answers
The following address should help you out. The model number is a little differrent but should have the same connections. Good Luck.
http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/49770CRD3351A_20001230125882900.pdf
Posted on Jul 27, 2010
Lost manual can not remember how to record new cd
You can get the manual on the link below.
http://dl.owneriq.net/5/571e7e55-923b-4c51-b093-3c42e491eed6.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 16, 2010 | Pioneer PD-R509 CD Recorder
I tried connecting a ipod cord in the back of the recievers ports and the volume can't be controlled by the reciever, is there a aux input option for this reciever or is it to old.
How did you "connect" an Ipod to the receiver? If you plugged in RCAs then you were probably plugging into the pre-amp outputs of the stereo. There is an aux option from pioneer (CDRB10) which plugs into the blue squarish plug on the back. I think its a CDRB20 if you ever wanted to add a CD changer as well.
Mar 02, 2010 | Pioneer DEH-P4000 CD Changer
I want to install my sony cdx-757mx 10 disc cd player in my recently purcased 2000 expedition that has a factory non working 6cd player in the center counsul.Do I need a wiring harness to adapt the sony?If...
the best bet is sony to sony / ford to ford/ pioneer to pioneer/ you can go down to wally world and pickup a decent reciever for about $150.00 and you will save a lot of head aches tryin to adapt& cut and you will still not know why the factory cd changer quit working..
best to ya
Feb 23, 2010 | Sony CDX-757MX 10-Disc CD Changer
I have my cd changer (alpine) plugged into the input port via ai net cable and I have the output going to the alpine radio (cda 9886) via ai net cable. When I hit the source button everything comes up but...
One thing to verify is that the Ai-Net switch at the bottom of the radio is set to Norm and not the EQ position. And also gray Ai-Net connectors are for audio input and the black Ai-Net connectors are for audio output. It sounds like you have everything connected correctly and at least the Sirius is coming up. And I assume that the CD changer works when connected directly to the reciever so you know that it is working. I would suspect that there might be a problem with the Sirius reciever not allowing the communication signal to connect to the Alpine deck and in that case you would need to get a new reciever. You could check the Alpine radio settings and see if there is something that needs to be changed in order to allow the CD changer to work. If you disconnected the battery connection to the radio then it might have reset the settings to factory default. Otherwise it sounds to me like the problem is with the Sirius reciever.
Jan 09, 2010 | Sirius Satellite Radio Sirius SIR-ALP1...
Cd changer needs to be constantly reset when I start car
wire the red and yellow wires together and tape(electrical) and turn the entire unit off by the off switch on your reciever (you will have to reset the unit for the final time- fader /bass/treble /balance/) what you have done is by passed the key switch( also look under the reciever for a "switched or unswitched button or toggle...
peace
Aug 26, 2009 | Sony CDX-757MX 10-Disc CD Changer
Panasonic CD Changer with Pioneer reciever
Panasonic CD changers have a specific plug in that will not work with the Pioneer head unit. The Pioneer uses the IP-BUS plug. You will also not be able to convert the unit to work because the data between the two cannot be controlled and you won't have the ability to use the units together.
Sep 12, 2008 | Panasonic CX-DP801 8-Disc CD Changer
Chm -s620 cd changer not loading cds
I've got the same problem with my Alpine changer. It seems like a widespread problem, but known cause or solutions.
Apr 03, 2008 | Alpine CHM-S620 6-Disc CD Changer
CD Changer Not Working
sum have a small reset button where the mag is
Nov 26, 2007 | Kenwood KDC-MP3035 CD Player
Radio recieves only odd frequencies
turn radio off, and press the "audio" botton until clock is displayed. then click it again shortly till you see "FM 100" on the display, press > (side arrow, now it should switch to "FM 50". long press on the "audio" to save and exit. afterwards it should work fine.
Feb 22, 2006 | Pioneer DEH-345 CD Changer
Pioneer CDX-P1280 12-Disc CD Changer Logo
187 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
