Question about Proform 540ls Treadmill Walking Belt
Belt skips belt on treadmill skips what can i do to make belt run smoothly
  • 15,935 Answers
This typically means the belt is worn - or not tensioned properly.
Look in your owner's manual - and it will tell you how to properly tension the belt with the included spanner wrench.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 27, 2010
Treadmill belt doesn't run smoothly
First of all lubricate the treadmill. If it didn't workout then try to tension the walking belt.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
https://www.youtube.com/watch?v=b1MU7MvBETs
https://www.youtube.com/watch?v=JC72OIKdluY
Dec 27, 2015 | Bodyguard T240 Treadmill
Belt don't move
you may have to adjust tension notch at a time and see if it makes any difference.
Mar 24, 2014 | Smoothfitness Smooth 6.17 Folding...
ProForm Space saver treadmill was closed while inclined, belt skips and moves to side
see the video and proceed according. God bless youlube the rack and pinion of elevation motor, and adjust the small POT attached. see the diagram attached.
Apr 05, 2013 | Exercise & Fitness
I have a Healthrider R65, engine works wellbut when I step on it skips and stops for afew seconds my husband adjusted belt on each side but is till not going smoothly please adviceI bought from my fri
1) Lube the deck belt, this produce enough friction between deck vs deck belt, and shut down for to protect the electronic system
2) lube the rollers bearing very well.
3) Test the drive belt and replace
4) Test the motor input voltage, if there are the motor need repair.
5) test the output voltage board, for input voltage motor, if there are not the board is faulty.
God bless you
May 11, 2012 | HEALTHRIDER R65 Treadmill
The treadmill runs fine until i step on it then it stalls and stops running
There is a motor which spins the treadmill belt.When you start the treadmill, the motor starts running and belt spins smoothly.But when you step on the treadmill, the motor cannot take the load and it stops working.In your case, the motor and motor control board is got weak and this is causing the problem. ---------- Or the other possibility is the treadmill belt, the belt on which you step.That belt should be smooth, there is grease in the inner side of belt to keep it lube and run fluently.If that oily grease gets dried up then belt gets bit stiff or jammed up, when a load is on belt.So get this both possibilities checked.First try lubing the belt internally and then try check the motor and motor control board.To locate motor control board its simple.On the side of motor you will see a electric plug in connector, the other end of that connector gets connected to motor control board.Remove that connector , clean it and reconnect after 5 minutes, then check.In some cases this resets the internal control system and everything, works normally.But its not always possible then removing and reconnecting connector helps.In other cases the motor or control board needs to be replaced.If the motor gets weak, then internal coils in motor gets burned up.----------- This will help.Thanks.Helpmech.
Mar 26, 2011 | Proform Exercise & Fitness
I have a Image 15.0 R treadmill. It skips and I tried tightening the belt 1/4 turn as directed and not over tighten it. Still skips and actually squeaks now especially when running on the treadmill at 6...
3 different possibilities in my opinion:
belt is too loose, belt is too tight, belt is worn out.
Try to lift the belt and get your hand under it in the middle of the deck. If you cannot reach, it is possible that your belt is too tight. Another clue for this would be the belt "curling" on both sides at the edges. Try to loosen the belt, gradually and testing it along the way.
If on the contrary you can easily slide your hand under the belt from one side to the other, it is more likely that the belt is too loose. The squeaking might be due to the belt not being "square" on the deck. Try to loosen it even more until you can slide it with your hands across the deck. And have it aligned evenly at the front and back. Then retighten and adjust the tracking at low speed.
!!! Do not over loosen as the bolts might come out of the back roller.
A worn out belt might squeak and skip when its old.
Mar 04, 2011 | RTO Image 15.0R Treadmill Walking Belt
Belt skips
take the cover off, if the front drive roller continues to turn when the running belt stops, tension the running belt by using the rear adjustment screws. One full turn on each side should do it. If the front roller stops turning but the motor doesn't, tension the drive belt by adjusting the motor back.
May 26, 2010 | Proform 760 CrossTrainer Treadmill
Thumping noise that increases with speed
OPEN MOTOR SHROUD SO YOU CAN BETTER INSPECT THE UNIT CHECK THE DRIVE BELT THEN I WOULD CHECK THE RUNNING BELT TO SEE IF THEIR IS ANY DEBRIS THAT THE BELT ITSELF IS SPLITTING SINCE YOUR SAY A THUMPING SOUND. SINCE KEYS FITNESS MADE THIS UNIT THEY ARE NO LONGER IN BUSINESS, BUT TREADMILL DOCTOR HAD PURCHASED THE PARTS. SO GO TO TREADMILL DOCTOR.COM THEY MAY HAVE THE PARTS YOU NEED
Mar 01, 2010 | Smoothfitness Smooth 5.45 Folding...
Proform 540ls Treadmill Walking Belt Logo
189 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
