Question about Kenmore 24032\24036 Top Load Washer
It is old kenmore washer and water can only fill up to half tank of the washer. Is that water level sensor problem
    President:
  • 1,430 Answers
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. There is a video at http://appliancehelponline.com/toppressureswitchvideo.html this will walk you thru the inspection and replacement of this part. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on Jul 27, 2010
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
FILLS WITH WATER THEN NOTHING
There is a water level sensor switch inside the washer. This sensor
needs replacing. It tells the washer to start running when the level
of water reaches the correct amount for you load size.
You will need to call a service repair man to change the sensor.
Feb 25, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore washer fills with water
You may have a bad lid switch. Need the model to check for you. Thanks
Dec 01, 2009 | Kenmore Washing Machines
Washer fill with water won't stop
HI.there is a water fill level pressure switch that is malfunctioning at this point. this switch regulates the fill level(water level). you will need to replace this defective switch asap.
Jun 18, 2009 | Kenmore 22642 Top Load Washer
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 2.1 cu. ft Washer water won't stop filing, cycle doesn't start...
most likely cause
kenmore pressure sensors work off a tube that runs from the bottom of the drum to the sensor, either the tube has come off the sensor body inside the control panel
  • open control panel reattach tube, wrap wiretie or twisttie to keep in plpace
or less likely cause
kenmore level sensors fail
there is a spring inside that stretches over time and mis reads, it is adjustable
  • control panel is still open from previous check
  • remove level selector from control panel, usually an unlock latch on the right side, rotate 45deg counter clockwise withdraw.
  • there is a 1/8 inch bolt head, turn right raise water level, turl left lower water level
Aug 23, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Ge top load washer keeps filling with water
most common leak point for washers is the level sensor connector on the lower part of the tank, a small plastic hose.
Not a solution, something to check
Jul 23, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Kenmore 24032\24036 Top Load Washer Logo
80 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
