Question about Movado 800 Performance watch
How do u you set the date on movado series 800 steel watch
  • Anonymous Mar 30, 2014
    I set the date and it does not change.
    Problem Solver:
  • 8 Answers
Turn the crown of the watch towards you until it pops out... After the crown pops out, pull on it to extend fully and you should be able to change the time at that point
Posted on Dec 09, 2010
  • Per Jakobsen Mar 08, 2011
    There is no way (other than moving the time (pull crown out twice) hourly until you have the right date. So much for 'quick date set'.
SOURCE:
How do I replace the rubber on the back case of movado 800 series
I was told my a jeweler that Movado condiders that. Design defect and they don't produce or offer that rubber insert for sale.
Jun 26, 2013 | Movado Series 800 Watch
I just recieved my Movado 800 series watch today and the large chronograph timer hand won't reset to zero (top of dial @ 12 o'clock) when I press the zero button. It resets to 56 minute position....
you do not need to return, as this is re-settable. Pull out crown to the first position (date setting) and then toggle with upper push button. If upper button do not do the job, try the bottom one. When you reach 12, then push the crown back in. Start the chrono, stop it and check if it returns to 12.
May 18, 2011 | Movado® Series 800 Blue Chronograph Watch...
Hello I have a movado 800 series sub 200 and
it is probably either in set time mode, or some sort of chronograph mode. play with the buttons.
Feb 19, 2011 | Movado 800 Performance watch
The chronograph hour hand on my movado series 800 is out of sync and i cant get it back to the 0 position. I have pulled out the crown and pushed the start/stop button...
Try pulling the crown out and using the reset button to move hands beside the sweep arm. If this doesn't work then you may need to take it to a repair shop that can reset or AC the watch. With a movement as fine as Movado I wouldn't attempt this yourself. If you make a mistake the repair could cost more than the watch. Be sure that you have the watch resealed so it maintains its water resistance.
Feb 10, 2011 | Movado Series 800 Watch
I have a Movado series 800 model 2600075 watch. I lost the manual and now need to change the time setting. How do I do that? Thx.
Turn the crown of the watch towards you until it pops out... After the crown pops out, pull on it to extend fully and you should be able to change the time at that point.
Nov 09, 2010 | Movado 800 Performance watch
Date will not advance on own. you can change it by hand but doesn't change at night stays on same date for days.
One of the wheels of the watch movement has become stuck or broken. You will either need to fix or replace the wheels or movement.
If you have still have warranty card for Movado and within the date range of the models warranty then Movado will repair watch for free if not you will have to have it fixed by Movado or a local jeweler.
Oct 18, 2010 | Movado 800 Performance watch
How do I remove a steel link from a Movado wristband 800 series?
mcdevito75 here, Special tools neede to remove links, Best Bet look for a small watch repair shop in your area, and hold onto those links once removed as you may need them again in the future.
Oct 16, 2010 | Movado 800 Performance watch
How do i set the date?
Go to their web site http://www.movado.com/Service.aspx and click on Download ....................series 800 operating instructions ................."
Aug 12, 2010 | Movado 800 Performance watch
My watch battery low. watch name MOVADO series 800
mcdevito75 here, Movado a FINE watch, BEST BET, look for a small watch repair shop in your area to change the battery, Movado watches have a very good over all value and any damage can lessen that value, not to mention the jewelers screwdriver you"ll need to change that battery.
Jul 09, 2010 | Movado Series 800 Watch
Movado 800 Performance watch Logo
4,113 people viewed this question
Top Movado Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Movado Watch Expert? Answer questions, earn points and help others
