Question about Milwaukee Tool Milwaukee 10 Amp Recprocating Saw Sawzall Plus with Quik - Lok Cord
Motor on my sawzall 6572 runs but blade does not move. Blade locked in tight. No reciprocating motion.
  • Milwaukee Tool Master
  • 43,501 Answers
The gears are stripped internally in the saw...it will need to be repaired..
heatman101
Posted on Aug 27, 2010
A piece of a broken blade is stuck here the blade fits into the saw (Dewalt DW 303m). How do I get it out?
Craig, a drop of penetrate oil and you will just have to work at it with ice pick.small screwdriver, or needle nose pliers if you can, make sure you have blade release depressed while trying to pry blade shank out. Once you get it moving it will fall out. Clean and blow out blade port before inserting another blade.
How to Remove Stuck Blade on Sawzall Hatchet eHow
Troubleshooting Your Malfunctioning Reciprocating Saw DoItYourself com
May 26, 2016 | Dewalt Saws
I pull the quick lever to put the blade in but i cannot get the blade in?
check to see if the lever is worn or bent. If so it won't make the sliding piece move enough to get the retaining ball to open all the way. Do you have a broken piece of blade stick in it?
Feb 17, 2015 | Dewalt 18 Volt Cordless Reciprocating Saw-...
Broken blade in dewalt sawzall
Remove broken blade, install new one. These blades don't change themselves, unfortunately.
May 06, 2012 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
Roybi sawzall blade wont go in
be sure it is rite type of blade some are pop in and some have a set screw there are several different blades for these couple different types of tools hope this helps
Mar 02, 2012 | Ryobi 18 V Cordless Reciprocating Saw
Cordless 18 volt lithium ion sawzall hums and clicks blade wont move
I don't know what model you have but Milwaukee sawzalls use a wobble shaft and wobble plate to turn the rotary motion of the armature into the reciprocating action of the blade. If you motor is working (hums?) but the blade won't move one or more of these parts are broken and hitting eacher (clicks?) inside the gear case. You or a repair center will have to take the gear case apart to find our what's broken and determine whether it's worth repairing.
Jan 27, 2012 | Milwaukee Tool Saws
Have DeWalt Model 303 Type 1 Blade is stuck can not remove, removed Scew part # 99164-06. Blade is still stuck, blade will move side to side, back and forth but will not slide out. Any ideas
It sounds like the set-screw may have caused a burr on the blade, and that's preventing you from removing it. You might use a tool like vice-grips, and apply more force. I don't think you can hurt anything by doing that if the blade is in the fully-extended position.
Good luck,
genetuck
Feb 13, 2011 | Dewalt 15 6" Reciprocating Sawzall Saw...
Milwaulkee sawzall quick release wont release.Cam turns ok but pin is holding blade.Tried prying blade out w/vise grips-no luck
try using WD-40 first to loosen up pin and if not you might have to replace the quick lock assembly. ot a tough job about 10 minutes or less.
Jan 17, 2011 | Milwaukee Tool 10 Amp Sawzall Plus with...
Motor spins, blade doesn't move
Yes it should be covered under warranty, it might not be a shaft breakage. there is a hex nut under the gearcase cover that might have loosened up. But I would take to a repair center first for warranty coverage. If you still have problems let me know.
Jul 18, 2010 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
The blade lever on my sawzall is stuck in the up position
oohh, that a tough one. you gotta, very carefully peal back the hand gaurd, the rubber where you hold onto it, at. Then releas the screws undeneath. Seems like you should be able to cycle the saw to its furthest out position, then remove the blade gaurd, uning some pliers of some sort you should be able to make the release, release.
Hope this helps
Mar 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
Milwaukee Tool Milwaukee 10 Amp Recprocating Saw Sawzall Plus with Quik - Lok Cord Logo
597 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Craig Butler
Craig Butler
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
