Question about GE Kitchen Ranges
GE Electric range coil burner does not work on low heat, has to be above 4 to have any heat and works perfect on high heat. Changed element same problem. Is it the receptacle or the dial control?
    President:
  • 1,430 Answers
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at http://appliancehelponline.com/infiniteswitchvideo.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Posted on Jul 27, 2010
GE TrueTemp range JBP30W0B1WW — 3 of 4 burners stay on HIGH even when set to low/medium.
as there is no make /model listed only a guess would be the switches
Dec 26, 2015 | Kitchen Ranges
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Spectra GE model JBP64W0B4WW stove top burner stopped working
Which element is it? Try to switch the infinite switch from another element. This will tell you if it is the element or the switch problem.
Apr 06, 2013 | GE Spectra JBP78 Electric Kitchen Range
On an old (1960s?) GE electric drop in range, 1 of the burner coils is not working. Solution?
Most likely the heating element (burner coil) has an open circuit ("burned thru") and would need to be replaced. Do you have a multi-meter with which to test the continuity of the element?
Charlie
Feb 08, 2011 | Microwave Ovens
Fixing an apartment sized GE range - pushbuttons don't respond
I'm not sure what your question is. Are you trying to find out why only one burner works? The top burners are simple and if you can work on it I can tell you how and what makes it works. The burners are as most ele. things. You have a line in, a switch, a load and a ground. The switch has 220v coming in. When you push a button it allows ele from the line to go to the element which is the load. Which button you push dictates the amount of ele that is allowed to go to the load. It should have a OFF, LOW, MEDIUM and a HIGH. If you check the wires between the switch and the element after you push the HIGH, you should show 220v. If not, you have a bad switch. I hope this helps like I stated, I'm not sure what your question is.
Please rate this solution
Aug 27, 2009 | GE Kitchen Ranges
The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Jul 13, 2009 | GE Spectra JBP78 Electric Kitchen Range
Burner heating element stays on high-cannot
there is a thermostat element beside every burner
i think it need to be changed.
thank you
Jun 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Burner coil replacement
You may have to change the infinite switch and the heating element holder with the wiring
Nov 18, 2017 | GE JBP25 Electric Kitchen Range
Single Burner Doesn't Heat Properly
1. Turn off power. 2. Determine type of burner. If it's a plug-in, test faulty burner in another receptacle * If it works, replace the original receptacle * If it doesn't work, replace the burner. * Replace other faulty components If it's a flip-up burner: * Disassemble and replace the faulty burner and any other faulty parts. 3. Restore power. 4. Test. *If it still doesn't work, call a repairperson.
Jan 18, 2006 | Crosley CE35100AA Electric Kitchen Range
Kitchen Ranges Logo
285 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
