Question about Dell 1815dn All-In-One Laser Printer
  • pref6051 Sep 09, 2008
    dell 1815 dn. 15 month old. working fine - wanted to print 8.5 x 14. It took me a while to figure out that instead of the bypass tray (which had a paper jam) I could extend the regular tray to accomodate legal paper. While I was solving the problem, I carefully opened the fuser door and removed the paper jam. Now the machine won't print without jamming - even letter size. Dell says the fuser has to be replaced - at least $200-250. Does this make sense to you. Email or call 714-842-7549
    Thanks. Dave
  • Anonymous Mar 21, 2009
    Dell printer squeals (very loudly) when turning on or off.
  • Dell Master
  • 1,056 Answers
Sounds like it stripped the pickup wheel drive gear.
Since it is only 2 months old, I would suggest calling Dell to have then service or replace the unit.
You will need the service tag, and the express service code (they can be found on a little white sticker where you put the toner in).
Contact Dell through the 800 # or they do have a really good online chat service. That device will have at least a one year warranty. I have found at most times, they will simply swap the unit out (I have 8 of these)
Posted on Aug 11, 2008
Dell MFP 1815dn continuously feeds paper when printing
There might be a paper jam or issue with the drum .. please remove the jammed paper or contact authorised dell support
Oct 05, 2016 | Dell Laser MFP 1815
How can I get it to print the ip address to hook it to my computer
Dell Laser MFP 1815dn configuration page
To print a configuration page (also called system data report) from a Dell Laser MFP 1815dn printer:
- Press the right arrow button until Menu is the active choice on the screen
- Press the check mark button to select it
- Press the right arrow button until Reports is the active choice
- Press the right arrow button until System Data is the active choice
Aug 21, 2015 | Dell Office Equipment & Supplies
Dell 1815dn Fax confirmation?
1. restart the system ,
2. turn off the power / scan/ fax ,
3. unplug all the cable to the system and wall socket and then wait for 20-30 seconds .,
4. connect all the cables and give a try it should work.
Oct 20, 2014 | Dell Printers:Dell MFP Laser Printer...
How do you print an envelope on a Dell Laser MFP 1815dn
when printing enevelopes always ALWAYS THROUGH THE BYPASS open front door and feed thru there. on the bypass is image to let you know fce up or down follow that. also change settings on pc when printing envelopes or cardstock etc.
Jun 09, 2012 | Dell 1815dn All-In-One Laser Printer
My dell laser mfp 1815dn is saying the memory is full how do i erase it?
Write cmd in your start button(you maybe have to run as admin)
A black window appers
Then write stop spooler and press enter.
Wait until the window close.
Your print job is now erased.
If this does not help, upgrade your software from here:
Good luck.
Mar 08, 2011 | Dell Printers:Dell MFP Laser Printer...
Dell laser mfp 1815 dn "scanner locked" message
When you lift the scanner lid look to the left bottom. you should see a green slider button. If you stick your hand in the output tray and get it rigth under the green slider you will find a lever. Move that thing backwards or forwards, that is your unlocker.
Jul 06, 2009 | Dell 1815dn All-In-One Laser Printer
Scanner locked printer dell laser mfp 1815dn
The lock for the scanner is on the roof of the cavity where the printed paper comes out. Simply flip it to the other position and restart the printer.
Jun 03, 2009 | Dell 1815dn All-In-One Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
407 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
