Question about Kenmore Elite 45986 Front Load Washer
I have a Kenmore HE 3 T. I put the clothes in the washer and when I push the button to turn it on, nothing happens. I checked the outlet and it's fine. The breakers aren't blown. I plugged the washer into another outlet on another circuit and still nothing. Any suggestions?
  • itsme1947 Jul 28, 2010
    I have the same problem. Love to know the answer. If I unplug it for awhile and plug it back in, it usually works.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
My kenmore 800 series washer started draining but stopped 3/4 of the way and now won't do anything at all
Put the machine into the spin cycle and start as normal. Then with the lid open take a item like a pencil and depress into the lid switch where the lid pushes down on a switch. If machine starts spinning remove and replace lid switch. Let me know.
Feb 01, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes.
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes. Kennmore 96590140.
Jan 01, 2011 | Kenmore 62602 Electric Dryer
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite H3 control buttons - some work some don't
The diagnostic function will not help you if your user interface board (UIB) is acting up because to put into diagnostic you have to select drain spin, then the no spin option, and hit the prewash button 4 times.
It sounds like your UIB is the problem.
Jan 01, 2009 | Kenmore 42822 Front Load Washer
No Power and will not open.
Try unplugging the machine for 10 minutes. A lot of times the computer will reset and function normal. At least you can most likely get it to unlock to get your clothes off.
Nov 14, 2008 | Kenmore 24032\24036 Top Load Washer
Washer won't rinse
when yr washer does not rinse, it could be that your outlet is clogged. Ensure that yr outlet filter is free from any kind of blockage. Check this, it is a small door in front of the machine bottom. Plug off the wall & clean out, expect some water to come out when you open it. If this is not the case check out your outlet pump.
Sep 26, 2007 | Kenmore Elite 45986 Front Load Washer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
27 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
