Question about Frigidaire FEQ1442ES Electric Dryer
Not heating gas - Frigidaire FEQ1442ES Electric Dryer
  • Frigidaire Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
True air heat tries to start then goes to gas.It worked fine in the fall but it is now -5F
Do you have a heat pump and gas furnace setup? Or is it electric and gas setup.
To me it sounds like either configuration issue its electric and gas, but if its heat pump/gas the furnace is defaulting to gas more then likely on the outside air temperature, usually most heat pumps only heat good down to 10 degrees F.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Nov 18, 2013 | Coleman Heating & Cooling
Hi, Gas dryer does not heat up. It was on Sensor
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | Maytag Neptune MDG5500AW Gas Dryer
M/n 38brb060300 carrier
Hi, to tell if your unit is a heat-pump or not, if the indoor unit is not gas fired, it is a split system heat pump. If it uses gas or propane gas, its a split system gas/elect unit. Look at your thermostat also. It should have aux heat, emergency heat on it also. Maybe not both, but you will know if you have a heat pump. Please don't forget to rate me. Please be kind, as I know you will. Just remember, no gas, its a heat pump, gas fired furnace indoors, its not a heat pump.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Jul 15, 2010 | Carrier 38CKC060 Air Conditioner
Gas Dryer has heat at beginning of cycle then no heat.
heatman101
Jun 05, 2010 | Whirlpool LGR3624JQ Gas Dryer
Neptune MDG5500AW Gas Dryer: gas dryer will not heat...
heatman101
May 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
GE Profile gas dryer tumbles but NO HEAT, not ignitor
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
No heat gas smell
heatman101
Mar 08, 2010 | Estate EGD4400SQ Gas Dryer
Roper gas dryer does not heat.
If the ignitor is not powering , go to the switch. That has to send power to the ignitor, then on to the gas valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 22, 2009 | Roper RGX4634KQ Gas Dryer
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
My dryer will not get hot
Dec 15, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Frigidaire FEQ1442ES Electric Dryer Logo
29 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
