Question about Refrigerators
The ice cube tray won't fit can you or how do you adjust the cifiguration of the freezer comaprtment to allow it is a bottom kitchen aid freezer
This is a common problem,Throw the tray in the bin and buy ice cube bags from any supermarket. You will produce a lot more ice and bigger cubes.
Regards
Steve
Posted on Jul 27, 2010
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Kitchen aid superba
Are they staying on top of the ice maker or are they going all over? The ice bucket might be the wrong size.
Oct 29, 2013 | Roper RT21SKXLQ Top Freezer Refrigerator
Our ice maker makes hollow ice cubes. Why?
Your icemaker is not getting enough water to adequatly fill the tray. Before you adjust it, check the status of the refrigerator's waterfilter. If it's old and clogged replace. Next, wait for the tray to fill, and check the level water before it has a chance to freeze. (or take the frozen tray out and allow to thaw). The tray should be about 75% or more full of water. If not, there is an adjustment that can be made to extend the amount of time the solenoid stays open (which means more time for the water to fill the trays). Good luck!
Feb 20, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kitchen Aid KSRG25FKSS17 side by side refrigerator and ther ice maker stopped working. I got the ice out of the tray and it filled up with water and the fingers cycled around but will not push the...
Good day,
When ice cubes are formed, a thermostat embedded in the ice maker closes, and then starts a motor that cycles the rakes, ejecting the cubes.
When the fingers of the rake hit the frozen cubes, the motor stalls.
However, there is an electric heater embedded in the bottom of the ice maker that at the same time is heating the well of the ice maker, freeing them up and allowing them to be discharged.
You should remove the ice maker, to see if there is a foreign object that fell into the well, preventing the cycle from continuing. If so, remove the item and reinstall the ice maker.
More commonly, the motor has weakened or the heater has failed. In either case, replacing the ice maker is your only option. There are in some cases a repair possible, but it is not cost effective.
Sep 21, 2010 | KitchenAid (KSRD22FKST) Side by Side...
My ice maker is crushing the ice despite the fact that I have it set on cube. I have dumped the ice out of the catch tray twice and made sure that the dispenser is not blocked, but it still continues to...
the bottom of the tray has a rod attached to it that controls a flapper that opens up to allow the ice to pass thru without hitting the cutter or crush blades. this rod goes into a housing at the back of the freezer that has a solenoid switch that activates it to open it up. check to make sure all of these items are free of ice and in their proper position and or not broken. if this all looks good then you may have a bad solenoid switch.
May 29, 2010 | Frigidaire FRS3R5EMB Side by Side...
My ice maker is letting too much water go into the ice tray so it freezes in a solid piece. Cubes do fall down but there is so much water it freezes into a solid block
The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Oct 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice maker makes too much ice
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
Jul 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Samsung model RF265ABPN waxy looking piece fell into ice tray
The waxy piece has a clear plastic bracket, if its not connected, look around your freezer. The waxy piece fits inside the bracket, and attaches to the ice maker, just in front of the ice tray.
The white wire fits inside the waxy piece. It is the thermostat that tells the ice tray when to dump the ice.
This is impossible to feel around for, so you will need to remove at least the bottom freezer compartment as well as the ledge piece from just inside the freezer door. If you are a relatively thin/small person, you can extend the top tray fully outward, and slide underneath. Looking up at the ice maker, the plastic bracket should have a little prong. This prong will attach just behind the ice maker, with the thermostat facing the ice tray.
Jul 05, 2009 | Samsung RF265AA Bottom Freezer French Door...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
