Question about GE 46GW947 46" Rear Projection Television
Convergance board do you know where i can get a new board
  • 121 Answers
Hi go to this sight I posted they don't list all the boards but when you go to this sight click on contact button and send them a e-mail telling them what kind of board you need they can usually get any board you need even the ones "no longer available"
and they get back to people quickly
http://servicemanuals.vstore.ca/
Posted on Apr 25, 2008
I need a new convergence board, can I install it myself? Where would I find a convergence board?
I presume actual model number is PCL5415R---you can buy the
AA95-01799Rboard--it is available :
I would suggest since it is over 100 dollars it makes more sense if you have a convergence problem to buy and replace the two STK-392-040 convergence chips on it--there may be a fuse on the board bad--easy to find--
You can buy a pair of the chips on Ebay for less than 20 dollars
Let me know if you have questions--I have seen people who replace the board have new problems-cheaper and better to repair the one in the set.
I am here to help people--if this information helps you rate this solution--I do this here for free.
SD TECH
Nov 02, 2009 | Samsung PCL541R 54" Rear Projection...
RCA D52W23 Color Alignment. Blue,Red,and
Its problem of convergence board and need to be replaced. You can buy this board at Part Store.
Please replace the board if you have basic electronics knowledge or get help of tech person.
Regards,
Sep 19, 2008 | Televison & Video
Screen is pinching
you may still have a fl231 fuse type problem. I would first suggest resoldering the flyback connections. dince this happen ever so often it possible a connection problem. If i had it in the shop i woould chek the flat ribbon connectors also. convergence is controled by three board, convergence power, convergence amp and small signal board. since it pinches this is indication of interuption of convergence power supply. the auto convergence not working. is a symptom of small signal board issues. the small signal board requires specal interface equipment to download data off to place on new board. or the sensors arond the screen has failed.
Dec 10, 2008 | RCA R56WH76 Projection Television
Hitachi 43F300 convergence
Do not replace whole convergence board.Because convergence data stored in old board cannot transfered to your new board.Means in your new board there is no convergence data.Unless you have the service manual and know how to get service menu.
I believe if you have convergence problem one of your IC (STK) is bad along with couple of small
Value resistance.
Dont forgat to Rate!
Good Luck
Dals123
Oct 21, 2008 | Hitachi 43F300 43" Rear Projection...
Hutachi 43inch rear projection 5 yrs old
Hitachi Convergence
Check out the Convergence Gallery. If you see the colored outlines or color shading as in the Gallery, you have a convergence problem.
The repair for a Hitachi requires the replacement of the defective IC or ICs and any damaged or smoked resistors. Some models don't have a separate convergence board and the board is not usually available for the ones that do have a separate convergence board. Usually there is little alignment required after the repair. If you play with all the adjustments before the fix, hours may be spent re-aligning.
If you change the original ICs with substitute "new and improved" parts that are talked about in the blogs, you will probably create problems. Use the original ICs and resistors.
Don't monkey with it.
This is a delicate and difficult repair. If not done by someone with some electronic repair experience, the TV will likely end up as junk or cost considerably more for a tech to fix the damage done.
If you live in Calgary, call me. If elsewhere, find a competent tech.
easyab
Jul 30, 2008 | Samsung HCN4226W 42" Rear Projection...
Rca d52w19 convergence hell
Did you replace the convergence board or the convergence power supply board? usually one color will be a problem with the convergence board and more than one color means the convergence power supply is the problem. Ebay isnt a good place for boards as you never know if the board is good. You can get the convergence or the convergence power supply boards at the following link along with free shipping and tech support.
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
New Convergence board but need help adjusting convergence still
If the new sub board didnt fix the problem you will need a new convergence board as the sub deflection boards with the ICs only powers the convergence board. thats a complete seperate board. Let me know if you need more assistance.
May 22, 2008 | Samsung HCM5525W 55" Rear Projection...
Sony KP-51HW40 Convergence issue
First if the auto convergence isnt working you need new Ics . two of them.I am part owner of a site that sells the ICs and provide free tech support by way of online instant messaging and we include detailed instructions on how to do the repair yourself. We also have a service where you can send your board to us and we will install new ICs and all new Convergence resistors and ship the board back to you. Or we sell remanufactured boards. I would recomend replacing the two ICs as that would be the cheapest rout the ICs arent exspensive , but will require de-soldering and soldering in the new ones. Here is alink to the site. You can go and send them a request for information by clicking on the contact us link in the lower left info box. Someone will get back with you quickly just leave your model number and what you would like info on.
Apr 10, 2008 | Sony KP-51HW40 51" Rear Projection...
Convergence problems with Samsung PCN5425R.
that model has a convergence board, how ever it may not be the conversgence board as the convergence ICs are not on the Convergence board itself, and usually thats what goes wrong are the actual ICs. However this is an easy repair the parts are inexpensive and I can post a link where you can get new ICs and they provide step by step instructions with pictures so you can do the repair your self. Let me know if you would like the link.
Mar 30, 2008 | Samsung PCN5425R 54" Rear Projection...
D52W19 convergence problem
Since this is an intermittent problem, I would first check the convergence board for cracked solder connections or other loose connectors (or leaky capacitors and diodes). If you still cannot find the problem, you will most likely have to replace the convergence board assembly p/n 264103. It can be quite difficult to re-converge if you do this unless you swap the two eeprom IC's on the original board to the new board IK210 and IK211 then Go Into The Service Menu Geometry And Set V Slope And H Position, Save, Then Back Out To the Customer Menu And Run AutoConvergence.
Dec 22, 2006 | RCA D52W19 52" Rear Projection Television
GE 46GW947 46" Rear Projection Television Logo
23 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
