Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Briggs mod 31p877 19 hp intek boggs down when hot
Briggs mod 31p877 19 hp intek on polun 46 rider;engine starts good,runs good till hot.choking keeps from dying and brings revs back up till next boggdown.fuel system and carb clean,intake valve lash.004,exaust lash .009 .cooling not obstructed and fins clean
  • 32 Answers
SOURCE: 22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
Posted on Jul 20, 2009
SOURCE: i have a briggs 20 hp intek , it run about 15 or
Believe it or not, I had this same thing happening on our L120 John Deere. Turned out to be a plugged gas cap vent! At first I couldn't believe it but i resolved it with my air compressor. Now I always make sure the vent is clean and have had no problems since.
Posted on Aug 14, 2009
SOURCE: 21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
Posted on Nov 07, 2009
SOURCE: Briggs and Stratton 20 hp intek runs great idles
Check the vent on the gas tank if it is blocked it will cause a vacuum in the tank thus starving it for fuel
Posted on Aug 02, 2010
SOURCE: 26 h.p. b&s intek engine. runs fine for a
Hello dkev65,
Did you get a response to your question ? I have a brand new 2010 model Husqvana with this engine and I have the same problem.
Regards
dd57
Posted on Sep 27, 2010
Have 22HP BS V-Twin in a 2010 Husqvarna rider w/25 total hours. Recently won't cold start without priminig. It will crank and crank cold til the battery runs down. A shot of starting fluid and it runs...
nearly all petrol mower engines need to have the 'choke' engaged to start from cold. This enriches the fuel mixture, and is similar to priming. If there is a prime 'button' then you will probably have to use this all the time. This is normal.
However, you should check with your dealer to see if this is an unusual situation.
Aug 27, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Motor will run fine with the choke on , but push
The governor is out of adjustment. It will be located on the side of the engine with a rod pointing downward with a weight
Apr 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Oct 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 20hp twin cylinder runs only with full choke
Had one on my saw mill had this problem as well Try pulling bowl off bottom of carby as the float can get **** with old fuel especially ethanol fuels as they attract water bowl is normally held on with one center screw on bottom of carby. Note always turn fuel off and let engine run out of fuel as this stops goop from building up in carby
Sep 04, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Have to hold chocke out to keep it running
sounds like the needle and seat is dirty within the carb
Aug 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
320 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
