Question about Mitsubishi Televison & Video
When i plug in my tv power cord the lamp light begins to blink and the when i press the power button it also contiues to blink. what is wrong with my tv?
  • Mitsubishi Master
  • 6,993 Answers
your TV is having a power problem. The power board of your TV is defective, That's why it will not power on and continue to blink.
Take care.
Posted on Aug 04, 2010
Tv will not power up
Press the TV button or ON/OFF button while remote is in TV mode and there's a source of power to the outlet or outlet strip.
Make sure the TV is plugged in.
You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or flashing section below for more information.
When you first plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when the TV is unplugged and plugged back in. The TV can
only be turned on after the Power indicator goes off.
Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else, such as a lamp.
Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 53.
Multiple TV Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Setup Options, then Advanced
Options, then Multiple TV Setup. Choose TV (default).
Sep 26, 2013 | RCA Scenium M50WH187 50" HDTV
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
My laptop shuts off after i turn it on.why
Does your laptop even begin the boot process where it displays stuff on the screen? Do you hear fans running, disk drives running, see lights, hear the cd drive click once and notice a light that comes on the cd drive door briefly when you press the power button? If not you computer either has a bad power cord, a bad dc power jack where the power cord plugs in, a bad mother board or static build up. 1) lets eliminate static buildup by removing the power cord and the battery then press and hold the power button for 30 seconds. Then replace the power cord but not the battery and hit the power button. If it boots up you had static build up. 2) Take an ink pen and put in in the slot where the power cord plugs into the laptop, if it wiggles loosely then your dc power jack which is soldered onto the motherboard needs to be replaced. 3) If the power jack is tight and when you plug in the power cord if you don't see any lights or hear a fan, disc, cd drive, then you can almost bet your power cord is bad. 4) If the power cord is ok then you have a mother board issue. Normally motherboards will give some beeps or constantly blinking lights when you plug in the power cord and try to boot up. These beeps or blinking lights will tell the technician what is wrong with your computer.
Mar 19, 2012 | Acer Aspire One Netbook 8.9" Notebook
Red standby light is blinking 8 times on my sony bravia tv
I simply followed these steps with a surge protector
press the power button and hold up
Then hold up with the power button
then let go of up
and let go of power
worked with my kdl-55ex720
Jul 16, 2011 | Sony 55 KDL55EX720 3D LCD TV
The screen does not turn on only the green led below turns on then star to blink
This might be cause by lamp error. Here's possible solution. Unplug AC cord for a while.
Then follow process as below. 1, Plug AC cord 2. Press Vol (-) + TV/Video Button at the same time 3. While holding above button, Power On by pressing power button. 4. Either "K" or "K123" will appear on the screen. This indicate that you enter the service menu. 5. The Press Button Vol(-) + Channel Up button to go to menu page. 6. Find Lamp Error page. 7. Lamp error data should be "0" zero, if not change to "0" 8. After changing the data, power OFF by Power button. 9. Unplug and re-plug AC cord 10. Power On to check if power resume.
Good luck Jheremiel
May 16, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    Replaced ink cartlidge and now wont print
    After replacing the ink cartridge you should print the alignment page to work product perfectly.
    Follow the below instructions to print alignment page:
    1. Turn on the HP PSC 1200 or 1300 series product.
    2. Disconnect the USB cable from the all-in-one.
    3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
      1. Press and hold Cancel .
      2. While holding Cancel , press On .
      3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
      4. Press Cancel again.
      5. Press Copies .
      6. Press Paper Type .
      7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
    4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
    5. Reconnect the USB cable.
    If the issue still persists, perform semifull reset by following the below instructions
    1. Unplug the power cord from the wall outlet.
    2. Unplug the power cord from the back of the all-in-one.
    3. Wait 30 seconds and plug the power cord back into the wall outlet.
    4. Plug the power cord to the back of the all-in-one.
    5. When the lights begin to flash, press and hold the On/Resume and Number of Copies Buttons.
    6. When only the On/Resume light is flashing, release the buttons.
    7. When the On/Resume light is steady, the reset is complete.
    Oct 12, 2009 | HP PSC 1350 All-In-One Thermal Printer
    I have RCA HD50LPW167 DLP TV with NO Sound and NO Audio. The LED blinks when I turn the TV on but that's all it does. Took it to the local RCA authorized repair shop and they told me that the digiital...
    Still sounds like a lamp:
    TV won’t turn on
    • Press the TV button or ON/OFF button while remote is in TV mode and there’s a source of power to the outlet or outlet strip.
    • Make sure the TV is plugged in.
    • You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
    • Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
    is blinking or fl ashing
    • When you fi rst plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
    and then go off during the initialization of the TV. This happens only when power is reapplied to the TV. The TV can only be turned
    • Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else, such as a lamp.
    • Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
    remote control solutions on page 84.
    Remote Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Connections, then Special Features, then
    Remote Setup. Choose TV (default).
    Power indicator is blinking or fl ashing
    If the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on. If the TV doesn’t turn on after 5 minutes and
    then the light blinks steadily for one minute, one of the following options is possible:
    • Lamp door may be open.Face the back of the TV. Locate the door at the bottom of the TV and close it. Turn off the TV and turn
    back on. The lamp should turn on.
    You can easily replace the lamp yourself by following the lamp replacement instructions. If your TV is still covered by
    the warranty, call 1-866-723-6486 to receive troubleshooting assistance and a lamp replacement.
    • If your TV’s warranty has expired, call 1-800-338-0376 to purchase a lamp replacement.
    To order the correct lamp, you’ll need to know your TV’s model number, serial number, and lamp type—this
    information is listed on the Service Model Number sticker (example of the sticker is shown above). Face the back of
    the TV. The sticker is located on the right side of the TV.
    Hope this helps :)
    Mar 07, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
    Mitsubishi 62" dlp wd-62525
    The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
    Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
    Power button blinking green
    disconnect the power cord overnight try it if ok change power cord cheers
    Dec 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
    Televison & Video Logo
    11 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
