Question about Malber WD1000 Front Load Washer/Dryer
Leaking pressure hose - Malber WD1000 Front Load Washer/Dryer
I want to buy a hose #3 9 82115 00
Posted on Sep 28, 2008
    Genius:
  • 1,073 Answers
If the pressure hose is leaking replace it
Posted on Apr 23, 2008
My F09 and my E01 codes keep coming on in mid cycle and shutting down the cycle
F09/E01 are related codes.
LONG DRAIN: If the drain time exceeds 8 minutes without reaching reset level in pressure sensor, the valves are turned off and the drain pump will stop running. NOTE: Suds can cause delays in draining. Washer drains for 4 minutes, pauses 5 minutes, then tries again for 4 additional minutes of draining. F9E1 will display if washer does not drain. (Normal drain takes less than 2 minutes)
Possible Causes:
Verify that the drain hose is not blocked or kinked.
Make sure drain hose is not sealed into drain pipe.
Make sure the drain hose height does not exceed 96" (2.4 m).
Check/clean drain pump filter of foreign objects.
Check connections from tub to air trap, air trap to pressure hose, and pressure hose to pressure sensor.
See TEST #8 (Drain Pump) on page 19. Is pressure hose pinched, kinked, plugged, or leaking air?Is pressure hose pinched, kinked, plugged, or leaking air?Is pressure hose pinched, kinked, plugged, or leaking air?
Oct 03, 2016 | Whirlpool Washing Machines
Error code 13. Turned water on to machine and it leaked.
Try this link
it says the following:
E13 Condition Water leak in the tub or air leak in pressure-switch air hose Check/Repair The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems.
Shop Parts Outer wash tub, Air hose, Water-level pressure switch
Frigidaire Front Load Washer Error Codes Sears PartsDirect
Jun 09, 2015 | Frigidaire Washing Machines
How to repair power steering leak?
You need to first diagnose what is leaking. Most power steering leaks are in the pressure hose but not always. Pressure hoses will have screw on fittings and return hoses will usually just have spring clamps or screw type clamps on the end of the hose. Pressure hose most likely, return hoses 2nd, failing rack and pinion assy 3rd and pressure pump last. If its leaking from the bellows on the end of the rack and pinion the you will need a reman unit. Presure pumps are also remanufactured if thats what you need. hoses are replaced with new hoses or standard return hose for the return line.
Jul 12, 2014 | 2001 Ford Windstar
Have a craftsman 175psi 25 gal 3.5 hp fills up to pressure shuts down then pressure leaks behind what i think is pressure switch
Leak at pressure switch is an indication that the in-tank check valve is leaking.
Follow small hose from pressure switch to the tank (usually brass valve). Remove hose at the brass valve and check for leak there. If leaking replace valve with generic valve from ebay or WWw. grainger.com or use exact part (some valves can be cleaned, as debris can be lodged between seat). Good luck
Mar 26, 2011 | Craftsman Air Tools & Compressors
Our he3 elite keeps over filling and stops and beeps gives error message h & f
The pressure switch has not tripped 8 minutes after the water valves are turned on and the flow meter has detected about 10.5 gallons of water entering the machine. Either the pressure switch contact is stuck in the empty position or the pressure hose has air leaks or clogs causing the pressure switch not to trip.
Disconnect power then remove the screws attaching the top panel to the rear of the machine then slide the panel rearwards and off the cabinet. Locate the pressure switch at the right side of the cabinet.
Disconnect the pressure hose from the pressure switch then blow air down into the hose forcefully to clear it for clogs and check it for air leaks and kinks. Remove the pressure switch from the cabinet the do the same as for the pressure hose to possible free the stuck or welded contacts. replace the pressure hose if it has air leaks and/or the pressure switch itself if the contacts cannot be released.
Jan 06, 2011 | Kenmore Washing Machines
Can thee hose be fixed if it has a leak.
If the leak is on the OUTBOUND side that is towards the Nozzle, it CAN be repaired but for safety I would strongly recommend a new hose. Main reason being that the pressure generated in that hose will blow MOST joints you put in there.
If it is the input side then just get a hose joiner and install it.
Feb 07, 2010 | Karcher Hose Reel
Maytag performa overflows out of tub want stop filling
you either have a leaking water valve
or a pressure switch leak
does it fill when off.........if yes leaking water valve
if not its a bad pressure switch, a kink in the pressure hose, or a leak in hose, but if that were true you would have water before it overfilled
witch leads us back to a kink in the hose or a bad pressure switch
have you had service recently?
Oct 09, 2009 | Washing Machines
Subaru impreza 1993 power steering leak
YOU CANT USE A REGULAR FUEL LINE ON POWER STEERING AS A HIGH PRESSURE HOSE.BECAUSE POWER STEERING PRESSURE IS 1000 PSI.YOU HAVE TO BUY THE POWER STEERING HIGH PRESSURE HOSE IT HAS NUMBER OF PLIES MATERIAL WEAVES TO MAKE IT STRONG.IT WAS MADE FOR POWER STEERING HIGH PRESSURE.YOU DONT HAVE A BLOCKAGE .THE HIGH PRESSURE HOSE JUST WORE OUT.REPLACE IT .IT SHOULD FIX THE PROBLEM.
Sep 04, 2009 | 1993 Subaru Impreza
Power fluid leaks, profuslly!!!!!!
check the power steering hoses. from the pump.. there's a high pressure line...if this one gets a crack, it'll leak alot...it's under pressure, the return line is not under pressure but it can leak just the same... wipe the hoses down and run the car, you'll be able to find the leak... also check the pump housing...for cracks.
Hoses are available from local parts houses... be sure to refill with only recommended type of fluid...don't cross mix types.
Jul 01, 2009 | 1991 Cadillac DeVille
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
