Question about Lite On SOHR-5238S CD-RW Burner
I need help finding out why my computer says no burner connected when ive burned disc from my liteon driver before from windows and now when i go to burn it say connect burner when ive checked the connections and its connected
  • Lite On Master
  • 27,725 Answers
Sounds like a faulty electrical connection check all connections that attach PSU to your burner or go into administrative tools,computer management, device manager if yellow? uninstall or roll back then once you uninstall diconect from PSU then re attach re-install
Posted on Jul 27, 2010
I am trying to use the condre burner with windows XP. do I need a condre driver or software to burn cd's . Windows media player will not burn to the condre. Help
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=ead6bf3a1eb47ae6aabbbdeba60fd395&modelid=513308&q=Condre+Power+Disc+DVD
this is only a manual im not sure what software whether burning
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver once you have select update windows will ask where to find the driver and if you want to connect to the internet
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers if your computer came with a motherboard disk the driver could be on it
hope this helps
May 21, 2011 | Computers & Internet
Need to add drivers and probably need software for lite on combo 4816h- will need to put on flash drive to uploadto my pc.
im not sure what software you want?
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
hope this helps
May 21, 2011 | Lite On LTC-4816H CD-RW/DVD-ROM (Combo)...
It wont play any dvd disc
You should be install CyberLink PowerDVD Player and than try to play it.
Jul 23, 2009 | Lite On DVD+/-RW LITEON SOHW-1673S BGE %...
LITEON LVW 5001 doesnt recognize DVD's
Laser either dirty or starting to go.Try cleaning laser with commerical disc cleaner,put a drop of rubbing alcohol on brushing.Laser can be cleaned manually with a Q tip dipped in rubbing alcohol but this requires opening burner.If you do this MAKE CERTAIN ELECTRICAL PLUG IS PULLED,lasers cause nasty burns.
Some times the problem is just the brand of disc,some brands don''t work in Liteon's.
If laser is going the burner can be replaced.Most of the Liteon 5001's used Liteon 401s burners,411s or 451s dvd burners all will work.The dvd burners mount from the bottom PC burners mount from the side so they would have to be adapted,many PC burners won't work in these older liteons some freeze up the second you hit fast forward.
Jan 18, 2009 | Lite On LITEON 8X DVDRW +/- Burner
I need drivers for a dvd super multi
I have an LG super multi burner that worked great on my older computer with windows xp, but i just moved it to my new computer with vista and it will not accept the software. the computer will read discs in the drive, but it will not burn, it acts as if there is not disc in it to burn. what can i do?
Sep 24, 2008 | LG GMA-4020B Super-Multi...
LOST INSTALATION DISK
Hi, check here and you will find the drivers you need for your dvdrw. Thanks! /D
http://www.nodevice.com/driver/company/LiteOn.html
Apr 27, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
HP DVD 740e wont burn Dual Layers anymore!
Try re-installing the software associated with the burner, so it installs the necessary drivers and files needed for the burner to work according to your needs.
Also check the connections and cables... sometimes moving it around causes the cables to loose some contacts.
Hope this helps...
Feb 26, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Lite-on DVD R/W combo LH-20A1L BLO5 Blank discs not recognized
Have you checked device manager to see if you have a yellow checkmark on your DVD./CD drives? if ok, sounds to me like the maker of the LH-20A1l BLO5 either needs to fix your problem or replace it. The Nero 7 should enable it to work correctly.
Feb 14, 2008 | Computers & Internet
Dvd burner
First off do you have any burning software installed? Roxio or nero or the like? sonic record now? etc etc...
Sep 14, 2007 | Lite On LiteOn 16X Dual Layer DVD...
Lite On SOHR-5238S CD-RW Burner Logo
73 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
William Alequin
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
