Question about Symbol CS1504 Handheld Barcode Scanner
The scanner is no longer beeping while scanning, how do I get it to beep. batteries are new. It just stopped making sounds. It still scans.
5 Suggested Answers
  • 74 Answers
SOURCE: 3 Beeps after trying to scan
If you are receiving three quick beeps (all the same tone) before a scan the battery is low. If the scanner is more than two years old the battery may need to be reconditioned. It is recommended the battery be reconditioned once a year. The latest revision of the LS4278 manual is here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983404apdf&sliceId=&dialogID=134112767&stateId=0%200%2014115220
Print page 28 of 414 and scan the Battery Recondition barcode. The scanner will discharge the battery then charge it up again. It goes through this two times so you need to leave it on the charger a while for this process to complete. Hopefully this will resolve your issue. If not, you may need a new battery.
If the beeps are low, medium, high the procedure above still may work, but you might want to call Motorola for assistance. Sometimes hearing the beeps helps to diagnose the problem.
Posted on Oct 09, 2009
Testimonial: "you are AWESOME! that was exactly the problem. thanks man!"
  • 74 Answers
SOURCE: 4 beep error when scanning barcode
The four beep error is a communications error. Usually it indicates the scanne is not configured properly. If the scanner is connecting with the CBA-K01-S07PAR cable and you are using a PS/2 keyboard you should have scanned the IBM PC/AT barcode from Adobe page 56 of 342 of the LS2208 Product Reference Guide.
If you do not have a PS/2 keyboard attached and are using a USB to PS/2 adapter you should scan the IBM AT Notebook from that same page. If the scanner does not start working immediately you may have to reboot your system. If the scanner still does not work the CBA-U01-S07ZAR USB cable might be a better choice.
If you are not connecting with either of these cables and are still getting the four beep error a call to the Motorola support center may be in order. Their phone number is 800-653-5350.
Posted on Oct 23, 2009
  • 74 Answers
SOURCE: The LS 2208 scanner I am using will beep when idle
Clean the glass really well. Sounds like it's picking up a number when it shouldn't.
Posted on Dec 08, 2009
Yogger
  • 117 Answers
SOURCE: My symbol barcode scanner beeps 4 time while I try
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Posted on Sep 08, 2010
My canner ls4278 is making a sound and turnin red when i scan
It could be the scanner is not paired to the cradle. The scanner will be once for the barcode and then four times for the communication error. Make sure the cradle has power; it will pull power from a USB port. Scan the pairing barcode on top of the cradle. The scanner will give a high low high low beep and then shortly after give a short low short high beep indicating the radios have paired. If the scanner still beeps four times after doing this, the host type may not be set. If connecting USB scan HID Keyboard from the LS4278 Product Reference Guide.
Jun 10, 2014 | Symbol LS 4278 Barcode Scanner
How to program itouchless doorlocks
change master code
0 + * + default/old mastercode + new 8 didgit master code + #
when successful it will make a solid single beep if unsuccessful it will beep 3 times
enroll finger print at random no user ID
1 + # + master code + #
first scan place finger on the scanner and remove when the scanner light turns off
second scan replace same finger when the scanner lights back up you will hear a single beep if enrollment is successful
if scan fails you will hear 3 beeps
Jan 15, 2012 | Itouchless Bm003l Bio-matic Fingerprint...
I was in the middle of an order and the red scaning light still working but will not scan the product, I downloaded what was on the scanner and that worked, but still not getting a beep after scanning the...
Push and hold down the big button for a while until it beeps. This scanner has a feature to disable the confirm beep that gets activated if you hold down the scan button too long!
Regards, Alan
Oct 05, 2010 | Opticon OPN 2001 Mobile Data Collector...
LS3070 (ls3070-i000a) Handheld: My scanner stopped scanning. It beeps four times. ...
The four times beep means that there is an problem in the connection to the PC, please check the cables and configuration.
May 18, 2010 | Symbol LS3070 (ls3070-i000a) Handheld
Oct 05, 2009 | Symbol LS 4278 Barcode Scanner
Laser not working, screen won't show, beeps continuously.
i think i can help u with this, if u unscrew the unit and carefully unhook ur the cables in side then will see two Philips screws, unscrew them and unhook the display cable its on the side
now gently try to take the board out and put it back on then hook the display cable back and screw the board back and for the scanning
unhook and re hook ur scan cable that will make it work,i hope that will solve ur problem
Jun 11, 2009 | HHP Dolphin 9550 Barcode Scanner
Symbol ls 4000i not scanning
The first beep is a Good decode beep, the four beeps later are telling that the connection to your PC is not working properly.
Jun 07, 2009 | Symbol LS 4000i Handheld
LS2208 scanner not returning for multiple scans
It sounds like you need to program a Tab after each scan. You will need to download the manual from www.motorola.com so you can access the setup bar codes.
May 27, 2009 | Symbol LS 2208 Barcode Scanner
Scanner beeps. Laser is a dot instead of a line.
There is a problem with the scan engine. The dot is created when the mirror inside the scan engine stops oscillating. If your scanner is still under warranty send it back for repair or request a replacement.
Mar 09, 2009 | Microsoft Metrologic MS9520 Voyager...
RadioShack PRO-94 Scanner
is there a vista program avalib.for pro-94 pc-interface cable
Sep 19, 2007 | Radio Shack Pro-94 Scanner
Symbol CS1504 Handheld Barcode Scanner Logo
102 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
