Question about Yamaha RX-V650 Receiver
Yamaha RX-V650 won't power up - blue 'Pure Direct' light comes on
I have a Yamaha RX-V650. When plugged in the 'Pure Direct' blue light comes on, and nothing else. Tried using the power button, remote power button, verified the two fuses on main power board are not blown...
I suspect, but can't confirm a power surge when I was on vacation, but the unit is plugged into a surge suppressor.
Any suggestions?
  • 4234 Answers
SOURCE: Yamaha RX-V420 No power
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
Dan
Posted on May 12, 2008
SOURCE: my yamaha rx-v461 won't turn on
Check the main fuse
Posted on Aug 22, 2008
SOURCE: Yamaha RX-V630 Doesn't power on!
I have the same problem.
Posted on Sep 04, 2008
SOURCE: Direct TV remote code for yamaha rx-v463?
It is 30376. The trick to discovering, is to turn the receiver off, first. Then it will power on when you input mute/select 30376. Then you can program the DirecTV remote to adjust volume (in AV2 mode only or in all modes). However, it will only power up the receiver. It has to be turned off with the original remote or at the receiver itself.
Posted on Feb 22, 2009
ButtFuzz
  • 463 Answers
SOURCE: Yamaha RX-V650 receiver won't power on.
You've probably already tried this, but...
Disconnect power from the mains, remove lid.
Reseat all the low-power connectors in the unit.
Check the thermister on/near the main transformer.
Check capacitors on or near power supply for obvious anomalies (fattness, leaking, smoked, etc.)
Replace lid and, plug back in, do a rain dance and hope.
Posted on Mar 04, 2009
My receiver no longer produces sound to the speakers unless I push the "Pure Direct" button.
verify that the optical cable (or the tv optical output) is not the problem. try using a different audio source with optical output such as a cd player if you have.
Oct 05, 2015 | Yamaha RX-V673
How do I reset Yamaha rx-a4730 it won't turn on just blinks Manual says it is in circuitry protection mode
Yamaha RX-V650 won't power on - Service manual, repair and unlock ...
forum.eserviceinfo.com/viewtopic.php?t=59945
10 posts - ‎6 authors Posted: Sat Aug 29, 2009 1:26 pm Post subject: Yamaha RX-V650 won't power on ... When i came back from a holliday, my receiver won't power up anymore. .... isn't powered (no voltage on the base) when the receiver doesn't comes on.
Sep 12, 2015 | Yamaha Audio Players & Recorders
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
Cannot Power Up, Sometimes can
i had a real nice yamaha natural sound receiver and the relay that switched it on went bad a lot..... try the relay???
Apr 26, 2010 | Yamaha RX-V650 Receiver
'clicking' off a few seconds after turned on
Does the receiver work OK?
These are probably electromechanical switches (called relays) which yamaha uses a lot. They use electricity to connect/disconnect something by magnetic force and this causes the "clicks". It is used for example to connect the speakers to the output of apmlifier only after it has finished initializing to protect both the amp and the speakers.
When I turn on my RX-V465 I hear at least one click, it is probably connecting power to the amp. When turning it on with Radio button on remote I hear 3 clicks over 2-3 seconds.
So these clicks are normal and nothing to worry about. They occur also when you switch to the PURE DIRECT mode.
Feb 27, 2010 | Yamaha RX-V463 Receiver
Intermittent output from speaker channels
i would swap speakers from side to side and check if it is the speaker of the amp. good luck
Feb 10, 2010 | Yamaha RX-V650 Receiver
Best way to hook up TV with one HDMI to blue ray DVD and RX-V465 receiver with Direct tv
Has Direct tv STB HDMI output?
Best is to connect all your sources (BD, DVD, STB, PS3) to yamaha receiver and connect yamaha hdmi-out to TV's HDMI-in.
Dec 29, 2009 | Yamaha RX-V463 Receiver
Yamaha rx-v650 wont come out of standby, fuses ok switchmode ok no display at all fault pointing towards microprocessor problem.
There is a common psu problem occurring on a few Yamaha models from ~4 yrs ago. Any Yamaha dealer should know what it needs. probably the mod component in the stby supply.
Doubt it would be a micro fault.
Oct 28, 2009 | Yamaha RX-V650 Receiver
Yamaha RX-V650 Receiver Logo
326 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
