Question about Linksys WRT120N Router
Only 1 pc can get to the internet using a WRT120N router
    Sergeant:
    Champion:
  • 301 Answers
You can get the others get the internet like 254 host you can ,but is not recommendable depends on speed you have , reset the rrouter behind the has a button , press like 20 seconds and try again to connect
Posted on Jul 27, 2010
5 Suggested Answers
govinda123
  • 2264 Answers
SOURCE: unable to connect to the internet with my linksys
If you connect the computer directly to the AT&T modem , it work. That means the modem is working properly.
AT&T is DSL connection type. the DSL connection works on 2 different modes. 1) DHCP 2) PPPOE.
Now you will need to connect the modem and the computer to the router. open the set up page of the rotuer.
The set up page is the page where you can change the settings of the router.
According to the type of internet connection you can change the settings of the router
Click Here for step by step by instructions
Posted on Feb 16, 2010
  • 126 Answers
SOURCE: WRT120N how to enable wireless option
Wireless should be enabled by default on the router. Check whether you have switched on wireless on your laptop.
Please rate if helpful.
Thanks
Posted on Apr 14, 2010
  • 425 Answers
SOURCE: internet disconnects after about an hour with
You are having a conflict with your modem try unpluging everything and then plug in the modem first let all lights start blinking then plug the router in and let all the lights light up on it then turn on computer and see if this helps router are very peticular about there setup.
Chris Thrash
B52Computers
Posted on Jan 21, 2011
shademand
  • 114 Answers
SOURCE: I'm using TP-LINK TD-W8101G ADSL
Unfortunately, you can't use two routers together in that manner. You must have a device in between them such as a switch or bridge or you'll have to disable the DHCP server settings in the second router. The second router then pretty much becomes a switch you may then use all the ports on the second router with the exception of the WAN port it must remain unoccupied. However, if you need wireless connectivity in another location far away from your main router then your only solution would be to indeed purchase an actual access point/bridge device
Posted on Sep 06, 2011
Can i use my WRT120N on neighbors WiFi Network
Hello there,
You cannot use this router to connect to your neighbour's router wirelessly. It is possible to share your neighbours internet connection with this router, only if you run a cable between. You will need a Range Extender or a Wireless repeater for this purpose.
Feb 28, 2014 | Linksys WRT120N Wireless Router
What is the security code for the WRT120N router
IF you don't know the password to your router you will need to reset the router by sticking a pin or toothpick into the hole on the back label reset and re-configure your router.
Dec 02, 2012 | Linksys WRT120N Router
How can I assign a pasword to my linksys cisco wrt120n so i don't have to use the pppoe on my computer
if you have pppoe on your computer, you need to input your username/password on your linksys router. so that you wont have to input anymore to your computer whenever you connect to the internet.
Jul 13, 2012 | Linksys Cisco-Wrt120n Wireless-n Router...
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
I'm using TP-LINK TD-W8101G ADSL Modem Router to connect internet, I'm trying to connect it with Linksys WRT120N Router Wirelessly. I want to use WRT120N as access point to extend TP-LINK...
Sep 06, 2011 | Linksys WRT120N Router
I want to connect d'link 2640t to linksys wrt120n, hi i have a DLink 2640T modem+router with IP 192.168.2.1, i want to extend my home network so i bought a WRT120N router with IP 192.168.1.1, i am...
This is too involved to just post your router settings. I would recommend reading up on how to "cascade" your router or to make your Modem/Router act as a bridge.
The dlink will need to have its DNS disabled and have the Linksys do the DNS. Then the LInksys will be using the Dlink as its host. you may be better off seeing if you can make the dlink run in Gateway mode instead of router mode.
Then see how to implement the cascading router with your particular situation and WAN IP.
Jan 02, 2018 | Linksys WRT120N Wireless Router
I have a Linksys Cisico WRT120N router, I used it to provide wireless signal to i PC, 1 mac desktop, 1 dell laptop running vista, and 2 roku boxes, 1 standard, and one XD. We are experiencing numerous...
If you are saying like 5 devices? Wonder if your internet provider ia allowing that? Sometimes they do have a limit and if you go over that it will lock up or fail...lose signal. Not saying you are doing something bad but maybe you do have a limit of devices allowed. If this is the problem leave one device off or switch off if not needed.
Jan 06, 2011 | Linksys WRT120N Router
I have a flashing icon on my WRT120N linksys router and when i connect my dsl modem to it, i have no internet connection. How do i fix this?
  1. check the line has internet service enable (telephone provider),
  2. check the microfilters on each telephone plugs
  3. check the dsl light stays always on. if not is a line/provider service problem.
  4. enter the router webpage.
  5. configure the user and password internet acess codes. (check the internet provider for your internet account)
  6. check the internet light turns on
Nov 06, 2010 | Linksys WRT120N Router
I have 10 computer.i want to connect it to the
u have to connect all the PCs to the HUB first...then connect the Hub to the Router(broadband modem)...u need to first establish a connection to the internet serivce provider by entering the necessary IP address/subnet mask/gateway address etc in each PC...
Note each PC will have a different IP address
PC1 - 192.168.1.5
PC2 - 192.168.1.8 etc etc...not necessarly in the order mentioned above....
the rest of the settings will remain the same in all PCs
refer attached word doc
reg
pls let me know if this was helpful...leave a feedback...
Jun 16, 2010 | Linksys WRT120N Router
Thanks
Apr 13, 2010 | Linksys WRT120N Router
Linksys WRT120N Router Logo
106 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
