Question about John Deere 40 In. Aerator-spreader
The very first time I used my John Deere 40 inch aerator-spreader (buyers remorse) the weight tray jumped off of the hopper assembly pin and it crashed into the hopper and damaged the moving part that churns the seed/fertilizer that goes into the hopper. How do I fix my aerator-spreader and modify it so the weight tray will stay in place once it gets repaired?
SOURCE: I have a Scott Rotary Fertilizer Spreader. When I
If the wheels turn( that is you can push the spreader easily) but the vertical shaft that spins the broadcasting plate doesn't, seems like the gears connecting the axle to that vertical shaft are worn; but if the wheels just slide along the gropund without turning then it would seem something right under the bin is keeping the verical shaft from turning. But I'm NOT an expert; I'm looking for an answer myself,
Posted on Mar 16, 2009
SOURCE: JOHN DEERE TRACTOR - MODEL A - SERIAL 642202 CLUTCH REPAIR
Try the John Deere web site, I think they will be able to help. donnyb60
Posted on Mar 21, 2009
SOURCE: Model 300 runs out of fertilizer
Since I didn't have a manul, I downloaded one from Scott's and used that to calibrate the spreader which was out of calibration.
Posted on Apr 09, 2009
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
Wheelbase on 950 john deere tractor
use a tape measure and you will find out .
Sep 17, 2016 | John Deere Garden
I have a John Deere hydro 165, Kawasaki 12.5 ,what oil does it use?
Most all Engines used in warm climate such as mowers etc.. Use standard weight SAE 30 but colder climates machines such as snow blowers etc. use any good quality mili viscosity oils 10-30 is an all around one..good luck a little higher such as 10-40 for high hours used machines..good luck..
Aug 25, 2015 | John Deere Garden
JD R-1 spreader controls
www.deere.com
Ask them, they made it.
Aug 18, 2013 | John Deere Model "r" Manure Spreader...
Assembly instruction manual for blue hawk spreader
That is a Lowes special item. I would go to Lowes customer service and see if the can copy one from another unit that they have.
Jul 07, 2013 | Blue Hawk 100 lb Capacity Tow-Behind Lawn...
I have john deer sabre 18 horse i have a snow blade but cant get on right
My name is Dane and I'll try to help you with your problem. I have given you the basic instructions here for mounting most john deere snow blades.
Here is a link to the parts diagram for the blade too.
http://www.searspartsdirect.com/partsdirect/part-model/Sabre-john-deere-Parts/Riding-mower-tractor-Parts/Model-15538G/1828/1509200/10060752/00034
You need to remove the mower deck from the machine, and you may have to remove the front bumper as well.
First, install the mounting brackets on the tractor. Align the holes in each mounting bracket with the holes in the tractor frame. Install using the kit that comes with the mounting bracket. Don't tighten this yet.
Next you should install the pivot support. Insert the pins on the right and left hitch plates into the notches on the mounting brackets. Install the pins and tighten the screws on those mounting brackets now.
Next you should Install the blade. Align the holes in the pivot support with the second holes from the end of the push channel assembly. Insert the channel pin and washer and secure with the spring locking pin.
Install the lift handle. Slide the lift handle rod into the end hole in the push channel assembly. Insert the lift link pin in the pivot support bracket into the lift handle rod. Add the washers and locking pin.
Now, Iistall the blade pivot rod. Either end of the blade pivot rod goes through the blade pivot shaft. The other end goes through the lift handle tube. Secure both ends with locking pins.
Lubricate the lift handle rods and pivot points.
Install the rear tire chains and wheel weights.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thanks! Dane
Dec 03, 2010 | John Deere Garden
Error code
Yes it can be fixed, just have to fond out if a wire got broken or disconnected. The control may have gone bad , but it doesnt happen very often.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Feb 06, 2010 | RTO Buyers Salt Dogg Suvpro Tailgate...
Bushings
They don't have to be made by the same company that made the aerator. Take one bushing off and visit Ace or Home Depot. I would replace them all at the same time. But all you need to do is find the physical match and go from there.
Nov 02, 2009 | Brinly-Hardy Brinly Hardy Company 40" Tow...
John Deere 40 In. Aerator-spreader Logo
78 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
