Question about Serif Digital Scrapbook Artist 2 for PC (DSA2USMBRT)
Tab not open to is full
Hi
I am new to( DIGITAL SCRAPBOOK ARTIST 2) The problem i have.is I Was following the tutoral on line step by step on how to curl a photo corner
I made the triangle and circle .I grouped a circle and triangle then i copied them Then with one group i went to tab ARRANGE,JOIN, ADD the i grouped the other triangle and circle then i went to ARRANGE, JOIN , SUBTRACT.
I then put the add image across the corner of my photo l wanted to curl.
I selected the photo went to sissies tab i used the shift key and dragged a straight line across the corner the i clicked on the piece i did not want
Then the tut oral said select corner press **** and select photo then go to ARRANG,JOIN and ADD
I could do the first two commands but the ADD would not high light so i could not go any farther
I hope all this makes sense and i would be very grateful if you could let me know were i have gone wrong. THANKING YOU EDNA.
Need digital copy of SERIF DIGITAL SCRAPBOOK ARTIST 2
Maybe the best thing is to contact Serif & see if they will allow you a free download of digital copy of this software. I purchase Serif software online at their site. I purchased selectively but only when they have 50% off prices, had no tech. problems in downloading from their site. Do not receive discs though doing it this way. But I backup all downloaded data at least to a few drives.
Nov 12, 2013 | Serif Digital Scrapbook Artist 2
How do I connect my Sylvania scrapbook to wifi
Step 1:
Boot up the Sylvania scrapbook by pushing the manual switch below the screen. Push the F9 key to turn on the Wi-Fi on the device.
Step 2:
ignore this step my bad
Step 3:
Select the little wireless icon in the toolbar at the bottom; it looks like a small computer. Choose the "Wireless Information" tab. This will show the online status of the device, as in whether it has connected to the Internet. If you have checked the box beside this option, this tab also notifies you when new networks are available. If the status shows that you have connected, skip to Step 6.
Step 4:
You may need to add your wireless router manually in the setup. Do this by choosing, "Add New." Obtain the necessary setup information from your wireless Internet provider. If you have an encrypted network, you will need to fill in that information about your router.
Step 5:
To configure the wireless setup further, click on the name of the wireless network. Click on "Advanced Settings" and adjust your connection choices; this tab determines the order of connection if there is more than one network available. Another important setting on this tab is the "Allow Windows to configure my wireless settings" option. Check that box.
Step 6:
Click the "Internet Explorer" icon on the desktop. If you are online, you will pull up the Google homepage.
Dec 26, 2012 | Computers & Internet
Software disc will not load automatically. Autorun and setup features of WINDOWS 7 won't help either. What am I doing wrong? Please advise.
when I try going in to it, it come up
This application has requested the runtime to terminate it in an unusual way
Aug 03, 2011 | Serif Digital Scrapbook Artist 2
In photo lab, tried to get rid of dust and scratches to photo, clicked on button but photo only changed for a short time. Used sliders for dust etc but again only got temporary changes, what am I doing...
when you make the changes you must save the file for them to take effect. always save as a different name to the original just in case you need to go back to it.
Jul 03, 2011 | Serif Digital Scrapbook Artist 2
I purchased the item listed below as a download in October last year. It never seems to work properly. I have reinstalled it many times but I get a box up saying I need to reinstall. I constantly lose...
Sounds like you need the latest patch which fixes a number of known issues..
Read about it here. http://forums.serif.com/showthread.php?t=66785
Download the patch here http://www.serif.com/downloads.asp
Scroll down about half way to Digital Scrapbook and click download button on the right.
Save it to your desktop then doubleclick it to install when downloaded.
Hopefully this will fix most or all of your problems with this SW
Mar 21, 2011 | Serif Digital Scrapbook Artist 2
I have just purchased my scrapbook artist 2 CD but am unable to load it on to my laptop. I get a page which has one box and ''autorun'' under it. I have tried to click on it but it comes up with another...
hi This issue can be caused by any of the below possibilities
1. File is corrupt, bad, or missing
2. File is not designed for your version of Windows.
3. File is a virus, worm, or other malware file
4. Hardware incompatibility
i suspect your problem to be /2or4 .silly question does it give your particular windows as one of the designates for your program.if there is hard ware incompatability you could try if you have vista orwindows7 to make you program compatable. hope this helps.
Aug 24, 2010 | Serif Digital Scrapbook Artist 2 for PC...
I have 2GB clip and every time I download some
Hi there !!!
When you say every time you download some files and if it says UNKNOWN. Then i would say the ID3 TAGS could be an issue.
This issue occurs when information in a track's ID3 tag is missing or incorrect.
ID3 tags
allows information such as the title, artist, album, track number, or other information about the file to be stored in the file itself.
In order to fix this up. Kindly follow any of these steps..
Step 1:
1. Open Windows Media Player.
2. Under Library, look for the file to be edited.
3. Right-click the file, then select Advanced Tag Editor.
4. Enter the proper data for the fields available (i.e., Title of the track, Artist Name, Album Name, Genre, Track number, etc.)
5. Click Apply then OK.
Step 2:
Using Windows Explorer
1. Look for the location of the file.
2. Right-click on the file, then select Properties.
3. Click the Summary tab.
4. Click the Advanced >> button.
5. Look for the information you want to edit under Property.
6. Click the space under Value to edit the information.
7. Click Apply then OK.
Feb 02, 2010 | SanDisk Sansa Clip MP3 Player
Where do I find the key code to install
On a sheet of paper packaged into the retail box?
On a sticky decal on the back of the plastic CD-ROM cover?
If you cannot find either, take everything back to the retail store, and get them to give you a different copy, and to open it, to show the key-code to you.
Nov 18, 2009 | Serif Digital Scrapbook Artist for PC
ID Number required for downloading Digital Scrapbook Artist
i beleave you need to buy the software to get the id number, using your own id or social security number on such question is not recommended.
Dec 09, 2008 | Computers & Internet
Serif Digital Scrapbook Artist 2 for PC (DSA2USMBRT) Logo
178 people viewed this question
Top Serif Computers & Internet Experts
Martin Murray
Jax Planet
Jax Planet
Michael Vincent Cruz
Are you a Serif Computer and Internet Expert? Answer questions, earn points and help others
