Question about Sport & Outdoor - Others
I have a Lawrance Airmap 2000, purchased in 2008. It ha started to completely malfunction. When starting with powedr switch, it goes to normal "warning" page for about 10 seconds, then recycles to start -- and repeats without end. It will not power down except by pulling batteries or diconnecting from panel power sosurce. Memory chip says Copyright 2005. Does this need to be returned? If so please give me a return authorization number. Thanks. hierony@gvtc.com
  • 11,800 Answers
I assume you have removed the memory card, faulty ones can mess up the system . In that case all points to a corrupted firmware. This can't be fixed by a user so the unit must be returned. For that you must contact the Factory Customer Service Department, use the following U.S. toll-free number:
800-324-1356
 For Canada use this number:
800-661-3983
Posted on Jul 27, 2010
Temperature sensor on 2007 Malibu Maxx LT location
Lumina V6, 2000 model after starting 5 to 6 mins temp gauge goes up slowly. Cooling fan is on. Coolant ok. If stopped the car and started again gauge needle comes down quickly to normal and then runs normal at any speed. It happens only first starting. I am suspecting temperature sender malfunction. Could not see the temp switch position to check its connection.On earlier models it is located directly under the thermostat. But if its bad it should throw a code making your check engine light come on. Sounds more like a thermostat problem. Even if its a new one they can fail.
Sep 30, 2016 | Cars & Trucks
Intermittent starts, battery good, altenator good. Car works fine for two weeks then next morning no start, then 2 days later,starts up fine. No other electrical malfunctions at all...when turning key on...
ecu is taking up more voltage as a back up reserved. Try removing the battery once it is loaded in the evening and put it back in the morning and try to start.Trial and observation will pin point the main cause.
Aug 16, 2011 | 2008 Jeep Cherokee Grand
Car is stuck in park,
IT MAY BE BRAKE SWITCH UNDER DASH SOME TIME WIRE BRAKES THERE AND OR SWITCH IS BAD OR LOCK OUT SWITCH ON SHIFTER IS DOING THIS HOPE THIS HELP THAT IS BRAKE LIGHT SWITCH ON PEDLE UNDER DASH MAKE SURER YOU HAVE POWER THERE
Sep 12, 2009 | 2008 Dodge Avenger
Lowrance AirMap 600C won't lock on satellites
Reset the AirMap 600:
1. Turn unit off
2. Press and hold PAGES and PWR until you get the "warning, do not rely..." message and then release the buttons.
If it still won't acquire position, install the latest update from http://www.lowrance.com/en/Products/Aviation/AirMap-600C/Downloads/AirMap-600C-Software-Update/.
If it still won't acquire, and it has a clear, unobstructed view of the sky, and the batteries are good, there is a malfunction and it will require service or replacement.
Jul 13, 2009 | Lowrance Iway 500c GPS Receiver
Shutter malfunctioning
no...return it for repair or replacement.  It may simply have dirt in the lens cover.  Digital cameras do not have shutters.
Mar 12, 2009 | General Electric E850 Digital Camera
Lowrance 100 works lowrance 500 dosen't [dropped] swap chip?
You cannot use a chip from the AirMap 500 in an AirMap 100. The AirMap 100 is not compatible with the mapping used with the AirMap 500 and the AirMap 100 does not have a memory card slot.
I suggest you use the AirMap 100 while you think about getting the AirMap 2000 or some other newer aviation GPS unit.
Jan 04, 2009 | Lowrance 5300C GPS Receiver
Ignition key turns on but car will not start
I suspect the ignition switch is malfunctioning.
Nov 19, 2008 | 2000 Ford Focus
Does not agitate or spin - fills and drains - checked belt & pulleys seems fine
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Fridge not cooling...tested evaporator fan
check door switches
when you open the dorr does the fan normally stop then on closing start again
could be door switch fault
Jan 26, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Sport & Outdoor - Others Logo
35 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
