How to find the exact location of an open access point? If I connect to an open wifi network, is there anyway to determine the exact location (street address) of the access point (maybe some type of streetview web site, I do have net stumbler installed.
  • JOE Jul 27, 2010
    please read notes carefully and fixya's comment
    before responding
    thank you
  • 922 Answers
If the access point has Internet access go to http://www.spyber.com/ and get the location of the router/modem it uses. (Usually the access point is the router or very close to it.)
You can also Google "wifi hotspots" and see if they match the ones you have found.
Of course the most exact method is the most difficult. Use your favorite WiFi sniffer on a notebook and go "war driving". (I prefer "inSSIDer" since it is free). An external WiFi adapter with a high-gain omnidirectional antenna would definitely help.
I hope this helps.
Posted on Jul 28, 2010
  • 3,083 Answers
Here's a good discussion of things you can try, and what you can do. Some of the answers may give a clue to the street address, but I think you'll have to kind of guess that. Most of those programs give the IP address, and that's all you can expect. Here's the blog:
http://forums.whirlpool.net.au/forum-replies-archive.cfm/539315.html
    Guru:
  • 632 Answers
Not really unless you have good equipment to trace/locate where the signal is being broadcast from, The only way to actually trace an WIFI network access point is to use equipment used to locate transmissions.
Would cost too much for the equipment for you to even consider it.
Sorry.
Posted on Jul 27, 2010
  • 749 Answers
Really hard to do unless your traveling with your laptop, netstumbler or any wireless software will tell you when your getting close. you might need to make a perimeter around the weakness of the wifi signal to pinpoint the area, which still will not tell you the room it's eminating from if inside a building.
Regards..
How do i connect hp 1050v compaq laptop to wifi
Compaq Evo n1050v Notebook PC Overview
I strongly suggest visiting the above linked page and determining exactly what model in the 1050v series you have. As stated on the linked page, some models don't have a Wireless Network Interface Card (WNIC), just the ubiquitous 10BaseT 10/100 (Mbps) NIC using RJ-45 jacks and plain old CAT5 Ethernet cabling.
If you're having trouble determining whether or not your model is one that does have a WNIC, check the strip of plastic above the keyboard and the front side of the laptop's bottom section for a light indicating the status of your WiFi radio. Your laptop, if it has WiFi capabilities, will use an indicator light shaped like a vertical pole with a small ball on top emanating three waves outward to the left and three to the right.
If the radio is disabled for whatever reason, it will not light up. If the radio is on but you are not connected to a network, it will glow orange. After connecting to a network successfully, it will glow blue. At no point will this indicator light flash unless something is terribly wrong.
Assuming your specific model of laptop has WiFi connectivity, then to enable the hardware you'll need to download and install the requisite drivers (if you haven't already), and lastly you'll have to locate the physical sliding switch which controls the WNIC (on/off) and thumb it over to "on."
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
Mar 10, 2015 | HP Computers & Internet
My tablet is saying i am offline and will not connect to Wi-fi
Firstly Check if your WIFI router is working by accessing the WIFI connection from another computer, tablet or phone.
If it does, then use the same WiFi connection settings that it has on your ARCHOS.
You could also try connecting your ARCHOS to a friend's WiFi network and if this works, change your access point parameters to similar ones.
OTHER TROUBLESHOOTING OPTIONS:
1. Check your WiFi router/modem documentation to see if it has a pairing button that needs to be pressed. Some modems have such a button that must be pressed the very first time you try to make a WiFi connection with a new device.
2. If you have to enter a password (a security code of type WEP or WPA) be very careful that you do not confuse a 1 and I (one and letter "I"), a 0 and O (zero and letter "O"), or U and V. These are common mistakes.
3. When entering a security code for your WiFi access, check the box "Show Password" which will allow you to see exactly what you are typing in. This will avoid any mistakes.
4. Some access points use what is known as MAC filtering. That means, the WiFi access point has a list of access numbers (every hardware device has a unique MAC number) which are the only ones allowed to access to the WiFi point. The person managing the WiFi modem/router should shut off this MAC filtering system to see if this solves the problem. It is recommended to shut off MAC filtering in general as this is now known to be an outdated and ineffective system for WiFi security. If you must use it, you can find your device's specific MAC address by going to Settings >Wireless & Networks > Wi-Fi settings > Menu > Advanced. It will look something like 00:16:dc:5e:9e:39.
5. Try temporarily shutting off the encryption system of your WiFi router/modem to see if the problem has to do with the encryption system you are using. The preferred encryption system is the WPA2.
Aug 14, 2014 | Archos Tablets & eReaders
Cannot connect to wireless networks, where is
First of all check these are ok: Check your network adapter settings to see if you have your wireless card enabled. If that is ok, see if you can pick up any other wifi access points apart from your own. If you can see others fine, this means your wifi card is working correctly. If you can see your own access point and not connect to it, check the signal strength, items like microwaves and cordless phones can interfere with the signal. If you have a good signal try connecting. If it is asking for a key/password, then you will need to find the authentication key for your wireless access point.
If you cannot see your wifi access point but can see others, then you may have SSID broadcasting disabled, or the wifi might not be functioning correctly. Check these in your access point settings.
May 15, 2010 | Dell Inspiron E1505 Notebook
My PSP internet connection not supported to my access point.
The SSID is the NAME of your Routers connection. So you need to know your WiFi connections Name, That's the "Access point" Security, Is IF you assigned a WEP/WAP KEY, when the router was first setup. If NO Key is set, that is what it means "Unsecured",
You need to get a Netgear router manual, for your exact model, it shows all in pictures how to do it.
Apr 25, 2010 | Sony PlayStation Portable (PSP) Slim...
I have lost the manual to my WL-167g USB WLAN Adaptor and I want to connect to a different router I do not know how to set it up to operate the new router. the router is working on the internet with...
The wireless card will find any available access points. If you take the laptop to a location with wifi, the wireless card will find the wifi spot. Just open the wireless software you are using and ask it to refresh the wireless networks and you should see your wifi.
If you don't see your wifi but have confirmed your wireless network card works in other locations with other routers then take a look at your router configuration.
Please let me know if you have any more questions. Thank you.
Sep 29, 2009 | Computers & Internet
I recently purchased an IPOD Touch. I have wifi in my house and I'm able to check my email from that. However how do I go about setting the IPOD up to connect to other WIFI's when I'm in a different...
Usually Coffee Shops, fast food restaurants or perhaps your neighbors leave their wireless point access for use, unless they will put a protected password then you cannot able to access them.
Essentially your IPOD Touch can easily identify automatically wireless network in your range (open or password protected).
Ask them that you wanna connect to the wireless network and maybe they will give access to you.
Hope this might help you a tip on how and why you want access on WiFi Spot Network.
Please rate us.
Thank you.
Aug 31, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Nokia E61 Wifi connection
setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
Jul 08, 2009 | Nokia E61 Smartphone
Toubleshoot
My guess would be a networking problem where the two PCs can see all three access points and are getting confused. Perhaps getting a DHCP license from one of the other access points and then trying to use that, conflicting, IP to access the access point you want. If the PCs are fixed, you could always use three different SSIDs to prevent this from happening.
You don't mention it but you should have all three access points on different channels that are spread apart to minimize interference. Try shutting off the other two access points, right clicking on the network icon on an affected computer and selecting repair. If you can get on the network after this, then my solution will fix your problem.
You might want to consider switching to a solution designed for having multiple access points on one network. Open-Mesh is a pretty good inexpensive route and you can add multiple access points easily. The firmware is still in beta, however, I have a network of 5 nodes that is pretty reliable. If you want a more commercial solution, the Meraki network (the predecessor of open-mesh) is very robust but more expensive.
Sep 13, 2008 | Linksys BEFW11S4 802.11b Wireless...
Confirguration
After installing the hardware and physical mounting, basic configuration is something like below:
1. Set your computers TCP/IP address temporarily to be a static IP address such as 192.168.1.5;
2. Open your browser and type in 192.168.1.1 in the address bar. The EnGenius password prompt should appear. The default user is admin and the password is also admin. The control interface should now be accessible;
3. Under the Wireless heading click on Site Survey. This will display all the access points in your area. Your ISP or to whatever WiFi network you would want to connect should be listed in the ‘Wireless Site Survey’. Select the access point with the highest signal level or your choice. Click ‘Connect’;
4. After clicking ‘connect’, it should confirm that the EnGenius has connected successfully;
5. Click Ok and it will take you back to the list of wireless site surveys;
6. To confirm that the SSID has been changed go to the ‘Wireless Basic Settings’ page which is in the Wireless submenu in the left side bar. Once on the wireless page go to the box with SSID. The value should read "Your ISP or the WiFi network you would want to connect"; this has to be exact and case-sensitive to connect successfully.
This is just the start, all settings are configurable and actually depends as to how you would want to use the device; as a WiFi Access Point, as a client router mode or Wireless outdoor bridges in WDS mode.
After all settings have been changed to your requirement(s), go back to the PC's control panel and your network connections, and change your TCP/IP address back to DHCP settings (obtaining an IP address automatically). panel window.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 15, 2008 | EnGenius EOC-3220 (EOC3220)
Wifi access
Find the router and locate yourself as close as possible to it. If you are in the guest house and the router is in a main house, try opening a window or door if you can see the house out it, as wifi works better with less obstructions in between you and the access point.
May 05, 2008 | Computers & Internet
Computers & Internet Logo
225 people viewed this question
Alun Cox
David Payne
David Payne
