Question about Xantrex Technology Xantrex 458 10 12 Freedom 1,000 Watt Inverter/Charger
The inverter dose not charge the batters on my coach.
How many fuses are in the Xantrex Inverter. i found one on the first board blowen but cant tell the size? this unit on the front panel has a 15amp and 20amp breaker. it has a 110volt going to it.
From the manual I read on the Xantrex website shows 2 fuses. 1 in the F1 Position which is the outer circuit breaker, and the other in the F2 position. You can see the F1 tube-style fuse from the front, but the F2 fuse you have to tuck your head behind and see it from the other side. You can see if the fuse wire is burnt. To be sure, use an ohm meter to check the continuity of the circuit. Hope that helps.
Posted on Aug 18, 2010
I need a Control Board for my TR2424.
why do you need control aboard where are you fitting it and to what i have one on my coach its wired straight from my batteries
Nov 18, 2014 | Xantrex Trace Series TR2424-120-60...
Inverter Error err flashing
Not sure about this unit - but I can tell you how I fixed 2 of my own Xantrex inverters.
I took them apart and found that they had replaceable fuses - 400w inverter had 1 fuse and the 3000w had 12 which were blown. Replaced and all worked fine afterwards.
Hope this helps a little and good luck.
Apr 08, 2014 | Mitsubishi Electronics - Others
My Prosine 2.0 display panel displays Panel Fault: Memory error and the display error as well as all lleds are off. The unit looks as if it has no power to it. I reset (power off.power on) the prosine and...
This is a know and widespread problem with the Prosine 2.0, yet when you call Xantrex, they want to charge you to return, repair and/or replace the remote panel. Shame on you Xantrex.
Sep 06, 2010 | Xantrex Technology 806-1800 Prosine...
Xantrex 458 freedom....has stopped charging house batteries off of engine alternator. Alternator is showing that it works (dash gauge). It does charge while on shore power or generator....but not charging...
Fis\rst of all is the inverter supplying 120 VAC? when turned on?. If so the inverter seems to be working.I think your problem is in the truck alternator/charging system. The inverter is independent of this charger..
Mar 23, 2010 | Xantrex Technology Xantrex 458 10 12...
HEART 25 INVERTER
if the charger will not charge the batteries, it means the charger is bad or the fuse for the charger is broken
Mar 18, 2009 | Xantrex Technology Heart Freedom 25...
I have a motor home with a Trace inverter/charger. When the unit is connected to shore power the system will recarge the battery pack fine. When they are charged the remote meter will switch from bulk...
More than likely you may a a relay that is stuck or not energizing which should switch the charging mode over automatically. Trace back from the generator to the charging circuit for the batteries. I'm not sure where the relay (or solinoid) would be located but you can be assured it is something in the charger sensing/switching circuit.
Good Luck! Gary
Mar 12, 2009 | Xantrex Technology Trace Series Inverter /...
Inverter won't charge
check if the inverter has a fuse for the charger, if it does test it if it is still ok if not change it
Mar 09, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
Jan 15, 2009 | Xantrex Technology Heart Freedom 20 12...
Non-operational in RV when Onan generator and Xantrex inverter are on
Are you still under warranty with your RV? If so, take your RV back to them and try to get this problem fixed through them. You know more about electronics than I do (LOL) however, I do believe the RV sales/repair should be taking care of this issue for you.
I on the other hand own the Majestic brand washer and dryer and I am very dissapointed with them. The washer is broken already and is only 15 months old. Ugh!
Good luck, I hope your issue is a simple fix.
Oct 28, 2007 | Splendide 2100 Vented Washer-Dryer
Xantrex Technology Xantrex 458 10 12 Freedom 1,000 Watt Inverter/Charger Logo
575 people viewed this question
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
