Question about Canon Office Equipment & Supplies
Copier starts to scan but then stops and displays paper jamb. I have gone through the machine and cannot find any paper lambs. (I will saythat my two year old grandson was playing with yhe copier and constantly pushed the copy button). The model PC 745
  • John Muldowney
    John Muldowney Jul 27, 2010
    Have not tried it yet
  • 472 Answers
There is probably a slither of paper still stuck somewhere. You may need to remove the toner cartridge and fuser unit to get at it and have a good look.
Good Luck!
Posted on Jul 27, 2010
Hp 2410 loads paper but stops and says out of paper then paper jamb
Jamb:either of two stones, timbers, etc., forming the sidepieces for the frame of an opening.
Do you mean paper jam?
May 06, 2012 | HP PSC 2410 All-In-One InkJet Printer
The copier makes it half way thru the copy the stops with a paper jamb usually on the print table. I keep having paper jamb issues also have finger prints on copies which started after I removed the toner...
The jamming with the copy half way thru is almost always a broken fuser drive gear. The unit that gets hot as the paper exits the machine. Check the back side of this unit. You will see a gear, or part of a gear that is about 1.5 inches across. Either that gear breaks or the cog inside of it shears off and this causes the fuser not to turn. Very inexpensive part at less than $15 and pretty easy to change.
As far as the fingerprints go you most likely touched the drum surface. You may have to remove it again and clean your fingerprints off the drum with a soft cloth.
Oct 20, 2009 | Xerox Office Equipment & Supplies
First copy of the day jambs in copier.
Hell sir; Are you sure the document feeding direction is same as the paper direction in the tray you choice for a sample, if document feeding by landscape direction, †he paper tray paper should be landscape.
Mar 21, 2009 | Sharp AL 1631 Copier
How to scann photographic film fith epson scanner
Hi, I'm sorry to saythat this unit (DX4400) doesnt have the facility for film/negative scans
Dec 12, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Paper jam flasher
Henry, try blowing it all out with compressed air to clear jamb.
Nov 27, 2008 | Canon NP 7130 Black and White Copier
Panasonic FP 1780 Copier. The copier has a flashing wrench that will not reset. I need advice on resetting the wrench.
Hold down 3 buttons in this order:
Paper Tray (Oval button), Recall (Diamond) and #3.
You should see an F2 in the display.
Enter #5 (Display should be showing F5)
Hit the Print Button. (Display should show C00)
Enter 70. (Display should show C70)
Hit the print button. (Display should show probably a 7 or 8)
Hit the print button again. The print button should go Red for a second and then back to green.
Wrench should be gone.
Next to get out of service mode
Hit Clear / stop button until the display shows F5
Then hold down 3 buttons in this order:
Paper Tray, Recall and the Clear Stop button.
You should now be back to working order.
If you have any questions or need parts, feel free to ask.
Have a good day.
Good luck.
Please remember to leave your rating if I have helped you.
Mac
Apr 15, 2008 | Office Equipment & Supplies
Hp psc 1350v WILL NOT COPY OR SCAN
sounds like the scanner/copier engine(same device, by the way) has gone way UnHappy. time for a service call or a recycling effort on that machine..it's a major component..and buried deep inside machine.
Feb 19, 2008 | HP PSC 1350v All-In-One InkJet Printer
Gestetner #3470
The model number of your machine doesn't match up with anything I've seen. I'm thinking that it's a machine built by Ricoh and if so, that S/C 320 indicates that the polygon mirror motor has failed. If that is the case, it's going to be a costly repair as that part is burried way inside the machine and isn't easy to replace by the average layman. Sorry I couldn't be more help. I'm about 5,500 miles away.
Aloha,
Bill Monroe
Oct 17, 2007 | Office Equipment & Supplies
43 people viewed this question
old marine
old marine
