Question about Lexmark Wheelwriter 1000 Typewriter
The power only stays on for a few seconds.
Lexmark Wheelwriter 1000: The power only stays on for a few seconds. I have tried: unplugging unit from wall, unplugging cord from back of machine, cleaning dust etc. out of inside of unit. It turns on and the printwheel spins (like it always has), but then it shuts of completely. Any ideas?
  • Lexmark Master
  • 3,594 Answers
Check for forgien objects on or under the PC board if that dosen't do it you will probably need a tech.
DickyO
Posted on Jul 27, 2010
IBM Wheelwriter 6 powers up, then beeps. No lights, changed batteries. What is problem?
I have an instruction manual for IBM Wheelwriter 1000. The troubleshooting page in my manual for the machine coming on and having no lights is to make sure the cord is securely plugged into the typewriter and the wall or power strip and to switch the machine off and back on. Mine has a power saving mode where the lights go off after a while to enter power saving mode. I only need to touch a key to turn it back on.
Hope this helps - Cindy
Nov 06, 2014 | IBM Wheelwriter 6 Typewriter
Wheelwriter 1000 suddenly dead
No lights or beeps? Probably the power supply or popwer cord.
DickyO
Aug 21, 2012 | Lexmark Wheelwriter 1000 Typewriter
Lexmark Wheelwriter 1000 -Problem with wheel?
A few possibilities: The LED or sensor that looks at the primtwheel is getting weak, There may be debris on or under the PC board, the power supply is weak or rarely the flat white cable to the carrier is bad.
None of these are easy repairs, I'm sure we can repair it if you get it to us.
DickyO
216-241-0027
May 18, 2012 | Lexmark Wheelwriter 1000 Typewriter
Cant lift scanner unit to replace cartridge (stuck/jammed)
Try unplugging the unit from the wall and leaving unplugged for at least 40 seconds. Then plug it in, wait a few seconds and then turn on the power. Wait until the light on the front of the unit is steady green and try opening the unit. I hope this helps. Good luck. :-)
Dec 01, 2011 | Lexmark X4650 InkJet Printer
After my Wheelwriter 1000 is unplugged or turned
It sounds like your keyboard is going bad. You can try my tip under WW1000 or you can contact Geo. Beyers Co. @ 800-392-8085 for a rebuild.
DickyO
Jan 06, 2010 | Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 6 Typewriter won't come on.
When the switch is turned on, the machine sholuld cycle all the motors and home the carrier to the left margin position and one of the linespace lights whould be on. If the machine does not cycle at all:
  • Make certain that there is power to the outlet (try a known working appliance or light into that outlet)
  • Ched that the line cord is securely plugged into the wall outlet
  • Check that the line cord is securely pluggted intor the back of the typewrtier (you can wiggle it while the power switch is on and see if the machine reacts)
  • Flip the switch on and off several times, including a flicking motion
Nov 09, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
Wheelwriter 1000 beeps when I try to type!
Could be a few things, board, power supply, keyboard or printer.
But there are some things you can check, remove the printwheel and look for debris in that area, unplug and replug the keyboard, if you are really adventurious remove the cover and keyboard and look for paper clips or staples on or under the pc board.
DickyO
Aug 18, 2009 | Lexmark Wheelwriter 1000 Typewriter
Storing information on the lexmark 1000 typewriter
For the LexMark Wheelwriter 1000 you can only "Reprint" the information you have typed. Once you turn off the machine the "reprint" mode will not longer retain information.
Jan 28, 2009 | Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 1000
I believe Jim ment the platen (black rubber roller).
DickyO
Jul 27, 2008 | Lexmark Wheelwriter 1000 Typewriter
Lexmark 3500 carrier jam
Hi adirag! This is directly out of the user's manual! Clear Carrier Jam These are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges
______________________________________________
Hope this helps and good luck!
-WB
Jun 14, 2008 | Lexmark Wheelwriter 3500 Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
61 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
