Question about ASUS DRW-2014L1 DVD±R Dual Layer Burner
ASUS Driver wont operate
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19).
I have uninstalled and reinstalled several times and keep getting the above message
  • 2,632 Answers
Here's a solution to fix this:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT
and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
Thanks for using Fixya.
Posted on Jul 27, 2010
ATAPI DVD A DH168BSH configuration incomplete or damaged
Try uninstalling the DVD drive in the Device Manager in the Control Panel, then do a graceful shutdown of the PC. Power the PC back on and see if it finds "new hardware" and installs the driver. I take that you have an Acer Aspire PC.
Aug 11, 2012 | Acer Computers & Internet
My lenovo 3000c series also have this problem, code:19. please advise.... thank you
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged or corrupted.
Probably data in the registry for the device and its driver have been damaged/corrupted
Try these options,
•Click Uninstall, and then click Scan for hardware changes to load a usable driver.
or
•Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back or restore to the most recent successful registry configuration.
Hope it helps.
Aug 12, 2010 | Computers & Internet
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you should uninstall and then reinstall the hardware device. (Code 19)
Try these options:
•Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back to the most recent successful registry configuration.
Hope it helps.
Jul 10, 2010 | Microsoft Windows Vista Ultimate Edition
Code 19 DVD DX not working
  • Open up your Device Manager where you'll see your DVD DX Hardware Device that no longer works correctly. Click it, and then click uninstall. Once uninstalled you can reboot, or click 'scan for new hardware'. Either way Windows will find your Device again and reinstall the driver and probably fix the registry entries.
  • If that does not work, reboot your computer holding down F8 and select 'Load Last Known Good Configuration' before booting into Windows again. It'll restore your settings back when it didn't detect any problems.
Apr 21, 2010 | Computers & Internet
I have HP Pavilion 9500,Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolutions
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Here are some things that you can try to resolve this problem.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Revert to the most recent successful registry configuration
This content is designed for an advanced computer user.
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores all the registry information and driver settings that were in effect the last time that the computer started successfully.
For more information about the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 (http://support.microsoft.com/kb/307852/ ) How to start your computer by using the Last Known Good Configuration feature in Windows XP Edit the registry
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP
hope this helps
please leave feedback
thanks
Robb
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP.
Good Luck .. !!
Nov 22, 2009 | Acer Aspire 5315 Notebook
If you don't have a Registry backup you could use to overwrite your present corrupted one all you can do to save this install is to do a Repair install.
Nov 22, 2009 | ASUS A7N8X Motherboard
System unable to find the Driver
hi there depends on what windows you are using most drivers are only for xp
vista dose not support some xp drivers
Aug 24, 2009 | Computers & Internet
Dvd/cdrom wont wont install, media direct woks fine inspiron 6400
reformat again your windows.because your system is corrupted..that's why didn't install your DVDROM..
Jan 15, 2009 | Dell Inspiron 6400 Notebook
ASUS DRW-2014L1 DVD±R Dual Layer Burner Logo
299 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
