Question about Sony Ericsson P900
Sony Ericsson P900 touch screen: control panel cannot calibrate
Sony Ericsson P900 touch screen: control panel -> display -> calibrate, points 1 & 2 okay, 3 will not calibrate (point too far) ... and under save new settings, only working option is 'no', 'yes' cannot be accessed by touch screen. return to factory settings also doesn't help, consequently I cannot use the touch screen (right side of the screen doesn't work at all)
SOURCE: Sony Ericsson P900 touch screen Not working
touch area too far off screen, cannot get into 'device' option...and it would not calibrate anyway..'.too far from centre point 1.'
Posted on Sep 08, 2008
SOURCE: p990i touch screen problem
I encountered the same problem but was able to fix it. Just don't know if it's just temporary. Go to tools, control panel, other, set up wizard, tap yes, tap the second button before cancel, keep on clicking to the right direction until the numbers 1, 2, 3 and 4 appears. Tap the center of each number until blinking stops, save settings. For the first few steps you may use the jog dial found on the left side of the phone if the touch screen does not follow your tappings.
Posted on Sep 17, 2008
SOURCE: Sony-Ericsson P900 firmware files needed
my sony ericsson p900 is not recognized by my pc
Posted on Sep 28, 2008
270rexton
  • 782 Answers
SOURCE: i want to unlock my p900 sony ericsson
www.davinciteam.com £30
Posted on May 12, 2009
  • 34 Answers
SOURCE: sony ericsson M600i touch screen not working,not calibrating
it can be touch pad problem.
Posted on Jun 21, 2009
Hi The bottom of the toiuchscreen of the sony P1i is not working .. the top part is fine. Also sometime when I touch one icon, something else opens up. Its erratic. Can you help pls?
at first calibrate first your touchscreen sensitivity. at the control panel>setup wizzard>press next til the screen present you about calibration. > set up that and save if you have already copy your contacts from sim to your phone just ignore when it displays copy simcontacts to your phone. hope this helps.
*if software calibration doesnt fis this maybe it is the hardware.:(
Aug 07, 2010 | Sony Ericsson P1i
Hp pavillon tx1000 12.1 inch touch screen cursor stays at bottom left hand conrner
Clean the screen with a clean soft cotton cloth is the step #1
Step 2:
SEE FULL instruction HERE
Calibrate the touch screen
The command buttons and fields are displayed on the screen image at specific pixel points. To initiate a response, the touch screen interface needs to recognize exactly where a fingertip or pen touches the screen relative to the pixel position of the display. Each user has a slightly different hand-eye coordination response. Calibrating the touch screen allows the interface to compensate between where the program is expecting a touch and where the touch actually occurs. To calibrate the touch screen, place the tablet notebook in the desired orientation and do the following actions.
  1. Click or tap Start > Control Panel > Tablet PC Settings to open the Table PC Settings window.
  2. On the General tab, select the option to display the menus in either the Right-handed or Left-handed position.
  3. On the General tab, select the desired screen orientation from the drop-down menu, and click or tap Calibrate . Follow the instruction to touch the screen at the specified points. Repeat this calibration action for all four of the screen orientations, then click or tap Apply .
  4. On the Handwriting Recognition tab, select the Use the handwriting personalization option.
  5. At a later time, you can return to review the Go to Pen and Input Devices and Go to Input Panel Settings options to make using the touch screen to control programs and input text easier and more accurate.
Compare your version of the firmware to the latest one at HP offical site HERE
Always get the latest firmware to avoid problem.
Always keep the screen clean!
Jul 11, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
P990i touch screen not possible to calibrate
First, upgrade the software of the phone. After the upgrade, the setup wizard appears; complete it, and start it again from "Control panel", "Other", "setup wizard": now, just press the next button until 1 2 3 4 appears in the screen: don't select anything else, just the next button, or the calibration screen would not appear.
Jun 17, 2009 | Sony Ericsson P990i Cellular Phone
SonyEricson P900- Touch screen is not working AT ALL ! !
Try a master reset on the phone. If this doesn't help then the hardware has malfuntioned and the phone will need to be serviced.
Jun 08, 2008 | Sony Ericsson P900
Roohullah
hmmmm [:o]
my touch screen is not working at all [:(] sony ericson P900 [:(]
Jun 04, 2008 | Sony Ericsson P900
Touch screen not working properly
you can do it by running setup wizard, located in control panel->others-> setup wizard and follow instructions till you will be asked to tap on blinking points.
Sep 10, 2007 | Sony Ericsson P990i Cellular Phone
You Might want to calibrate the screen.
just go to control panel -> display
Sep 06, 2007 | Sony Ericsson P900
Touch screen calibration
Touch screen not working for sony ericsson P990i Mobile phone
When I hit the center some part above gets highlighted and selected and the botton part where the taskmanager and battery icons are present does not respond to my taps ... what could be the problem,,, kindly help me solve the issue.
Praveen
Aug 24, 2007 | Sony Ericsson P990i Cellular Phone
P990i touch screen problem
Sony Ericsson P900 Logo
205 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
