Question about Sector 550 Series Chronograph R3253993035 Watch
I just received a sector chronograph series 550 (water res 100m, chrono 1/5th sec) for my birthday. The only problem is that it is not running and i dont' find how to start it... Can anyone help?
  • claude_gronf Jul 27, 2010
    Thanks small6363 but even with the crown pushed or screwed (entirely), the watch doesn't start...
Set alarm on sector 550 chronograph alarm saphire crystal
Thanks for help!I love older Sector swiss watches !Those watches were built to last!
Sep 23, 2013 | Watches
I have a sport chronograph watch serial number AW60452W and need to reset the whole thing. How can I get a manual to achieve this?
company has down load manual, chronos pull out stem all the way and press the right top or bottom button , it should move in sec. incruments .,. press all way to the 12:00 and push in stem. press chro run top right. stop it after 10 sec. top right. then press bottom right. to reset it should go to 12. .. other dials can be set by stem in middle position.
Jun 17, 2011 | Watches
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
Reset
Some watches will change the day/date starting at 1130pm and not be done changing both until 230am. So yours may be normal for that particular watch. BTW, that is when the date does change to the next day, at 1201am. Hope this helps.
Jun 16, 2010 | Sector 550 Series Chronograph R3253993035...
My sector watch has damage to the case ,where can i get it repaired
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 19, 2010 | Sector 550 Series Chronograph R3253993035...
Hi there i have bought a second hand tag heuer carrera tachymeter,i dont have a user manual,but cant seem to get the chronograph functions to work ?
Great watch! Operation should be pretty straight forward. The top button starts the chrono and stops it. The bottom button resets it. To calibrate the sweep arm into the right position pull the crown out to the first or second set position and press the start button until the sweep arm is in the start position you desire. This is typically 12:00 or 0.
If your chrono is not working then have the battery checked. If the battery has been recently replaced then make sure the watch doesn't need to be cleared.
I recommend you take this to a watch maker/technician who will be familiar with the service requirements of this model including resealing and pressure testing the watch to be sure it is sealed to its marked water resistance specifications.
Thanks!
Sep 20, 2009 | Tag Heuer Carrera Series Chronograph Watch
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
SECTOR CHRONOGRAPH 200 WATCH
That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
Sep 19, 2007 | Watches
Sector 550 Series Chronograph R3253993035 Watch Logo
173 people viewed this question
Top Sector Watches Experts
staicuma
Level 1 Expert
aravind shet
aravind shet
Are you a Sector Watch Expert? Answer questions, earn points and help others
