Question about JC Whitney Flip Down Monitor From
Shifter replacement How do I step by step replace the floor shifter in a 2005 F-150 Ford Lariat
  • dmjza Apr 23, 2008
    How do I, step by step replace my floor shifter on a 2055 F-150 Lariat.
Do you know where i can get the replacement for an automatic shifter for a 2005 f150 lariat? its the shifter between the seats where they have the console...if you know email me at ctpitts12@hotmail.com
Posted on Nov 18, 2008
2004 Lariat. Automatic shifter broken off. How can I replace it?
If your talking about the chrome cover on top of the shifter Ford sells an updated cover.
Mar 26, 2016 | Ford F-150 Cars & Trucks
I have a 2012 Ford Fusion SE and the shifter is stuck in park and I have no brake lights. I already have had the brake switch replaced twice within 3 months.
if the shifter is on the floor there should be slot that a key will go in and manuly release it,neutral before starting check fuses electical release
Mar 18, 2015 | 2012 Ford Fusion SE
2001 pontiac aztek Has floor mounted shift. Won't shift out of park.
First of all, you are stepping on the brake pedal when you try to shift. Had to ask.
It could be a number of things. I have a 2000ish Grand Am that wouldn't shift. The problem turned out to be the T-handle on the shifter. Most GM shifter handles come off the same way. If there is a rubber/leather boot, pull that down a little to expose a metal clip.
The metal clip can be pulled off straight for\ward (I think), and the handle comes off.
The shifter will be a tube with a plastic rod sticking out of it. Try pushing the rod in, and see if the shifter works. If yes, replace the handle. If not, the problem is probably down in the shifter.
When you step on the brake, there is a cable going from the brake pedal to the shifter. Step on the brake and you should hear something moving in the center console/shifter. If not, the cable could be detached or broken.
The shifter itself may be broken, but that can be tough to get to.
The could be something wrong at the transmission, or inside the trans.
Feb 27, 2011 | 2001 Pontiac Aztek
How do i replace the plastic handle on my automatic shifter for my ford f150 2006 lariat
I assume you have a console floor shifter...You may need to pull shifter all the way back to low gear to see...look near the bottom on the back side of the handle...you should find a removeable screw or pull out clip...after removing this, the handle should lift off...New handles are roughly $35. at your Ford dealer...or they are plentiful in your nearest salvage yard...Hope this helps.
Feb 01, 2011 | Ford F-150 Cars & Trucks
My 2006 Road King toe shifter is stripped. How do I replace the post that the heel / toe shifter levers attach to? Is it difficult for an average, mechanically inclined guy? I'm trying to save some cash....
If that's where your shifter is stripped, you're lucky. Usually, they strip back where the shifter rod connects to the shifter pawl shaft.
To replace the shaft at the shifter lever, just take the floor board off and the bolts that hold the shifter bracket on. Slide the bracket off the shaft and take the shifter rod off the shaft. No problem.
Good Luck
Steve
Nov 06, 2010 | 2006 Harley Davidson FLHR Road king
I need to replace the shift handle and can not get the old part to pop up for replacement (part#4L3Z 7213 BA) FORD F150 LARIAT 2005
The top does not just pop off, you need to pull out on the button, and release the button. Once the button is off, you will see the set screw holding the shifter handle in place, release the set screw and the whole handle comes off as a single part.
The releasing of the shift button is hard to do, it is really stuck on.
Mar 05, 2010 | 2005 Ford F-150
2001 FORD FOCUS SHIFTER CABLE SNAPED
You did not need to remove the heater box to replace the cable. There is a hole in the floor the cable passes through.
Nov 15, 2009 | Ford Focus Cars & Trucks
2008 Chevy Cobalt - care is running, but I can't turn it off! Go to park, try and move the key and it won't move to the off position to turn off the car
replace the shifter assembly.I replace alot of them.use this bulletin as a reference.Subject: Various Concerns With Shifter and/or Ignition Key (Replace Shifter Assembly/Shifter Components or Ignition Lock Cylinder )
Models: 2005-2008 Chevrolet Cobalt
2005-2006 Pontiac Pursuit (Canada Only)
2007 Pontiac G5
with Automatic Transmission 4T45-E (RPO MN5)
Some customers may comment on any of the following concerns:
• The shifter is hard to move or binds.
• They cannot remove the ignition key.
• It takes high effort to rotate the key.
Cause 1
The shifter button may be sticking in the handle.
Cause 2
The pin that activates the micro-switch may have moved out of position (refer to illustration above). This causes the micro-switch to fail to engage when the vehicle is placed in Park. If this condition is present, the customer will not be able to remove the key from the ignition.
The illustration above shows the switch in a correct position.
Cause 3
Metal flashing left in the cylinder may cause a high effort to rotate the key.
Cause 4
The slider may be binding in the guides. This may cause the shifter to become difficult to operate.
Correction 1
Verify that the shifter button is inoperative by evaluating if the park pawl pin on the shifter assembly moves when activating the button. If the parking pawl does not move when the button is activated, the shifter handle will have to be replaced. Refer to Floor Shifter Control Knob Replacement in SI.
Correction 2
Important: A change has been made to the shifter assembly for service. The replacement shifter assembly will read PRNDIL (Park, Reverse, Neutral, Drive, Intermediate and Low).
Verify that the micro switch is out of position. Replace the shifter assembly. Refer to Transmission Control Replacement in SI.
Correction 3
Important: Refer to instruction sheet that is supplied with the lock cylinder kit. BO 47869 is an essential staking tool and must be used for the repair.
Replace the ignition lock cylinder. Refer to Ignition Lock Cylinder Replacement in SI.
Correction 4
Replace the slide indicator and guides in the shifter following the procedure below:
Apply the parking brake.
Remove the upper console trim. Refer to Trim Plate Replacement-Console Front in SI.
Remove shifter knob. Refer to Floor Shifter Control Knob Replacement in SI.
Remove the indicator plate. Use a flat-bladed screwdriver to release the locking tabs.
Remove the shifter indicator lens.
Pull up on the indicator and remove it from the assembly.
Remove the two front rails by unsnapping the front and lifting up, and then back, to remove the rails from the shifter assembly.
Install the new guides. Place the hook end into the assembly and push down. It will snap into place.
Install the new slide indicator. With the transmission in neutral, place the slide over the shifter and into the guides. Move the slide indicator down the guides in the front and rear.
Important: Replace the shifter indicator lens if damage is present due to the slider binding or if it becomes damaged during disassembly.
Install the shift indicator lens.
Install the shift indicator plate.
Install the shifter knob. Refer to Floor Shifter Control Knob Replacement in SI.
Install the upper console trim. Refer to Trim Plate Replacement-Console Front in SI. post back with what you find.
Jan 20, 2009 | 2008 Chevrolet Cobalt
Floor shifter ont engage to park
YES THE PART THAT IS BROKEN IS MOST LIKELY A WHITE PLASTIC PIECE THAT SITS INSIDE THE SHIFTER HOUSING, REMOVE THE SHIFTER HANDLE REMOVE THE WHITE PLASTIC PIECE WITH ALL THE ROUND BALLS ON IT (I KNOW WHAT IT LOOKS LIKE YOU DONT HAVE TO SAY IT) AND LOOK DOWN THE HOUSING WITH A FLASHLIGHT IF YOU STILL SEE A PART OF THAT WHITE PLASTIC PIECE, THATS YOUR PROBLEM. YOU CAN EITHER REPL SHE SHIFTER LEVER P# 52078551AG OR SEARCH THE JUNK YARDS FOR THAT PART
Nov 29, 2008 | 2004 Jeep Wrangler
How to repair 66 ford f100 steering column
contact ford. for parts and diagram
Oct 24, 2008 | 1981 Ford F 100
Car Audio & Video Logo
199 people viewed this question
Top JC Whitney Car Audio & Video Experts
Jaime Hernandez
xxxxxx xxx
Are you a JC Whitney Car Audio and Video Expert? Answer questions, earn points and help others
