what you need to do to fix up oven back again
is that you will have to locate the element of your oven it has develop a lick-age from it some air get escape from it and
the element is the heat provider for your oven that allow it to carry out it function has an oven it is always in silver colour and it is connected to the maize (the wire or the hose from the gas ) which supply power to it
unscrew the oven from the back and trace the wire or the hose that connect to the element
please do this with care to avoided more damage on it
OR
You have one or two possibilities here, one is your control board is going out. The second and most likely problem which is usually associated with this error is that the Latch to the door, or switch is failing causing this message to appear. You need to replace the latch to fix the problem. A new latch can be bought from the place you bought the oven or from RepairClinic.com
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Well is there any error code on the digital display of your Microwave/oven?
Do you mean how to keep it from beeping when you press keys, or is it beeping by itself?
If the microwave oven is coming on or doing anything (beeping) by itself, this is very dangerous and can result in a fire.
First of all you cam leave it unplug for half hour, it helps you to reset your microwave/oven. If further you have the same problem please reply to the questions.......
Good Luck!!
Thanks
There is not an error code.
the microwave is beeping by itself.
the microwave is not coming on by itself.
i cant unplug because it is built-in. I have tried shuting off power to the microwave but when I turn the power back on the beeping starts right up.
I have not heard back since the first responce two days ago.
