Question about Cobra 19 Ultra II CB Radio
Key mike no hears me but shows meter - Cobra 19 Ultra II CB Radio
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 184 Answers
You didn't mention if you hear the other radio. If not, here's a common problem and solution.
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike.
However, if you hear them, and they see your signal, but no talk (modulation), then the problem is usually your mike. Try another one in this case. Thanks, Bill
Posted on Sep 01, 2010
My cobra 29 turns on but i have no sound i can hear it key up and the meter swings speakerand mike are good could it be the finels
Are you sure its not on PA mode? And if the meter swings forwards its not a finale. It could be a bad soldier or IC chip. If you don't have it on PA to see if your IC chip is good take an external speaker plug it into your PA jack in the back turn on the PA switch and then key up the radio.Does it squeal or make any kind of noise if yes the the chip is good if no then there's your problem.If it is good Then its could be just a simple bad soldier.
Jul 15, 2012 | Cobra 29 LTD CB Radio
My connex 3300 wont transmit anymore and the talk back wont work either,i have tried a different mike and when you key it up the meter still won't swing.
Plug in an external speaker to the pa jack ... Switch the band selector to pa and see if you hear yourself... No? Bad audio chip
Dec 29, 2010 | Connex 3300 240-Channels Base CB Radio
Cobra 29 nw when you key the radio the swr meter doesnt move and if you move the swicth to cal you can adjust it with out keying the mike but has good recive any help would be good thanks dwayne
To check the SWR, you put the swicth on CAL and key the mike with mike gain turned down all the way,then calabrate it to the meter on the CAL scale,then swicth it to SWR before you unkey the mike, then what ever the needle falls back to, that is your SWR reading.
Apr 26, 2010 | Radio Communications
Can hear others, they can't hear me.
You need a standing wave meter to see if your radio is putting out. Another thing to check is the microphone and its switch. You could use a 'dummy load'm, to check these things if you can find one for sale. It is made up of a coax fitting with a small light bulb attached. When you key the mike, the light should light up. As you talk, the intensity should change.
Mar 21, 2010 | Radio Communications
When I key the mic the needle on the meter does not move I have power to the radio and the mic is new
Try putting it on cb not pa,see if you hear other people talking,now try it.....could be the mike is not wired right,or bad meter..Put it on channel 19,ask for a radio check,if someone answer,s you its ok, maybe meter not adjusted...hope this helps..
Feb 28, 2010 | Cobra 29 LTD CB Radio
Superstar 3900 with no USB or LSB on receive.
most likely been fiddled with and out of alignment. If you have a freq counter and a volt meter you could possibly fix it yourself. look at cbtricks.com for the aligment procedure.
Jun 13, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
External mike doesn't work
I'm assuming you have Windows Vista. If so, you may need to change the default microphone, particularly if you have a built-in microphone on the computer.
1. Right-click the speaker icon next to the clock in the system tray.
2. Select "Recording Devices"
3. Select "Microphone" or whatever item you want to record with.
There will be a VU meter showing the input level. Try talking into you mike and see if the VU meter goes up. If so, you're good to go.
If not:
1. Click the "Properties" button in the screen mentioned above
2. Move the "Volume" and "Boost" sliders up.
3. Click "OK."
4. Check your VU meter again.
If this does not work it is possible you selected the properties for the wrong device. Click on another device and repeat the last 4 steps again.
Jun 02, 2009 | Dell Inspiron 9300 Notebook
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
98 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
